Hi,
I have tried everything
- Wayland / Xorg
- lts / zen2 / zen3 kernel
- power tweaks
With the latest Garuda linux I am unable to get this fixed… sadly GNOME Garuda was stable in previous releases
The current GNOME Rani is really unstable and is crashing after every suspend
Could not figure it out and tried other drivers also.
Kindly assist as for now I have started using Manjaro as its causing me stability issues every suspend runs
Kernel: 6.12.43-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=4bea1b79-c244-4003-8684-6fdd6cee9fa8 rw rootflags=subvol=@
quiet resume=UUID=e24441d3-0344-4a7f-b1f8-80a392987c89 loglevel=3 splash
amd_pstate=active
Desktop: GNOME v: 48.4 tk: GTK v: 3.24.50 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 48.0 Distro: Garuda base: Arch Linux
Type: Laptop System: Dell product: Dell G15 5525 v: 1.23.0
serial: <superuser required> Chassis: type: 10 v: 1.23.0
Mobo: Dell model: 03MJW9 v: A01 serial: <superuser required> part-nu: 0B5E
uuid: <superuser required> UEFI: Dell v: 1.23.0 date: 04/16/2025
ID-1: BAT1 charge: 36.6 Wh (89.5%) condition: 40.9/56.0 Wh (73.0%)
volts: 12.2 min: 11.4 model: BYD DELL DVG8M2B type: Li-ion serial: <filter>
status: not charging cycles: 166
Info: model: AMD Ryzen 5 6600H with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA40410A
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/4564 boost: enabled scaling:
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 79081
Device-1: NVIDIA GA107BM [GeForce RTX 3050 Mobile] vendor: Dell
driver: nvidia v: 580.76.05 alternate: nouveau,nvidia_drm
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:25e2 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: Dell driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
DP-7, DP-8, Writeback-1 bus-ID: 05:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 44.0 C
Device-3: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3
chip-ID: 1bcf:2ba8 class-ID: fe01 serial: <filter>
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Najing CEC Panda 0x005f built: 2021 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
drv: nvidia device: 1 drv: radeonsi device: 2 drv: swrast gbm:
drv: kms_swrast surfaceless: drv: nvidia wayland: drv: radeonsi x11:
drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 660M (radeonsi rembrandt
LLVM 20.1.8 DRM 3.61 6.12.43-1-lts) device-ID: 1002:1681 memory: 500 MiB
unified: no display-ID: :0.0
API: Vulkan v: 1.4.321 layers: 8 device: 0 type: integrated-gpu name: AMD
Radeon 660M (RADV REMBRANDT) driver: mesa radv v: 25.2.1-arch1.1
device-ID: 1002:1681 surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 Laptop GPU driver: nvidia v: 580.76.05
device-ID: 10de:25e2 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.1-arch1.1 (LLVM
Info: Tools: api: eglinfo, glxinfo, vulkaninfo gpu: corectrl,
nvidia-settings, nvidia-smi x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GA107 High Definition Audio vendor: Dell
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
[Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Dell
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Dell driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.43-1-lts status: kernel-api tools: N/A
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
Device-1: Foxconn / Hon Hai MediaTek MT7921 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2
chip-ID: 0489:e0c8 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 140.66 GiB (15.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP600 MINI
lanes: 4 tech: SSD serial: <filter> fw-rev: ERFM11.2 temp: 37.9 C
ID-1: / raw-size: 492.5 GiB size: 492.5 GiB (100.00%)
used: 140.66 GiB (28.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 956 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 492.5 GiB size: 492.5 GiB (100.00%)
ID-4: /var/log raw-size: 492.5 GiB size: 492.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 492.5 GiB size: 492.5 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.86 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.34 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 44.0 C mobo: 45.0 C sodimm: 40.0 C gpu: amdgpu
temp: 44.0 C
Fan Speeds (rpm): cpu: 2200 mobo: 2500
Memory: total: 16 GiB note: est. available: 14.86 GiB used: 2.55 GiB (17.2%)
Processes: 423 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle
image: 5.82 GiB services: gsd-power,upowerd Init: systemd v: 257
Packages: pm: pacman pkgs: 2070 libs: 529 tools: octopi,paru Compilers:
clang: 20.1.8 gcc: 15.2.1 alt: 14 Shell: Bash v: 5.3.3 default: fish
v: 4.0.2 running-in: gnome-terminal inxi: 3.3.38
Garuda (2.8.1-2):
System install date: 2025-05-28
Last full system update: 2025-08-23
22/23 checks run in 1.40 seconds ⌛
Powered by garuda-health 🦅
