my system info
Kernel: 5.18.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=7a6526ce-88e4-40a8-95cf-54dfd046b840 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 info: latte-dock
Type: Convertible System: LENOVO product: 81X2 v: IdeaPad Flex 5 14ARE05
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: EECN36WW date: 05/17/2021
ID-1: BAT0 charge: 40.2 Wh (75.8%) condition: 53.0/52.5 Wh (100.9%)
volts: 12.2 min: 11.6 model: LGC L19L3PD6 type: Li-poly serial: <filter>
status: discharging cycles: 539
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x60 (96) stepping: 1 microcode: 0x8600106
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1423 high: 1579 min/max: 1400/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1427 2: 1397
3: 1579 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 bogomips: 31940
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN 5.1
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:2
chip-ID: 5986:212a class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1406 built: 2019
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.46 5.18.5-zen1-1-zen)
v: 4.6 Mesa 22.1.2 direct render: Yes
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.18.5-zen1-1-zen running: yes
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
bus-ID: 3-4:4 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 4 state: down
address: <filter>
Local Storage: total: 476.94 GiB used: 64.51 GiB (13.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVME 512G size: 476.94 GiB
type: SSD serial: <filter> rev: T1102A0L temp: 35.9 C scheme: GPT
ID-1: / raw-size: 371.17 GiB size: 371.17 GiB (100.00%)
used: 64.48 GiB (17.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 21.4 MiB (7.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 371.17 GiB size: 371.17 GiB (100.00%)
ID-4: /var/log raw-size: 371.17 GiB size: 371.17 GiB (100.00%)
ID-5: /var/tmp raw-size: 371.17 GiB size: 371.17 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.14 GiB used: 59 MiB (0.8%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 47.0 C
Processes: 293 Uptime: 19h 24m wakeups: 12 Memory: 7.14 GiB
used: 4.1 GiB (57.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1520
lib: 359 Shell: fish v: 3.4.1 running-in: konsole inxi: 3.3.19
Garuda (2.6.4-1):
System install date: 2022-06-11
Last full system update: 2022-06-24 ↻
╭─sanbid@sanbid in ~ took 2s
╰─λ sudo garuda-inxi
[sudo] password for sanbid:
Console: pty pts/3 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
serial: <filter> Chassis: type: 31 v: IdeaPad Flex 5 14ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
ID-1: BAT0 charge: 40.1 Wh (75.7%) condition: 53.0/52.5 Wh (100.9%)
Info: model: AMD Ryzen 7 4700U with Radeon Graphics socket: FP6 bits: 64
type: MCP arch: Zen 2 gen: 3 built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x60 (96) stepping: 1 microcode: 0x8600106
desc: 2x4 MiB
Speed (MHz): avg: 1550 high: 2000 min/max: 1400/2000 boost: enabled
base/boost: 2000/4200 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 2000 3: 2000 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 31940
address: <filter>
SMART: yes health: PASSED on: 59d 12h cycles: 4,053
read-units: 11,041,892 [5.65 TB] written-units: 9,925,748 [5.08 TB]
used: 64.49 GiB (17.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 21.4 MiB (7.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 294 Uptime: 19h 25m wakeups: 12 Memory: 7.14 GiB
used: 4.09 GiB (57.3%) Init: systemd v: 251 default: graphical
lib: 359 Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
Garuda (2.6.4-1):
any solution
