So i have a weird thing, it started a few days ago, the issue happens like this:
Whenever i have a fullscreen electron app (only testes with discord “vesktop” and chrome/brave) on my second display (4k connected via hdmi) it gets extremly laggy (like if the fps drops), and on primary display (1440p displayport) i get artifacts on open windows on mouse movement (green and black boxes around movement and changes on the area), as soon as exit fullscreen on the second display its gone. This issue happens even after a restart and is consistent. If i open some games (only tested with balatro) the issue does not happen, even if i put it on the second display, and after opening the game the issue seems to be gone (closed the game and it didnt happen o discord for the 5 minutes i kept testing), the issue is back if i restart or log out then back in. the other game i tested was helldivers 2 and when it open was laggy (the steam fps counter was above 180, buit the game felt choppy like it was at 30 or less), changing the kde settings and enablind hdr solved it and the game went back to normal (idk what is happening here), after log out then in and the issue is back.
I have tested both hyprland and kde x11, the issue was only noticeable in kde wayland. trying to measure desktop fps with the kde in built tool made the issue not happen. I tried downgrading, but i only had “recent” snapshots, and they all either didnt work (couldnt get to desktop) or had the issue. Ive tested both monitors on different ports, same issues.
My question is: is my GPU dying? I would guess not, as it is new (not even 6 months) and it doesnt seem to have the issue on other DEs and x11 (at least not that I could notice) and that I`m having a seemingly unrelated issue: google chrome isnt loading pages on kde wayland (it works on other DEs).
video of the artifacts https://www.youtube.com/watch?v=kfscUVkNRJg
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8ae5615f-c6d8-4e31-89de-ac9490bb8ee9 rw rootflags=subvol=@
resume=UUID=357e86cf-c5fb-42d3-9c8d-9dd891f79fd6 loglevel=3 amd_iommu=on
iommu=pt rd.driver.pre=vfio-pci kvm.ignore_msrs=1
pcie_acs_override=downstream,multifunction amdgpu.sg_display=0
clearcpuid=304 ibt=off
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland tools:
avail: swaylock dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7D73 v: 1.0 serial: N/A
Mobo: Micro-Star model: MPG B650I EDGE WIFI (MS-7D73) v: 1.0
serial: <filter> uuid: 49e6398a-67a4-5a16-afc1-047c16bb5ba3 UEFI: American
Megatrends LLC. v: 1.20 date: 03/24/2023
Device-1: hidpp_battery_8 model: Logitech G502 X LIGHTSPEED serial: <filter>
charge: 86% rechargeable: yes status: discharging
Info: model: AMD Ryzen 7 7700X socket: AM5 bits: 64 type: MT MCP arch: Zen 4
gen: 5 level: v3 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA601203
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2565 high: 5360 min/max: 400/5573 base/boost: 4500/5550
scaling: driver: amd-pstate-epp governor: performance volts: 1.3 V
ext-clock: 100 MHz cores: 1: 5336 2: 400 3: 5349 4: 400 5: 400 6: 5360
7: 400 8: 400 9: 400 10: 5350 11: 5349 12: 400 13: 5349 14: 400 15: 400
16: 5350 bogomips: 144008
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Sapphire PULSE driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1,Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael vendor: Micro-Star MSI driver: vfio-pci v: N/A
alternate: amdgpu arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 13:00.0
chip-ID: 1002:164e class-ID: 0300
Display: server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 7680x2160 s-dpi: 96 s-size: 2032x572mm (80.00x22.52")
s-diag: 2111mm (83.11")
Monitor-1: DP-2 pos: primary,right model: LG (GoldStar) ULTRAGEAR
serial: <filter> built: 2023 res: 3840x2160 hz: 165 dpi: 139 gamma: 1.2
size: 700x390mm (27.56x15.35") diag: 800mm (31.5") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
Monitor-2: HDMI-A-2 pos: left model: Samsung U32J59x serial: <filter>
built: 2018 res: 3840x2160 hz: 60 dpi: 139 gamma: 1.2
max: 3840x2160 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
navi31 LLVM 17.0.6 DRM 3.57 6.8.7-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-2: AMD Rembrandt Radeon High Definition Audio
speed: 16 GT/s lanes: 16 bus-ID: 13:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 13:00.6 chip-ID: 1022:15e3
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-10:5
chip-ID: 0db0:36e7 class-ID: 0300
Device-5: SteelSeries ApS Arctis Nova Pro Wireless
lanes: 1 mode: 1.1 bus-ID: 1-5:2 chip-ID: 1038:12e0 class-ID: 0300
Device-6: Kingston HyperX QuadCast
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 0951:16df class-ID: 0300
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: n/a (root, process) with:
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:6 chip-ID: 0e8d:0616
Local Storage: total: 3.64 TiB used: 1.69 TiB (46.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 33.9 C
SMART: yes health: PASSED on: 104d 15h cycles: 330
read-units: 18,507,430 [9.47 TB] written-units: 12,371,952 [6.33 TB]
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Kingston model: SNV2S2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 41.9 C
SMART: yes health: PASSED on: 104d 11h cycles: 330
read-units: 20,363,219 [10.4 TB] written-units: 11,155,369 [5.71 TB]
ID-1: / raw-size: 1.75 TiB size: 3.57 TiB (203.81%) used: 1.69 TiB (47.4%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
used: 25.9 MiB (8.6%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 1.75 TiB size: 3.57 TiB (203.81%)
used: 1.69 TiB (47.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 1.75 TiB size: 3.57 TiB (203.81%)
maj-min: 259:2
ID-5: /var/tmp raw-size: 1.75 TiB size: 3.57 TiB (203.81%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 61.96 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 68.16 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 48.1 C mobo: 36.0 C gpu: amdgpu temp: 56.0 C
mem: 64.0 C
Memory: total: 64 GiB note: est. available: 61.96 GiB used: 7.2 GiB (11.6%)
Processes: 386 Power: uptime: 54m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.76 GiB services: org_kde_powerdevil,
Packages: 2419 pm: pacman pkgs: 2390 libs: 587 tools: octopi,paru
pm: flatpak pkgs: 29 Compilers: clang: 17.0.6 gcc: 13.2.1
Shell: garuda-inxi (sudo) default: Bash v: 5.2.26 running-in: alacritty
inxi: 3.3.34
System install date: 2023-08-15
Last full system update: 2024-04-20
Is partially upgraded: Yes
Windows dual boot: Yes
If theres anything else i can provide/test please inform me.
