Hello, I've been trying to get Korean input to work, but so far I haven't been able to. I've tried to follow the IBUS instruction and edited my environments and bashrc as well, but to no avail.
I also just timeshifted back to before I began fiddling around so everything should be clean (I reset the bashrc back manually).
Has anyone been able to get Korean input to work on garuda yet? I've seen other posts but no solutions.
System: Kernel: 5.13.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=829aefe3-eba5-4752-b123-36813328608c
systemd.unified_cgroup_hierarchy=1 resume=UUID=13b83040-af69-419b-832d-d7e7080c3730 loglevel=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: Inspiron 5584 v: N/A serial: <filter> Chassis: type: 10
Mobo: Dell model: 03D64V v: A00 serial: <filter> UEFI: Dell v: 1.4.1 date: 04/12/2019
Battery: ID-1: BAT0 charge: 26.5 Wh (100.0%) condition: 26.5/42.0 Wh (63.1%) volts: 13.0 min: 11.4
model: Samsung SDI DELL CYMGM8C type: Li-ion serial: <filter> status: Full
Device-1: hid-dc:2c:26:d6:45:de-battery model: K1-keyboard serial: N/A charge: N/A status: N/A
CPU: Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: B (11) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
6: 800 7: 800 8: 800
Graphics: Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 0c45:671f class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:9dc8
Sound Server-1: ALSA v: k5.13.12-zen1-1-zen running: yes
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell
driver: ath10k_pci v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
IF-ID-1: moz0 state: unknown speed: N/A duplex: N/A mac: N/A
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 0cf3:e009
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4060
bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Device-1: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 2944 chunk-size: N/A
Components: Online: N/A Spare:
0: nvme1n1 maj-min: 259:4 size: 13.41 GiB state: S
Drives: Local Storage: total: 251.89 GiB used: 28.64 GiB (11.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: H10 HBRPEKNX0101A NVMe 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 7002 temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Intel model: H10 HBRPEKNX0101AO NVMe 16GB
size: 13.41 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 7050 temp: 36.9 C
Partition: ID-1: / raw-size: 225.49 GiB size: 225.49 GiB (100.00%) used: 28.64 GiB (12.7%) fs: btrfs
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 225.49 GiB size: 225.49 GiB (100.00%) used: 28.64 GiB (12.7%) fs: btrfs
ID-4: /var/log raw-size: 225.49 GiB size: 225.49 GiB (100.00%) used: 28.64 GiB (12.7%)
ID-5: /var/tmp raw-size: 225.49 GiB size: 225.49 GiB (100.00%) used: 28.64 GiB (12.7%)
ID-1: swap-1 type: partition size: 12.72 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 11.56 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 49.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2700
Info: Processes: 268 Uptime: 4m wakeups: 2 Memory: 11.57 GiB used: 2.66 GiB (23.0%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1371 lib: 432
Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.06
