fcinq
11 August 2021 14:51
1
Hi all,
First of all, thank's very mutch for this fantastic distribution!
I got a problem, my krunner are at the wrong place after update/reboot the system. But i have notice if i killall latte-dock the krunner are at the good place. If i re lauch latte-dock, krunner go at the bad place.
Sorry for my bad english, hope i can find some help.
My inxi -Fza : PrivateBin
The krunner at the wrong place : https://i.imgur.com/9rAYQ5t.png
Best regards.
SGS
11 August 2021 15:23
2
Welcome
1st world problem
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2") s-diag: 1055mm (41.5")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 96 size: 510x287mm (20.1x11.3") diag: 585mm (23")
Monitor-2: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 96 size: 510x287mm (20.1x11.3") diag: 585mm (23")
What happen if you use one monitor?
Best you open an issue on KDE, it works before update, so it seems a bug if you can't change krunner settings.
fcinq
11 August 2021 15:26
3
Krunner are working with 1 screen at the good place
What i am suppose to do ? ^^
SGS
11 August 2021 15:33
4
fcinq
11 August 2021 15:39
5
I can force change the setting like this : https://i.imgur.com/AQaRC6y.png
But how i can have the exact middle of my screen ? 1920/2 ?
SGS
11 August 2021 15:43
6
I use one monitor and 95% i3wm, in KDE I never use krunner.
Let's wait and see if an experienced KDE user comes forward.
(1920 / 2) - ([width of krunner] / 2)
Bro
12 August 2021 00:51
8
Kruler. Use it to measure your screen.
fcinq
12 August 2021 17:15
9
Thank's a lot, i whas able to fix my trouble with Kruler
system
Closed
14 August 2021 17:16
10
