i have tried every possible method that i found on internet and it didnt worked
i have intel i7 intel core cpu and a nvidia 4090 rtx gpu
im new to it, so i added garuda in my computer by
1)booting live usb
2)choosing drive D as partition to replace with size of 543gb
3)installed
4)in bios set hard drive to garuda instead of windows 11 boot manager
have you tried installing Garuda in open source instead of nvidia drivers? i got a 4080 and at time have been forced to do that.
Have you tried an older version of the Garuda iso than June 25? Such may also make a difference.
If you are successful with the non nvidia drivers answer yes to install the nvidia drivers after first run update watching the installation of the nvidia dkms modules. If they compile rightly all is well if not try the code below uninstalling any conflicting packages, and reinstalling them after a successful install of the nvidia drivers.
if that does not work i have final code that might help and this is using the nvidia-all drivers. The developers do not like them, but in the past they have rescued me often.
Owning a nvidia graphic card can be a real challenge at times.
Best of luck
EDIT:
Oh i saw no garuda-inxi! So i do not know if your bios is up to date. However i had to update my bios to get the installer to recognise my graphic card correctly, it may benefit you as well.
Once you have plasma-x11-session installed you can to login with an X11 session rather than Wayland. Look at the bottom left of the login screen, you can alter your session type there. Hopefully using X11 will correct your problem.
