Hi all,
I’ve been experiencing issues with kwin_wayland on my setup, particularly when using an external monitor. Here are the details of my hardware and setup:
Hardware:
- Laptop: ASUS TUF A15 FA506QR (16GB RAM)
- CPU: AMD Ryzen 7 5800H
- GPU1: AMD Radeon Vega Series / Radeon Vega Mobile
- GPU2: NVIDIA GeForce RTX 3070 Mobile
- External Monitor: LG UltraGear 2K 180Hz (connected via dock directly to the NVIDIA GPU)
Problem Description: The issue started about two months ago when I first started using the external monitor. Initially, the system would terminate the kwin_wayland process, which I confirmed by checking dmesg logs (I unfortunately don’t have those logs saved).
Over time, the problem evolved/changed completely: instead of terminating the process, the system became progressively more laggy until everything froze completely. Unplugging the external monitor did not resolve the freeze and a force reboot through the power key is required.
I’ve tried to connect the monitor to the laptop through the HDMI port which is not directly connected to the NVIDIA GPU, but goes through the internal one. Again I get into the same exact situation.
For the past couple of days I’ve been using this env variable that is supposed to help with this problem:
#!/usr/bin/sh
export KWIN_DRM_FORCE_MGPU_GL_FINISH=1
According to KDE wiki (Environment Variables · Wiki · Plasma / KWin · GitLab) I’ve putted the script above here: ~/.config/plasma-workspace/env/
Note: This happens over time it can be in the short span of an hour or the long span of up to four hours.
garunda-inxi:
Kernel: 6.12.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=db2baf1a-01a3-4311-9428-cb6b675205c4 rw rootflags=subvol=@
quiet resume=UUID=4a23e327-ae59-4ccd-ab3b-4db8caad9ba4 loglevel=3
nvidia_drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.9.0
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506QR v: 1.0
Mobo: ASUSTeK model: FA506QR v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FA506QR.415
date: 01/07/2023
ID-1: BAT1 charge: 60.2 Wh (100.0%) condition: 60.2/90.2 Wh (66.7%)
volts: 16.4 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
^[[FCPU:
microcode: 0xA500011
Speed (MHz): avg: 1100 min/max: 400/4463 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1100 2: 1100 3: 1100
4: 1100 5: 1100 6: 1100 7: 1100 8: 1100 9: 1100 10: 1100 11: 1100 12: 1100
13: 1100 14: 1100 15: 1100 16: 1100 bogomips: 102206
Device-1: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 565.77 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-1 empty: none bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 06:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 57.0 C
Device-3: Microdia PC-LM1E driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:6
chip-ID: 0c45:636d class-ID: 0102 serial: <filter>
Device-4: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:10
chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
gpu: nvidia,amdgpu d-rect: 3584x1152 display-ID: 0
Monitor-1: DP-1 pos: right res: 2048x1152 size: N/A modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1536x864 size: N/A modes: N/A
drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: radeonsi
x11: drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: amd mesa v: 24.3.3-arch1.1
renoir LLVM 18.1.8 DRM 3.59 6.12.8-zen1-1-zen) device-ID: 1002:1638
API: Vulkan v: 1.4.303 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Laptop GPU driver: N/A device-ID: 10de:249d
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6
Device-5: Microdia PC-LM1E driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.12.8-zen1-1-zen status: kernel-api tools: N/A
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.1:8
IF: enp6s0f3u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0029
Local Storage: total: 2.33 TiB used: 1.29 TiB (55.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM790 2TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 11296 temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: SK Hynix model: HFM512GD3JX013N
lanes: 4 tech: SSD serial: <filter> fw-rev: 41000C20 temp: 36.9 C
ID-1: / raw-size: 1.85 TiB size: 1.85 TiB (100.00%) used: 1.29 TiB (70.0%)
ID-3: /home raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
used: 1.29 TiB (70.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.85 TiB size: 1.85 TiB (100.00%)
ID-1: swap-1 type: zram size: 15.02 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.53 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 75.0 C mobo: N/A gpu: amdgpu temp: 61.0 C
Memory: total: 16 GiB note: est. available: 15.02 GiB used: 3.88 GiB (25.8%)
Processes: 419 Power: uptime: 0m states: freeze,mem,disk suspend: s2idle
image: 5.96 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 1633 libs: 477 tools: octopi,paru Compilers:
gcc: 14.2.1 alt: 13 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-09-11
Last full system update: 2025-01-07
╭─wh1t3_r4v3n@nothingness in ~ took 2s
╰─λ
