same problem facing ![]()
itās a bug???
https://bugs.debian.org/cgi-bin/pkgreport.cgi?pkg=kwin-x11;dist=unstable
My first thought would be to disable anything that puts demands on the compositor. Disable the KDE visual effects in KDEās system settings to see if that helps.
You might also want to try disabling any plasmoids you have installed.
but in my case the settings manager is crashedā¦its open with black screen
this is my garuda inxiā¦
ā°āĪ» garuda-inxi
Kernel: 5.15.84-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=bf08036d-22f5-4042-836f-34387c2571c4 rw rootflags=subvol=@
resume=UUID=36ca17a6-c461-4bb5-b067-65ca87b9600c loglevel=3 ibt=off
Type: Desktop System: Gigabyte product: H110M-S2 v: N/A
Mobo: Gigabyte model: H110M-S2-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F21 date: 06/09/2017
Info: model: Intel Core i3-6100 bits: 64 type: MT MCP arch: Skylake-S
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 29598
vulnerable
prctl and seccomp
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GT218 [GeForce G210] driver: nouveau v: kernel non-free:
series: 340.xx status: legacy (EOL) last: release: 340.108 kernel: 5.4
xorg: 1.20 arch: Tesla process: 40-80nm built: 2006-13 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 ports: active: VGA-1 empty: DVI-I-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:0a60 class-ID: 0300 temp: 37.0 C
compositor: kwin_x11 driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: :0
s-diag: 414mm (16.31")
Monitor-1: VGA-1 model: LG (GoldStar) HD serial: <filter> built: 2017
res: 1366x768 hz: 60 dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06")
diag: 470mm (18.5") ratio: 16:9 modes: max: 1366x768 min: 720x400
API: OpenGL v: 3.3 Mesa 22.3.1 renderer: NVA8 direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
Device-2: NVIDIA High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0be3
Sound API: ALSA v: k5.15.84-1-lts running: yes
Local Storage: total: 1.58 TiB used: 34.44 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
type: SSD serial: <filter> rev: 056 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3500413AS
type: HDD rpm: 7200 serial: <filter> rev: JC4B scheme: GPT
model: WD10EZEX-60WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-1: / raw-size: 64.52 GiB size: 64.52 GiB (100.00%)
used: 16.38 GiB (25.4%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 125.51 GiB size: 125.51 GiB (100.00%)
used: 18.06 GiB (14.4%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 64.52 GiB size: 64.52 GiB (100.00%)
ID-5: /var/tmp raw-size: 64.52 GiB size: 64.52 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
ID-2: swap-2 type: zram size: 7.71 GiB used: 93 MiB (1.2%) priority: 100
System Temperatures: cpu: 34.0 C mobo: N/A gpu: nouveau temp: 37.0 C
Processes: 249 Uptime: 49m wakeups: 0 Memory: 7.71 GiB
used: 3.89 GiB (50.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1583
libs: 374 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.12-1):
System install date: 2022-11-15
Last full system update: 2022-12-21
Failed units: dev-binderfs.mount systemd-networkd-wait-online.service
kwin -replase couldnot work
but i canāt understand why my kde system settings couldnot opening?
is there any other way?
