Laravel is not found
I installed Laravel but when I want to start a new project
find-the-command: “laravel” is not found locally, searching in repositories...
find-the-command: command not found: “laravel”
I get an error.
then I can add to the bashrc file
export PATH=“$HOME/.composer/vendor/bin:$PATH”
and then when I said “source bashrc”
~/.bashrc (line 5): Missing end to balance this if statement
if [ -x /usr/bin/starship ]; then
from sourcing file ~/.bashrc
source: Error while reading file '/home/*/.bashrc'
I get an error. when I close that code block
~/.bashrc (line 2): $- is not a valid variable in fish.
[[ $- != *i* ]] && return
I get an error.
garuda-inxi;
Kernel: 6.9.1-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=a96a4615-ec9d-45b6-8fff-214051405d4a rw rootflags=subvol=@
quiet resume=UUID=b192c665-62e5-40f1-b438-14cd9c435ad9 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk2xxx
Mobo: HP model: 88E4 v: 76.41 serial: <superuser required>
part-nu: 4H0V9EA#AB8 uuid: <superuser required> UEFI: Insyde v: F.24
date: 10/04/2023
ID-1: BAT1 charge: 41.8 Wh (98.8%) condition: 42.3/52.5 Wh (80.5%)
volts: 12.9 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
microcode: 0xB6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 906 high: 2798 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 2798 6: 524 7: 1928 8: 400 bogomips: 52838
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: HDMI-A-1,eDP-1 empty: DP-1, DP-2, DP-3, DP-4
bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 550.78
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 bus-ID: 0000:01:00.0 chip-ID: 10de:1f9d class-ID: 0302
Device-3: Lite-On HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 04ca:707f
gpu: i915,nvidia d-rect: 3520x2080 display-ID: 0
Monitor-1: HDMI-A-1 pos: bottom-r res: 1600x1000 size: N/A modes: N/A
Monitor-2: eDP-1 pos: primary,top-left res: 1920x1080 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.7-arch1.3
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 7.33 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: integrated-gpu
name: Intel Xe Graphics (TGL GT2) driver: mesa intel v: 24.0.7-arch1.3
device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1650 driver: nvidia v: 550.78
device-ID: 10de:1f9d surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.0.7-arch1.3 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.9.1-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000
bus-ID: 0000:02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852AE WiFi 6 802.11ax PCIe Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel port: 3000
bus-ID: 0000:03:00.0 chip-ID: 10ec:a85a class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 0bda:385a
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 80.31 GiB (16.8%)
model: MZVLQ512HALU-000H1 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS4NFXV temp: 45.9 C scheme: GPT
used: 80.31 GiB (17.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 7.51 GiB used: 1.13 GiB (15.1%)
System Temperatures: cpu: 64.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Memory: total: 8 GiB available: 7.51 GiB used: 4.04 GiB (53.8%)
Processes: 308 Power: uptime: 46m states: freeze,mem,disk suspend: s2idle
image: 2.96 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1977 libs: 582 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-05-11
Last full system update: 2024-05-23
sorry for my english and linux knowledge*
Maybe this happens because in Konsole your shell is fish not bash.
Enter into a bash shell and try again or change the shell in konsole with Settings → Edit Current Profile →General → Command.
export PATH=“$HOME/.composer/vendor/bin:$PATH” is the wrong path.
the correct one
export PATH=“$HOME/.config/composer/vendor/bin:$PATH”
I added bashrc and bash_profile and then source and of course I had to change fish.
thank you.
It’s unusual to add a ~/.config directory to PATH. It is possible this application has been set up oddly.
Anyway, if you are going to be using Fish an easier way to set this up would be to run fish_add_path against it.
fish_add_path ~/.config/composer/vendor/bin
That should add it to the path for you. No need to source anything or change shells or whatever, just open the terminal and carry on with your work. fish_add_path - add to the path — fish-shell 3.7.0 documentation
Thank you very much. It worked.
