Hello,
I’ve got an older laptop (Dell Latitude E6410) that I’ve been trying to get Garuda to work on but when I install Nvidia drivers it doesn’t want to recognize my display properly and shows it as “Unknown-1” in display settings, leaving me unable to change the resolution and overall behaving oddly. I used the Garuda Setup Assistant to install the Nvidia driver. I did try booting with the LTS kernel just to see if it would help, but got the same result as on the zen kernel.
In display settings itself, it shows the monitor as:
Unknown-1 (800x600)
and does not give me much else to work with. I have read through some posts on here and tried using X11 instead of weyland but was met with the same issue.
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=ec6ce11f-676f-4555-8abf-dafcf1ade358 rw rootflags=subvol=@
quiet resume=UUID=abe504db-d289-4422-921d-1d59e5de184e loglevel=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: Dell product: Latitude E6410 v: 0001
Mobo: Dell model: 0K42JR v: A01 serial: <superuser required>
uuid: <superuser required> UEFI: Dell v: A17 date: 05/12/2017
ID-1: BAT0 charge: 73.0 Wh (100.0%) condition: 73.0/84.7 Wh (86.2%)
volts: 12.5 min: 11.2 model: Samsung SDI DELL R289607 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5 M 540 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 2 microcode: 0x11
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2793 min/max: 1199/2534 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2793 2: 2793 3: 2793
4: 2793 bogomips: 20215
Device-1: NVIDIA GT218M [NVS 3100M] vendor: Dell driver: N/A
alternate: nouveau, nvidia_drm, nvidia non-free: series: 340.xx
status: legacy (EOL~2019-12-xx) last: release: 340.108 kernel: 5.4
xorg: 1.20 arch: Tesla process: 40-80nm built: 2006-2013 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.0
chip-ID: 10de:0a6c class-ID: 0300
alternate: fbdev,nv,vesa gpu: N/A display-ID: 0
Monitor-1: Unknown-1 res: 800x600 size: N/A modes: N/A
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast wayland: drv: swrast x11: drv: swrast
API: OpenGL v: 4.5 vendor: mesa v: 24.1.1-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 17.0.6 128 bits)
device-ID: ffffffff:ffffffff memory: 7.56 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: cpu name: llvmpipe
(LLVM 17.0.6 128 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM
17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: Intel 5 Series/3400 Series High Definition Audio
vendor: Dell Latitude E6410 driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:3b56 class-ID: 0403
Device-2: NVIDIA High Definition Audio vendor: Dell
link-max: gen: 2 speed: 5 GT/s bus-ID: 01:00.1 chip-ID: 10de:0be3
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel 82577LM Gigabit Network vendor: Dell Latitude E6410
driver: e1000e v: kernel port: 8040 bus-ID: 00:19.0 chip-ID: 8086:10ea
Device-2: Intel Centrino Advanced-N 6200 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:422c
Local Storage: total: 465.76 GiB used: 13.51 GiB (2.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
speed: 3.0 Gb/s tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-1: / raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
used: 13.51 GiB (3.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-4: /var/log raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
zswap: no
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 7.75 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 74.0 C mobo: N/A sodimm: SODIMM C
Fan Speeds (rpm): cpu: 3813
Memory: total: 8 GiB available: 7.75 GiB used: 1.92 GiB (24.8%)
Processes: 216 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.06 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1314 libs: 376 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date: 2024-06-12
Last full system update: 2024-06-12
