kscreensaver causes system to lock up and crash forcing a hard powerdown. it also causes input/output error on several files on the ssd. when i apply a slideshow to the lock screen after several hours the machine stops responding and when i try to log back in then screen is still black.
There was a template for posting here, you should have read it
Please post your garuda-inxi
in code brackets, like this:
output ofgaruda-inxi
Kernel: 6.10.3-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=293fe8be-aa57-4da8-88c5-66790f403995 rw rootflags=subvol=@
net.ifnames=0 biosdevname=0 nvidia_drm.fbdev=1 nvidia-drm.modeset=1
resume=UUID=37597b3a-ebd2-4a0f-8395-3aecddd3a440 net.ifnames=0
biosdevname=0 nvidia_drm.fbdev=1 nvidia-drm.modeset=1 ibt=off
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.4.0
wm: kwin_wayland with: krunner vt: 1 dm: 1: LightDM v: 1.32.0 note: stopped
2: SDDM Distro: Garuda base: Arch Linux
Type: Desktop System: LENOVO product: 30A6S0MW00 v: ThinkStation P500
Mobo: LENOVO model: 102F v: SDK0E50510 WIN 2625087105949
part-nu: LENOVO_MT_30A6_BU_Think_FM_ThinkStation P500
uuid: <superuser required> UEFI: LENOVO v: A4KTACAUS date: 10/30/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse PID:0038
serial: N/A charge: 55% (should be ignored) rechargeable: yes
Device-2: hidpp_battery_1 model: Logitech ERGO M575 Trackball
serial: <filter> charge: 100% rechargeable: yes status: discharging
Device-3: ps-controller-battery-90:89:5f:3b:59:3f model: N/A serial: N/A
charge: N/A status: full
Info: model: Intel Xeon E5-2620 v3 bits: 64 type: MT MCP arch: Haswell
level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
model-id: 0x3F (63) stepping: 2 microcode: 0x49
L3: 15 MiB desc: 1x15 MiB
Speed (MHz): avg: 1340 high: 1794 min/max: 1200/3200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1197 2: 1589 3: 1197
4: 1200 5: 1617 6: 1200 7: 1197 8: 1200 9: 1197 10: 1200 11: 1794 12: 1498
bogomips: 57464
Device-1: NVIDIA GM206GL [Quadro M2000] vendor: Dell driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-1,DP-3,DP-4 empty: DP-2 bus-ID: 03:00.0
chip-ID: 10de:1430 class-ID: 0300
Device-2: Logitech Logi Webcam C920e driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-9:6 chip-ID: 046d:08b6
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia
d-rect: 7680x1440 display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 2560x1440 size: N/A modes: N/A
Monitor-2: DP-3 pos: right res: 2560x1440 size: N/A modes: N/A
Monitor-3: DP-4 pos: center res: 2560x1440 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: Quadro M2000/PCIe/SSE2
memory: 3.91 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu
name: Quadro M2000 driver: nvidia v: 555.58.02 device-ID: 10de:1430
18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.5-arch1.1 (LLVM 18.1.8)
Device-1: NVIDIA GM206 High Definition Audio vendor: Dell
bus-ID: 03:00.1 chip-ID: 10de:0fba class-ID: 0403
Device-2: Logitech Yeti Orb driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-13:8
chip-ID: 046d:0ad5 class-ID: 0300 serial: <filter>
Device-3: Sony DualShock 4 [CUH-ZCT2x]
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 7-1.4.4:7 chip-ID: 054c:09cc class-ID: 0300
API: ALSA v: k6.10.3-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.2 status: active with: 1: wireplumber
status: active 2: pw-jack type: plugin tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Emulex OneConnect NIC vendor: Hewlett-Packard StoreFabric CN1200E
10Gb Converged driver: be2net v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 port: N/A bus-ID: 04:00.0 chip-ID: 10df:0720 class-ID: 0200
temp: 48.0 C
IF: eth0 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-2: Emulex OneConnect NIC vendor: Hewlett-Packard StoreFabric
CN1200E 10Gb Converged driver: be2net v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 port: N/A bus-ID: 04:00.1 chip-ID: 10df:0720 class-ID: 0200
IF: eth1 state: down mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
lmp-v: 6 sub-v: 22bb hci-v: 6 rev: 22bb class-ID: 7c0104
Info: acl-mtu: 310:10 sco-mtu: 64:8 link-policy: rswitch hold sniff park
link-mode: peripheral accept service-classes: rendering, capturing, object
transfer, audio, telephony
Local Storage: total: 1.86 TiB used: 392.48 GiB (20.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Patriot model: P220 2048GB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 825 scheme: GPT
ID-1: / raw-size: 1.83 TiB size: 1.83 TiB (100.00%) used: 392.48 GiB (21.0%)
ID-3: /home raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
used: 392.48 GiB (21.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
ID-1: swap-1 type: zram size: 31.2 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 48.0 C pch: 49.5 C mobo: N/A
Memory: total: 32 GiB available: 31.2 GiB used: 9.56 GiB (30.6%)
Processes: 412 Power: uptime: 3h 4m states: freeze,mem,disk suspend: deep
Packages: 2501 pm: pacman pkgs: 2495 libs: 653 tools: octopi,paru,yay
pm: flatpak pkgs: 6 Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 12
Shell: garuda-inxi default: Bash v: 5.2.32 running-in: lxterminal
inxi: 3.3.35
System install date: 2024-03-24
Last full system update: 2024-08-10 ↻
Try
On KDE it’s often needed to reboot after updates, ↻.
