Hello all
I am swaped from Manjaro. I have installed system, updated and my external monitor on slot doesn't have signal. System sees but monitor dont respond. When I try to switch with WinKey + P for only external monitor I got black on both and need to disconnect hdmi to back to my laptop screen.
Below commands results we can start with.
xrandr:
─λ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 144.00*+ 60.02
1680x1050 144.00
1280x1024 144.00
1440x900 144.00
1280x800 144.00
1280x720 144.00
1024x768 144.00
800x600 144.00
640x480 144.00
HDMI-1-0 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 144.00 119.98 119.88 99.93 74.97 59.94 50.00
1280x1024 75.02 60.02
1280x720 59.94 50.00
1024x768 119.99 100.00 75.03 70.07 60.00
800x600 119.97 100.00 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 120.01 99.99 75.00 72.81 59.94 59.93
─λ garuda-inxi
LANGUAGE = "en_US",
LC_ALL = (unset),
LC_ADDRESS = "en_GB.UTF-8",
LC_NAME = "en_GB.UTF-8",
LC_MONETARY = "en_GB.UTF-8",
LC_PAPER = "en_GB.UTF-8",
LC_IDENTIFICATION = "en_GB.UTF-8",
LC_TELEPHONE = "en_GB.UTF-8",
LC_MEASUREMENT = "pl_PL.UTF-8",
LC_TIME = "en_GB.UTF-8",
LC_NUMERIC = "en_GB.UTF-8",
LANG = "en_GB.UTF-8"
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
Kernel: 6.0.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=c8ef7bab-57c7-49bc-bf44-205e6b6cafef rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec1xxx v: N/A
Mobo: HP model: 87B2 v: 31.23 serial: <superuser required> UEFI: AMI
v: F.25 date: 08/18/2021
ID-1: BAT0 charge: 42.9 Wh (100.0%) condition: 42.9/42.9 Wh (100.0%)
volts: 12.5 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: full cycles: 385
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600106
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2896 high: 3000 min/max: 1400/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3000 2: 3000
3: 3000 4: 3000 5: 3000 6: 3000 7: 3000 8: 3000 9: 3000 10: 3000 11: 1755
12: 3000 bogomips: 71867
protection
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:1636
class-ID: 0300 temp: 46.0 C
Device-3: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 3-3:2 chip-ID: 30c9:0013 class-ID: 0e02
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-1-0 size-res: N/A modes: N/A
Monitor-2: eDP pos: primary res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.48 6.0.7-zen1-1-zen) direct render: Yes
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir pcie:
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k6.0.7-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.60 running: yes
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0
Device-1: Realtek 802.11ac WLAN Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 942.7 GiB used: 31.18 GiB (3.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1006 size: 476.94 GiB block-size: physical: 512 B
rev: HPS2 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 44.81 GiB size: 44.81 GiB (100.00%)
used: 31.18 GiB (69.6%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 612 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 44.81 GiB size: 44.81 GiB (100.00%)
ID-4: /var/log raw-size: 44.81 GiB size: 44.81 GiB (100.00%)
ID-5: /var/tmp raw-size: 44.81 GiB size: 44.81 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.99 GiB used: 113.5 MiB (0.7%)
ID-2: swap-2 type: partition size: 16.49 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda4 maj-min: 8:4
System Temperatures: cpu: 74.2 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 0
Processes: 323 Uptime: 23m wakeups: 1 Memory: 14.99 GiB
used: 3.81 GiB (25.4%) Init: systemd v: 252 default: graphical
pkgs: 1887 libs: 525 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-08
Last full system update: 2022-11-16 ↻
