After the last update and the reboot does not open Konsole. When trying to open Konsole via Alacrity I get the following:
Icon theme "adwaita" not found.
Icon theme "ubuntu-mono" not found.
Icon theme "yaru" not found.
Icon theme "Mint-X" not found.
Icon theme "elementary" not found.
KCrash: crashing... crashRecursionCounter = 2
KCrash: Application Name = konsole path = /usr/bin pid = 189355
KCrash: Arguments: /usr/bin/konsole
KCrash: Attempting to start /usr/lib/drkonqi
zsh: suspended (signal) konsole
I tried to reinstall Konsole, but it did not help. Here is the output of the challenge of the challenges Dr Konqi:
[KCrash Handler]
#4 0x00007fcbd970ef21 in QWindow::winId() const () from /usr/lib/libQt5Gui.so.5
#5 0x00007fcbd8995e32 in KWindowEffects::enableBlurBehind(QWindow*, bool, QRegion const&) () from /usr/lib/libKF5WindowSystem.so.5
#6 0x00007fcbda66fde7 in Konsole::MainWindow::setBlur(bool) () from /usr/lib/libkonsoleapp.so.21
#7 0x00007fcbda67355c in Konsole::MainWindow::activeViewChanged(Konsole::SessionController*) () from /usr/lib/libkonsoleapp.so.21
#8 0x00007fcbd92b575b in ?? () from /usr/lib/libQt5Core.so.5
#9 0x00007fcbda50e243 in Konsole::ViewManager::activeViewChanged(Konsole::SessionController*) () from /usr/lib/libkonsoleprivate.so.21
#10 0x00007fcbda5389dd in Konsole::ViewManager::createController(Konsole::Session*, Konsole::TerminalDisplay*) () from /usr/lib/libkonsoleprivate.so.21
#11 0x00007fcbda5390ce in Konsole::ViewManager::createView(Konsole::Session*) () from /usr/lib/libkonsoleprivate.so.21
#12 0x00007fcbda673d53 in Konsole::MainWindow::createSession(QExplicitlySharedDataPointer<Konsole::Profile>, QString const&) () from /usr/lib/libkonsoleapp.so.21
#13 0x00007fcbda66f0d7 in Konsole::Application::newInstance() () from /usr/lib/libkonsoleapp.so.21
#14 0x000056415c7586fe in ?? ()
#15 0x00007fcbd8c0ab25 in __libc_start_main () from /usr/lib/libc.so.6
#16 0x000056415c7589de in ?? ()
[Inferior 1 (process 231891) detached]
✦ [⚡] × inxi -Faz
System: Kernel: 5.13.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=eaada518-9789-45a6-96d5-9ea2e9563ec6 rw rootflags=subvol=@
cryptdevice=UUID=12d783ca-85f9-4344-8e01-a57b4947f1a0:luks-12d783ca-85f9-4344-8e01-a57b4947f1a0
root=/dev/mapper/luks-12d783ca-85f9-4344-8e01-a57b4947f1a0 rd.udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Server System: Intel product: S2600CP v: .................... serial: <filter>
Chassis: P4308XXMFEN type: 17 v: IILH-M00000193 serial: <filter>
Mobo: Intel model: S2600CP v: G50768-509 serial: <filter> BIOS: Intel
v: SE5C600.86B.02.06.0007.082420181029 date: 08/24/2018
CPU: Info: 2x 8-Core model: Intel Xeon E5-2650 v2 bits: 64 type: MT MCP SMP
arch: Ivy Bridge family: 6 model-id: 3E (62) stepping: 4 microcode: 42E cache:
L2: 40 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 166300
Speed: 2219 MHz min/max: 1200/2600 MHz Core speeds (MHz): 1: 2219 2: 2534 3: 2452
4: 2594 5: 2100 6: 2207 7: 2585 8: 2281 9: 2578 10: 2489 11: 2594 12: 2543 13: 2594
14: 1776 15: 2546 16: 2545 17: 2228 18: 2400 19: 2532 20: 2377 21: 2594 22: 2586
23: 2584 24: 2444 25: 1988 26: 1801 27: 2217 28: 2552 29: 2528 30: 2551 31: 2452
32: 2590
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Graphics: Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: Micro-Star MSI driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 02:00.0 chip-ID: 10de:1b06
Device-2: Matrox Systems MGA G200e [Pilot] ServerEngines vendor: Intel
driver: mgag200 v: kernel bus-ID: 09:00.0 chip-ID: 102b:0522 class-ID: 0300
Device-3: NVIDIA GK210GL [Tesla K80] driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 83:00.0 chip-ID: 10de:102d class-ID: 0302
Device-4: NVIDIA GK210GL [Tesla K80] driver: nvidia v: 470.63.01
alternate: nouveau,nvidia_drm bus-ID: 84:00.0 chip-ID: 10de:102d class-ID: 0302
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
Screen-1: 0 s-res: 1920x1080 s-dpi: 69 s-size: 707x392mm (27.8x15.4")
s-diag: 808mm (31.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 46 size: 1060x626mm (41.7x24.6")
diag: 1231mm (48.5")
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Audio: Device-1: NVIDIA GP102 HDMI Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 02:00.1 chip-ID: 10de:10ef class-ID: 0403
Device-2: Creative Sound Blaster Play! 3 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 2-1.2:3 chip-ID: 041e:324d
Sound Server-1: ALSA v: k5.13.10-zen1-1-zen running: yes
Network: Device-1: Intel I350 Gigabit Network driver: igb v: kernel port: 1020 bus-ID: 07:00.0
chip-ID: 8086:1521 class-ID: 0200
IF: eno0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel I350 Gigabit Network driver: igb v: kernel port: 1000 bus-ID: 07:00.1
IF: enp7s0f1 state: down mac: <filter>
RAID: Hardware-1: Adaptec Series 7 6G SAS/PCIe 3 driver: aacraid v: 1.2.1[50983]-custom
port: 4000 bus-ID: 01:00.0 chip-ID: 9005.028c rev: 01 class-ID: 0104
Drives: Local Storage: total: 21.83 TiB used: 1.76 TiB (8.1%)
ID-1: /dev/sda maj-min: 8:0 model: root size: 21.83 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: N/A rev: V1.0 scheme: GPT
Partition: ID-1: / raw-size: 21.83 TiB size: 21.83 TiB (100.00%) used: 1.76 TiB (8.1%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-12d783ca-85f9-4344-8e01-a57b4947f1a0
ID-2: /boot raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 288.6 MiB (28.2%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 21.83 TiB size: 21.83 TiB (100.00%) used: 1.76 TiB (8.1%)
ID-4: /var/log raw-size: 21.83 TiB size: 21.83 TiB (100.00%) used: 1.76 TiB (8.1%)
ID-5: /var/tmp raw-size: 21.83 TiB size: 21.83 TiB (100.00%) used: 1.76 TiB (8.1%)
ID-1: swap-1 type: zram size: 125.79 GiB used: 0 KiB (0.0%) priority: 100
Sensors: Permissions: Unable to run ipmi sensors. Root privileges required.
System Temperatures: cpu: 31.0 C mobo: N/A gpu: nvidia temp: 40 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 51%
Info: Processes: 543 Uptime: 24m wakeups: 0 Memory: 125.79 GiB used: 6.3 GiB (5.0%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1
Packages: pacman: 2141 lib: 511 Shell: Zsh v: 5.8 running-in: alacritty inxi: 3.3.06
What could be the problem? What am I doing wrong? Thank you in advance.
