Hi y’all, i’am having problem updating
update -a
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur 2,6 MiB 3,63 MiB/s 00:01 [--------------------------------] 100%
blackarch is up to date
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
blackarch downloading...
:: Replace baloo with extra/baloo5? [Y/n] y
warning: greetd-qtgreet: local (1.0.0-4.1) is newer than chaotic-aur (1.0.0-4)
:: Replace kactivities with extra/kactivities5? [Y/n] y
:: Replace kbookmarks with extra/kbookmarks5? [Y/n] y
:: Replace kcmutils with extra/kcmutils5? [Y/n] y
:: Replace kdeclarative with extra/kdeclarative5? [Y/n] y
:: Replace kded with extra/kded5? [Y/n] y
:: Replace kdesu with extra/kdesu5? [Y/n] y
:: Replace kdnssd with extra/kdnssd5? [Y/n] y
:: Replace kfilemetadata with extra/kfilemetadata5? [Y/n] y
:: Replace kglobalaccel with extra/kglobalaccel5? [Y/n] y
:: Replace kiconthemes with extra/kiconthemes5? [Y/n] y
:: Replace kidletime with extra/kidletime5? [Y/n] y
:: Replace kio with extra/kio5? [Y/n] y
:: Replace kitemmodels with extra/kitemmodels5? [Y/n] y
:: Replace kitemviews with extra/kitemviews5? [Y/n] y
:: Replace kjobwidgets with extra/kjobwidgets5? [Y/n] y
:: Replace knewstuff with extra/knewstuff5? [Y/n] y
:: Replace knotifications with extra/knotifications5? [Y/n] y
:: Replace knotifyconfig with extra/knotifyconfig5? [Y/n] y
:: Replace kpackage with extra/kpackage5? [Y/n] y
:: Replace kparts with extra/kparts5? [Y/n] y
:: Replace kpty with extra/kpty5? [Y/n] y
:: Replace kquickcharts with extra/kquickcharts5? [Y/n] y
:: Replace kservice with extra/kservice5? [Y/n] y
:: Replace ktextwidgets with extra/ktextwidgets5? [Y/n] y
:: Replace kwallet with extra/kwallet5? [Y/n] y
:: Replace kxmlgui with extra/kxmlgui5? [Y/n] y
:: Replace purpose with extra/purpose5? [Y/n] y
:: Replace qqc2-desktop-style with extra/qqc2-desktop-style5? [Y/n] y
:: Replace solid with extra/solid5? [Y/n] y
:: Replace sonnet with extra/sonnet5? [Y/n] y
:: Replace syndication with extra/syndication5? [Y/n] y
:: Replace syntax-highlighting with extra/syntax-highlighting5? [Y/n] y
resolving dependencies...
:: libgedit-amtk and amtk are in conflict. Remove amtk? [y/N] y
:: installing kvantum (1.0.10-2) breaks dependency 'kvantum-qt5' required by wayfire-desktop
inxi below
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=62bf35b1-a655-4f1a-ba2d-7d69f04d231d rw rootflags=subvol=@
Desktop: wayfire v: 0.7.5 info: waybar vt: 1 dm: greetd
Type: Desktop Mobo: Micro-Star model: PRO B650-P WIFI (MS-7D78) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.40
date: 03/24/2023
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1945 high: 5350 min/max: 400/5573 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 400 2: 400 3: 400
4: 5349 5: 400 6: 400 7: 5349 8: 400 9: 5349 10: 5350 11: 400 12: 400
13: 400 14: 400 15: 400 16: 5331 bogomips: 144004
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: Sapphire NITRO+
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: HDMI-A-1,HDMI-A-2 empty: DP-1,DP-2 bus-ID: 03:00.0
chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael vendor: Micro-Star MSI driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-3, DP-4,
DP-5, HDMI-A-3 bus-ID: 12:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 39.0 C
compositor: wayfire v: 0.7.5 driver: gpu: amdgpu display-ID: 1
Monitor-1: HDMI-A-1 model: Dell U2410 serial: <filter> built: 2010
res: 1920x1200 dpi: 94 gamma: 1.2 size: 518x324mm (20.39x12.76")
diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200 min: 720x400
Monitor-2: HDMI-A-2 model: Lenovo LEN D24f-10 serial: <filter> built: 2019
res: 1920x1080 dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54")
diag: 598mm (23.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi inactive: wayland,x11
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 23.1.8-arch1.1
note: incomplete (EGL sourced) renderer: llvmpipe (LLVM 16.0.6 256 bits),
AMD Radeon Graphics (raphael_mendocino LLVM 16.0.6 DRM 3.54
6.5.5-zen1-1-zen), AMD Radeon RX 7900 XTX (gfx1100 LLVM 16.0.6 DRM 3.54
6.5.5-zen1-1-zen)
Device-2: AMD Rembrandt Radeon High Definition Audio
speed: 16 GT/s lanes: 16 bus-ID: 12:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: HP HyperX QuadCast S driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5.4.4:7
chip-ID: 03f0:0d8b class-ID: 0300 serial: <filter>
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: active (process) with:
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0bda:8771
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Device-2: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:6 chip-ID: 0e8d:0616
Report: ID: hci1 rfk-id: 1 state: up address: <filter> bt-v: 5.2 lmp-v: 11
Local Storage: total: 1.82 TiB used: 736.88 GiB (39.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 34.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 736.88 GiB (39.6%)
used: 736.88 GiB (39.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.51 GiB used: 67.2 MiB (0.2%)
System Temperatures: cpu: 45.8 C mobo: N/A
GPU: device: amdgpu temp: 40.0 C mem: 51.0 C fan: 0 watts: 17.00
device: amdgpu temp: 38.0 C
Processes: 419 Uptime: 1h 26m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.51 GiB used: 7.88 GiB (25.8%) Init: systemd v: 254
Packages: 1582 pm: pacman pkgs: 1573 libs: 489 tools: pamac,paru pm: flatpak
pkgs: 9 Shell: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.30
System install date: 2023-08-03
Last full system update: 2023-09-30
