Hi all -
new Garuda user hear and I’ve seen some oddities with the XFCE environment that I wanted to understand better.
I run dual screens - a large display and the laptop’s native display. Unfortunately, XFCE only gives me an option of 2560x1600 for the laptop display which made things VERY small and near unusable. After some fiddling, I used a custom scale of X 0.5 and Y 0.5 and I could get the visibility I was looking for, but now the screen appears to scroll up and down within the confines of the monitor? For example, if I put my mouse on the right side of the laptop screen, it will scroll to the right causing the wallpaper to disappear. Similarly, if I put the mouse at the bottom of the screen, it scrolls down until the wallpaper disappears as well. I can scroll back up to what would be the top of the screen, but moving left causes the mouse to pop out onto my other monitor. Initially I thought it might’ve been the workspaces, but reducing the workspaces to 1, did not address the issue. Oddly, this scrolling behavior also appears to affect the dimensions of the primary display, removing the ability to access the left side of the screen?
Thanks in advance!
Mike
inxi is below:
Kernel: 6.6.32-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=88957d70-06c0-4be3-b335-b2ee2a415d61 rw rootflags=subvol=@
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Laptop System: ASUSTeK product: ROG Zephyrus M16 GU604VZ_GU604VZ
Mobo: ASUSTeK model: GU604VZ v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: GU604VZ.312
date: 09/07/2023
ID-1: BAT0 charge: 84.0 Wh (100.0%) condition: 84.0/90.0 Wh (93.3%)
volts: 17.5 min: 16.0 model: AS3GYFG3KC R220358 type: Unknown
serial: <filter> status: full
Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4121
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 572 high: 944 min/max: 400/5200:5400:4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 679 2: 400 3: 630 4: 400
5: 616 6: 400 7: 792 8: 944 9: 400 10: 706 11: 827 12: 943 13: 400 14: 400
15: 400 16: 400 17: 918 18: 400 19: 400 20: 400 bogomips: 119840
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: DP-2 empty: DP-3 bus-ID: 0000:00:02.0 chip-ID: 8086:a7a0
class-ID: 0380
Device-2: NVIDIA AD104M [GeForce RTX 4080 Max-Q / Mobile] vendor: ASUSTeK
driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ ports: active: none off: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 0000:01:00.0 chip-ID: 10de:27e0
Device-3: Sonix USB2.0 FHD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:6 chip-ID: 3277:0018
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 6000x2119 s-dpi: 122 s-size: 1249x381mm (49.17x15.00")
s-diag: 1306mm (51.41")
Monitor-1: DP-2 mapped: DP-1-2 pos: primary,top-left model: LG (GoldStar)
ULTRAGEAR+ serial: <filter> built: 2024 res: 3440x1440 hz: 240 dpi: 84
gamma: 1.2 size: 1043x436mm (41.06x17.17") diag: 1130mm (44.5") modes:
max: 3440x1440 min: 640x480
Monitor-2: eDP-1 mapped: DP-2 note: disabled pos: bottom-r model: BOE
Display NE160QDM-NM4 built: 2022 res: 1280x800 dpi: 2032 gamma: 1.2
size: 16x10mm (0.63x0.39") diag: 407mm (16") ratio: 16:10 modes: 2560x1600
API: Vulkan v: 1.3.279 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4080 Laptop GPU driver: nvidia v: 550.90.07
device-ID: 10de:27e0 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel Graphics (RPL-P) driver: mesa intel v: 24.1.1-arch1.1
device-ID: 8086:a7a0 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51ca class-ID: 0403
Device-2: NVIDIA AD104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:22bc
Device-3: Realtek LG Monitor Headset MIC driver: hid-generic,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.3:4
chip-ID: 0bda:4cb6 class-ID: 0300
Device-4: Razer USA Nari Ultimate driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5.2.4.1.4:15
chip-ID: 1532:051a class-ID: 0300
API: ALSA v: k6.6.32-1-lts status: kernel-api tools: N/A
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f1 class-ID: 0280
Device-2: Realtek USB 10/100/1G/2.5G LAN driver: r8152 type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2.4.2.1:6
chip-ID: 0bda:8156 class-ID: 0000 serial: <filter>
IF: eth0 state: up speed: 2500 Mbps duplex: full mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:7 chip-ID: 8087:0033
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 4.57 TiB used: 20.92 GiB (0.4%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: SK Hynix model: HFS001TEJ9X101N
lanes: 4 tech: SSD serial: <filter> fw-rev: 51000A20 temp: 43.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 4TB size: 3.64 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 40.9 C scheme: GPT
ID-1: / raw-size: 256 GiB size: 256 GiB (100.00%) used: 9.17 GiB (3.6%)
fs: btrfs dev: /dev/nvme1n1p4 maj-min: 259:4
used: 588 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p3 maj-min: 259:3
ID-3: /home raw-size: 380.42 GiB size: 380.42 GiB (100.00%)
used: 5.73 GiB (1.5%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:14
ID-4: /usr raw-size: 1000 GiB size: 1000 GiB (100.00%)
used: 6.02 GiB (0.6%) fs: btrfs dev: /dev/nvme1n1p6 maj-min: 259:5
ID-5: /var/log raw-size: 256 GiB size: 256 GiB (100.00%)
used: 9.17 GiB (3.6%) fs: btrfs dev: /dev/nvme1n1p4 maj-min: 259:4
ID-6: /var/tmp raw-size: 256 GiB size: 256 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.97 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 51.0 C mobo: N/A gpu: nvidia temp: 50 C
Fan Speeds (rpm): cpu: 2200
Memory: total: 32 GiB note: est. available: 30.97 GiB used: 4.05 GiB (13.1%)
Processes: 441 Power: uptime: 22m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 12.35 GiB services: power-profiles-daemon,
upowerd, xfce4-power-manager Init: systemd v: 255 default: graphical
Packages: pm: pacman pkgs: 1478 libs: 434 tools: octopi,pamac,paru,yay
Compilers: gcc: 14.1.1 Shell: garuda-inxi default: Zsh v: 5.9
running-in: xfce4-terminal inxi: 3.3.34
System install date: 2024-06-12
Last full system update: 2024-06-12
Failed units: mnt-NetHome.mount mnt-NetMX.mount mnt-NetShared.mount mnt-NetWeb.mount
