Hi guys,
I am complete newbie to Linux but I find Garuda as the best treatment from my Microsoft depression .
I am trying to run games on my NVIDIA card but now I am realizing that even if I updated to the proprietary NVIDIA driver my card is still not in use. .
I`ve tried this so far:
Up to date drivers
sudo pacman -S nvidia-dkms
It will be much easier if I`v had the permission to upload screenshots((
What’s the problem with not posting garuda-inxi?
It contains additional, useful information about the status of your system.
Did you search in forum?
Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
ONE issue per topic.
Describe your issue in detail. The more we know, the better we can help
Show us the results of your searches, and what you’ve tried
After rebooting, post the FULL output of garuda-inxi
in the body of the post (not linked externally, or collapsed with the “hide details” feature)
Format terminal output (including your garuda-inxi
) as a code block by clicking the preformatted text button (</> ) , or put three tildes (~) above and below the text
Without garuda-inxi this request will be moved to 412 Precondition Failed
HI, do you mean this?
ystem:
Kernel: 6.7.6-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=545f7bc0-c81c-450b-930e-831da044d26b rw rootflags=subvol=@
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: PCSpecialist product: Standard v: Standard
serial:
Mobo: TongFang model: GM7MG0P v: Standard serial:
part-nu: 0001 uuid: UEFI: American Megatrends
v: N.1.07PCS04 date: 02/24/2021
ID-1: BAT0 charge: 67.3 Wh (100.0%) condition: 67.3/91.6 Wh (73.4%)
volts: 12.4 min: 11.6 model: standard type: Li-ion serial:
status: full
Info: model: Intel Core i7-10875H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF8
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 min/max: 800/5100 scaling: driver: intel_pstate
bogomips: 73598
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Tongfang Hongkong
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:5 chip-ID: 04f2:b68b
class-ID: 0e02 serial:
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
s-diag: 777mm (30.58")
Monitor-1: eDP-1 model: BOE Display 0x0977 built: 2020 res: 2560x1440
hz: 165 dpi: 171 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
ratio: 16:9 modes: 2560x1440
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-arch1.1
device-ID: 8086:9bc4 memory: 30.43 GiB unified: yes
API: Vulkan v: 1.3.276 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.0.2-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Tongfang Hongkong
API: ALSA v: k6.7.6-zen1-2-zen status: kernel-api with: aoss
Device-1: Realtek RTL8125 2.5GbE vendor: Tongfang Hongkong driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
IF: enp3s0 state: down mac:
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0029
rfk-block: hardware: no software: yes address: bt-v: 5.2 lmp-v: 11
Local Storage: total: 715.41 GiB used: 146.98 GiB (20.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 tech: SSD serial: fw-rev: 004C temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 model: 256GB PCS PCIe M.2 SSD
lanes: 4 tech: SSD serial: fw-rev: T0707A0L temp: 39.9 C
used: 146.98 GiB (61.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
ID-1: swap-1 type: zram size: 31.16 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C pch: 47.0 C mobo: N/A
Memory: total: 32 GiB available: 31.16 GiB used: 4.97 GiB (15.9%)
Processes: 418 Power: uptime: 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.42 GiB services: csd-power,upowerd
Packages: pm: pacman pkgs: 1608 libs: 519 tools: pamac,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0
running-in: gnome-terminal inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-24
Last full system update: 2024-03-02 ↻
Yes, but
↻ Means, you update the system, but reboot needed.
filo
2 March 2024 07:35
5
Your Nvidia GPU is not reported in the garuda-inxi Graphics section.
Are you sure it is not disabled in the BIOS?
HI again guys
So I`ve updated the system again and this is my new results:
Mobo: TongFang model: GM7MG0P v: Standard serial: <superuser required>
part-nu: 0001 uuid: <superuser required> UEFI: American Megatrends
volts: 12.4 min: 11.6 model: standard type: Li-ion serial: <filter>
status: full
bogomips: 73598
ports: active: eDP-2 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Tongfang Hongkong driver: nvidia v: 550.54.14
2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none empty: DP-1,HDMI-A-1,eDP-1
bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-3: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-2 model: BOE Display 0x0977 built: 2020 res: 2560x1440
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 Laptop GPU driver: nvidia v: 550.54.14
device-ID: 10de:2520 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-2: NVIDIA GA106 High Definition Audio vendor: Tongfang Hongkong
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0029
Local Storage: total: 715.41 GiB used: 146.92 GiB (20.5%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 004C temp: 26.9 C scheme: GPT
lanes: 4 tech: SSD serial: <filter> fw-rev: T0707A0L temp: 39.9 C
used: 146.92 GiB (61.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:5
System Temperatures: cpu: 42.0 C pch: 47.0 C mobo: N/A
Memory: total: 32 GiB available: 31.16 GiB used: 3.51 GiB (11.3%)
Processes: 374 Power: uptime: 11m states: freeze,mem,disk suspend: deep
Garuda (2.6.23-1):
Failed units: nmb.service
Hopefully I posted it in the right place
filo
2 March 2024 08:04
7
That’s better. Now the dGPU is there.
To use it
Please format terminal text like this, to make it more readable
You were right Filo,
In bios was selected Igpu only for some reason.
Thank you for that
system
Closed
4 March 2024 08:05
9
