Hello,
Couldn't really find anybody else having the same issue as me, feel free to tell me if i can ask any other place
So often when alt tabbing games my second monitor freezes and I have to either power it on and off
Or change the display configuration in some way, and then I work after for example changing the Hz sometimes it takes multiple tries to get it to work again
Rarely it also happens just on the desktop
I'm running my display via a USB c display port alt mode to HDMI
I tried running it on Windows and there seems to be no issues with the cable
I tried disabling the compositor and my tiling manager but nothing worked
I'm using the prime render offload for the NVIDIA optimus
The monitor that freezes is DP-1-0
xrandr does not change at all when the montior freezes and everything else still thinks the monitor is still there. The game keeps running and i can hear sounds form it
My garuda-inxi
Kernel: 6.2.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=40903308-baba-4d26-8bdb-93fe94bc67a5 rw [email protected]
loglevel=0 mitigations=off sysrq_always_enabled=1 acpi_backlight=native
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Standard product: Standard v: Standard
Mobo: TongFang model: GM5MP7Y v: Standard serial: <superuser required>
UEFI: American Megatrends v: N.1.05 date: 06/10/2020
ID-1: BAT0 charge: 28.9 Wh (100.0%) condition: 28.9/62.3 Wh (46.3%)
volts: 16.2 min: 15.2 model: standard type: Li-ion serial: <filter>
status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Gaming Mouse
serial: <filter> charge: 5% (should be ignored) rechargeable: yes
Info: model: Intel Core i7-10875H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4080 high: 4100 min/max: 800/5100 scaling:
driver: intel_pstate governor: powersave cores: 1: 4100 2: 4100 3: 4100
4: 4100 5: 4028 6: 4062 7: 4097 8: 4021 9: 4054 10: 4033 11: 4100 12: 4100
13: 4100 14: 4100 15: 4100 16: 4100 bogomips: 73598
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Tongfang Hongkong
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh]
vendor: Tongfang Hongkong driver: nvidia v: 525.89.02
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f14 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 2-13:6
chip-ID: 04f2:b68b class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: i965 gpu: i915
Screen-1: 0 s-res: 2560x2520 s-dpi: 96 s-size: 675x665mm (26.57x26.18")
s-diag: 948mm (37.31")
Monitor-1: DP-1-0 pos: top-left res: 2560x1440 dpi: 109
Monitor-2: eDP1 pos: primary,bottom-r res: 1920x1080 hz: 144 dpi: 143
size: 340x190mm (13.39x7.48") diag: 389mm (15.33") modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.0 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Tongfang Hongkong
driver: snd_hda_intel v: kernel bus-ID: 2-12.2:10
alternate: snd_soc_skl,snd_sof_pci_intel_cnl chip-ID: 19f7:0003
class-ID: 0300 bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Tongfang Hongkong
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: RODE Microphones NT-USB type: USB
Sound API: ALSA v: k6.2.8-zen1-1-zen running: yes
vendor: Tongfang Hongkong driver: r8168 v: 8.051.02-NAPI modules: r8169
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0
IF: enp60s0 state: down mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp61s0 state: up mac: <filter>
bus-ID: 2-14:8 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.16 TiB used: 611.61 GiB (51.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S11 Pro size: 953.87 GiB block-size: physical: 512 B
rev: 42AZS6AC temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Micron model: 1100 MTFDDAV256TBN
type: SSD serial: <filter> rev: A020 scheme: GPT
used: 611.58 GiB (64.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:2
used: 28.2 MiB (9.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 62.63 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 82.0 C pch: 60.0 C mobo: N/A
Processes: 429 Uptime: 1h 38m wakeups: 26 Memory: 62.63 GiB
used: 12.34 GiB (19.7%) Init: systemd v: 253 default: graphical
pkgs: 1669 libs: 480 tools: yay Shell: fish v: 3.6.0 running-in: konsole
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2022-11-21
Last full system update: 2023-03-25
Is partially upgraded: Yes
Failed units: [email protected]
xrandr -q
Screen 0: minimum 8 x 8, current 2560 x 2520, maximum 32767 x 32767
eDP1 connected primary 1920x1080+256+1440 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 144.01*+ 72.01
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
DP-1-0 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 598mm x 336mm
2560x1440 59.95 + 144.00* 120.00 99.95 84.98 23.97
1024x768 60.00
800x600 60.32
640x480 59.94
DP-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-3 disconnected (normal left inverted right x axis y axis)
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
DP-1-4 disconnected (normal left inverted right x axis y axis)
Journal log where monitor froze at 18:10:55
mar 25 18:10:16 lucas-standard plasmashell[876313]: Discord ID: None
mar 25 18:10:16 lucas-standard plasmashell[876313]: 2023-03-25 18:10:16,332: Discord RPC Disabled or Discord APP ID Not Present
mar 25 18:10:16 lucas-standard plasmashell[876313]: lutris-wrapper: Contraband Police
mar 25 18:10:16 lucas-standard plasmashell[876313]: Started initial process 907751 from /home/lucas/.local/share/lutris/runners/wine/lutris-GE-Proton7-41-x86_64/bin/wine /home/lucas/Documents/Games/Contraband Police/Contraban>
mar 25 18:10:16 lucas-standard plasmashell[876313]: Start monitoring process.
mar 25 18:10:16 lucas-standard plasmashell[876313]: wineserver: using server-side synchronization.
mar 25 18:10:16 lucas-standard plasmashell[876313]: wine: Using setpriority to control niceness in the [-11,11] range
mar 25 18:10:16 lucas-standard plasmashell[876313]: 2023-03-25 18:10:16,834: The game has run for a very short time, did it crash?
mar 25 18:10:16 lucas-standard plasmashell[876313]: 2023-03-25 18:10:16,851: No file /tmp/lutris-d96c3fb0-4684-4ba9-b01d-d5f2a00b9649
mar 25 18:10:27 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:10:28 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:10:29 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:10:30 lucas-standard plasmashell[876313]: Discord ID: None
mar 25 18:10:30 lucas-standard plasmashell[876313]: 2023-03-25 18:10:30,035: Discord RPC Disabled or Discord APP ID Not Present
mar 25 18:10:30 lucas-standard plasmashell[876313]: lutris-wrapper: Contraband Police
mar 25 18:10:30 lucas-standard plasmashell[876313]: Started initial process 911017 from /home/lucas/.local/share/lutris/runners/wine/lutris-GE-Proton7-41-x86_64/bin/wine /home/lucas/Documents/Games/Contraband Police/Contraban>
mar 25 18:10:30 lucas-standard plasmashell[876313]: Start monitoring process.
mar 25 18:10:30 lucas-standard plasmashell[876313]: wineserver: using server-side synchronization.
mar 25 18:10:30 lucas-standard plasmashell[876313]: wine: Using setpriority to control niceness in the [-11,11] range
mar 25 18:10:32 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:10:33 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:10:38 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:10:52 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:10:53 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:10:53 lucas-standard rtkit-daemon[7484]: Supervising 2 threads of 2 processes of 1 users.
mar 25 18:10:55 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:10:56 lucas-standard rtkit-daemon[7484]: Supervising 2 threads of 2 processes of 1 users.
mar 25 18:11:00 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:11:01 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:11:02 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:11:03 lucas-standard kernel: logitech-djreceiver 0003:046D:C537.0004: Unexpected input report number 128
mar 25 18:11:06 lucas-standard dbus-daemon[735]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.516' (uid=0 pid=917037 comm="sudo journalctl -->
mar 25 18:11:06 lucas-standard dbus-daemon[735]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
mar 25 18:11:06 lucas-standard sudo[917037]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
