Hello Garuda!
Before saying anything, I'll do the traditional dump of my inxi -Faz as shown below:
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f6f45d85-b66c-48c7-ae2e-becddd3d4d46
rw rootflags=subvol=@ splash amd_iommu=on rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1407 date: 04/02/2020
CPU: Info: 16-Core (2-Die) model: AMD Ryzen 9 3950X bits: 64 type: MT MCP MCM arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 230395
Speed: 3601 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 3601 2: 3599
3: 3620 4: 3595 5: 3602 6: 3600 7: 3612 8: 3599 9: 3602 10: 3615 11: 3625 12: 3611 13: 3599
14: 3593 15: 3598 16: 3614 17: 3607 18: 3617 19: 3608 20: 3624 21: 3599 22: 3599 23: 3599
24: 3594 25: 3602 26: 3599 27: 3601 28: 3592 29: 3598 30: 3603 31: 3600 32: 3612
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: eVga.com. driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 08:00.0 chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9") s-diag: 610mm (24")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 92 size: 531x299mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce GTX 970/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74 direct render: Yes
Audio: Device-1: NVIDIA GM204 High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel
bus-ID: 08:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS SteelSeries Arctis 5 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:2 chip-ID: 1038:12aa class-ID: 0300
Device-4: Licensed by Sony Entertainment America Rocksmith Guitar Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2:2 chip-ID: 12ba:00ff class-ID: 0300
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: f000
bus-ID: 04:00.0 chip-ID: 8086:1539 class-ID: 0200
Drives: Local Storage: total: 5.91 TiB used: 3.38 TiB (57.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 2B2QEXM7 temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q
scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST6000VN0033-2EE110 size: 5.46 TiB
serial: <filter> rev: SC60 scheme: GPT
Partition: ID-1: / raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 33.5 GiB (14.4%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 33.5 GiB (14.4%) fs: btrfs
ID-4: /var/log raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 33.5 GiB (14.4%) fs: btrfs
ID-5: /var/tmp raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 33.5 GiB (14.4%) fs: btrfs
ID-1: swap-1 type: zram size: 31.27 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 56.9 C mobo: N/A gpu: nvidia temp: 63 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 9%
Info: Processes: 520 Uptime: 11h 34m wakeups: 0 Memory: 31.27 GiB used: 4.95 GiB (15.8%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1220 lib: 303
Now, cutting to the chase.
I am new to Garuda and have a little bit of Linux experience but I'm not crusty at it. I'm running Garuda now as my main operating system and I quite like it but wanted to do some virtualized gaming, so I decided to follow the guide of my favorite "fat indian" of the internet as he refers to himself SomeOrdinaryGamers. Mutahar went through the process in the video here:
Mutahar's GPU Passthrough/Hijacking Tutorial
I went through the process and did everything needed but now I've hit a bit of a snag. Near the middle bit before I decide to muck about with the VM the scripts required to hijack the GPU seem to be working a little bit funky in comparison to what he's got there, though he does state that it's to your taste pertaining to which distro you're using. I've narrowed down that the service that I'm supposed to yank is sddm-plymouth.service with by writing in the shell script: "systemctl stop sddm-plymouth.service", where as in his script he's just got the basic sddm.service he yanks.
The problem I'm facing is when I go ahead and stop the plymouth service and proceed with the script, it hangs with the messages:
:: running early hook [udev]
:: running early hook [plymouth]
I have to then force reboot but the screen doesn't go black like I'm expecting it to. Especially when running the VM for ■■■■■■■, it's not passing through my GPU and instead just hanging on this screen and nothing else on it. To put in context what the script is doing so nobody has to go sifting through the video to see what I've followed, here are the two scripts I've got copied over:
start.sh
# debugging
set -x
# load variables we defined
source "/etc/libvirt/hooks/kvm.conf"
# stop display manager
# unbind vtconsoles
echo 0 > /sys/class/vtconsole/vtcon0/bind
# unbind EFI-Framebuffer
echo efi-framebuffer.0 > /sys/bus/platform/drivers/efi-framebuffer/unbind
# avoid race condition - can be whatever above 5
sleep 10
# unload nvidia drivers
modprobe -r nvidia_drm
modprobe -r nvidia_modeset
modprobe -r drm_kms_helper
modprobe -r nvidia
modprobe -r ic2_nvidia_gpu
modprobe -r drm
modprobe -r nvidia_uvm
# unbind gpu
virsh nodedev-detach $VIRSH_GPU_VIDEO
virsh nodedev-detach $VIRSH_GPU_AUDIO
# load vfio
modprobe vfio
modprobe vfio_pci
modprobe vfio_iommu_type1
revert.sh
# debugging
set -x
# unload vfio-pci
modprobe -r vfio_pci
modprobe -r vfio_iommu_type1
modprobe -r vfio
# rebind gpu
virsh nodedev-reattach $VIRSH_GPU_VIDEO
virsh nodedev-reattach $VIRSH_GPU_AUDIO
# rebind vtconsoles
echo 1 > /sys/class/vtconsole/vtcon0/bind
# read nvidia x config
nvidia-xconfig --query-gpu-info > /dev/null 2>&1
# bind efi-framebuffer
echo "efi-framebuffer.0" > /sys/bus/platform/drivers/efi-framebuffer/bind
# load nvidia
modprobe nvidia_drm
modprobe nvidia_modeset
modprobe drm_kms_helper
modprobe nvidia
modprobe drm
modprobe nvidia_uvm
# restart display service
systemctl start sddm-plymouth.service
The kvm.conf file referenced is just simply:
VIRSH_GPU_VIDEO=pci_0000_08_00_0
VIRSH_GPU_AUDIO=pci_0000_08_00_1
I then use a patched gpu rom in the further movement through setting of this up, but I haven't gotten to get to that stage yet due to this snag seemingly getting in the way.
I imagine this is a bit beyond the scope of what people might offer but I thought I'd try and see if there might be anyone who knows what I'm doing wrong here and can help. If not, no worries, I'll just figure something else out, but so far it's been fun tinkering.
Thanks for the read!
