Konsole locks input not able to search in rofi / rofi-rbw
Issue Description
Since the migration to mocca and wayland I noticed the following behaviour.
When using rofi-rbw with the Konsole open, the input I do on my keyboard is sent to Konsole instead of rofi-rbw.
So I can’t search my credentials or input them.
Also the copy credentials to clipboard is not working.
What is rofi-rbw? A rofi frontend for Bitwarden/Vaultwarden.
Why do I need this? The Bitwarden/Vaultwarden Desktop Client is meh.
I want to search and enter my credentials as fast as possible.
The feature that rofi-rbw can send the password as keystrokes with ydotool is pure heaven when you have to input a 64+ size passwords into a KVM web console of e.g. Hetzner, DigitalOcean etc.
  Kernel: 6.14.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=4f3937b5-6c07-4580-8883-8cef1f42d4f5 rw rootflags=subvol=@
    cryptdevice=UUID=3d769afd-2828-481c-8e36-8aba99397d5a:luks-3d769afd-2828-481c-8e36-8aba99397d5a
    root=/dev/mapper/luks-3d769afd-2828-481c-8e36-8aba99397d5a
    resume=UUID=4f3937b5-6c07-4580-8883-8cef1f42d4f5 resume_offset=57068631
    wm: kwin_wayland tools: avail: i3lock vt: 1 dm: SDDM Distro: Garuda
  Type: Laptop System: Framework product: Laptop v: AB
  Mobo: Framework model: FRANBMCP0B v: AB serial: <superuser required>
    part-nu: FRANBMCP0B uuid: <superuser required> UEFI: INSYDE v: 03.07
    date: 12/14/2021
  ID-1: BAT1 charge: 48.0 Wh (100.0%) condition: 48.0/55.0 Wh (87.2%)
    volts: 17.3 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
    status: not charging
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    microcode: 0xB8
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1721 min/max: 400/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1721 2: 1721 3: 1721 4: 1721 5: 1721 6: 1721
    7: 1721 8: 1721 bogomips: 44851
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Framework
    built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Realtek Laptop Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 0bda:5634
  Monitor-1: eDP-1 model: BOE Display 0x095f built: 2019 res:
    mode: 2256x1504 hz: 60 scale: 135% (1.35) to: 1671x1114 dpi: 201 gamma: 1.2
    size: 285x190mm (11.22x7.48") diag: 343mm (13.5") ratio: 3:2
    modes: 2256x1504
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
    GT2) device-ID: 8086:9a49 memory: 15.2 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.309 layers: 9 device: 0 type: integrated-gpu name: Intel
    Iris Xe Graphics (TGL GT2) driver: mesa intel v: 25.0.4-arch1.1
    device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
    name: llvmpipe (LLVM 19.1.7 256 bits) driver: mesa llvmpipe
    v: 25.0.4-arch1.1 (LLVM 19.1.7) device-ID: 10005:0000
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Framework
    bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
  API: ALSA v: k6.14.3-zen1-1-zen status: kernel-api tools: N/A
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: aa:00.0
  IF: wlp170s0 state: up mac: <filter>
  IF-ID-1: br-64316bb60675 state: down mac: <filter>
  IF-ID-2: br-8f600333d6f8 state: down mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: virbr0 state: down mac: <filter>
  IF-ID-5: virbr1 state: down mac: <filter>
  IF-ID-6: virbr2 state: down mac: <filter>
    wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0032
    rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
  Local Storage: total: 931.51 GiB used: 386.33 GiB (41.5%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QGXA7 temp: 40.9 C
  ID-1: / raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
    used: 386.33 GiB (43.1%) fs: btrfs dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-3d769afd-2828-481c-8e36-8aba99397d5a
    used: 768 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
  ID-4: /var/log raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
  ID-5: /var/tmp raw-size: 896.96 GiB size: 896.96 GiB (100.00%)
  ID-1: swap-1 type: file size: 64 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-2: swap-2 type: zram size: 31.13 GiB used: 34.4 MiB (0.1%)
    max-streams: 8 dev: /dev/zram0
  ID-3: swap-3 type: partition size: 34.25 GiB used: 0 KiB (0.0%)
    priority: -3 dev: /dev/dm-1 maj-min: 253:1
    mapped: luks-a59fcb28-cd12-4a13-abcf-1ad9ee0585a5
  System Temperatures: cpu: 56.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 3621
  Memory: total: 32 GiB note: est. available: 31.13 GiB
    used: 10.23 GiB (32.9%)
  Processes: 387 Power: uptime: 39m states: freeze,mem,disk suspend: s2idle
    suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
    power-profiles-daemon, thermald, upowerd Init: systemd v: 257
  Packages: pm: pacman pkgs: 2325 libs: 509 tools: octopi,pamac,paru,yay
    Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish
  System install date:     2022-05-10
  Last full system update: 2025-04-24
Solution
Uninstall rofi
yay -R rofi
Install rofi-wayland and wl-clipboard
yay -S rofi-wayland wl-clipboard
Be Happy everything works again - yippy! :partying_face:
Little Hijack since this is about rofi and mokka.
There are premade themes for Catppuccin :heart_eyes:
