Few days before while I was using the computer the power went out and after restarting the terminal has changed( The color scheme has changed to Breeze). I can't even revert it how it was before. (It was Sweetified color scheme.). But if I open it as root, It opens normally. Is there a way to change it? I can't even add a new color scheme, it changes in the next open.
If you want to hide the user and host, you should make it unrecognizable in photos everywhere.
In photos we do not need and want from the terminal (here konsole) anyway.
Have you already read in the manual(s)?
I did it cz the name seems stupid, Btw which manual?
This one?
You do not post your inxi, but I think you use KDE and the “konsole”
so I think you must look in there manuals.
BTW, what means cz?
System: Kernel: 5.13.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=31462efd-23b4-43d9-9128-7cb5083a1f03
systemd.unified_cgroup_hierarchy=1 resume=UUID=37a06802-8265-4d92-901e-28812d45594f loglevel=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: SAMSUNG product: Samsung DeskTop System v: CAAAAAAF serial: <filter>
Chassis: SAMSUNG ELECTRONICS CO., LTD type: 3 serial: <filter>
Mobo: SAMSUNG model: Samsung DeskTop System serial: <filter> BIOS: SAMSUNG v: 00PE
date: 11/12/2009
CPU: Info: Quad Core model: Intel Core2 Quad Q6600 bits: 64 type: MCP arch: Core Merom family: 6
model-id: F (15) stepping: B (11) microcode: BA cache: L2: 4 MiB
flags: lm nx pae sse sse2 sse3 ssse3 vmx bogomips: 19155
Speed: 2394 MHz min/max: 1600/2400 MHz Core speeds (MHz): 1: 2394 2: 2394 3: 2394 4: 2394
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: Intel 4 Series Integrated Graphics vendor: Samsung Co driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:2e32 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.6x8.0") s-diag: 338mm (13.3")
Monitor-1: VGA1 res: 1024x768 dpi: 63 size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
OpenGL: renderer: Mesa DRI Intel G41 (ELK) v: 2.1 Mesa 21.2.1 direct render: Yes
Audio: Device-1: Intel NM10/ICH7 Family High Definition Audio vendor: Samsung Co driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:27d8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Samsung Co
driver: r8169 v: kernel port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u bus-ID: 1-8:4
chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s29f7u8 state: up mac: <filter>
IF-ID-1: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Drives: Local Storage: total: 409.88 GiB used: 47.6 GiB (11.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3320820AS size: 298.09 GiB block-size:
physical: 512 B logical: 512 B speed: <unknown> type: N/A serial: <filter> rev: D scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 model: AITC KSM 120GB size: 111.79 GiB block-size: physical: 512 B
logical: 512 B speed: <unknown> type: SSD serial: <filter> rev: 2A0 scheme: MBR
Partition: ID-1: / raw-size: 103.43 GiB size: 103.43 GiB (100.00%) used: 47.6 GiB (46.0%) fs: btrfs
dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 103.43 GiB size: 103.43 GiB (100.00%) used: 47.6 GiB (46.0%) fs: btrfs
ID-3: /var/log raw-size: 103.43 GiB size: 103.43 GiB (100.00%) used: 47.6 GiB (46.0%) fs: btrfs
ID-4: /var/tmp raw-size: 103.43 GiB size: 103.43 GiB (100.00%) used: 47.6 GiB (46.0%) fs: btrfs
ID-1: swap-1 type: zram size: 3.8 GiB used: 1.47 GiB (38.7%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.36 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb2
maj-min: 8:18
Sensors: System Temperatures: cpu: 70.0 C mobo: N/A
Info: Processes: 262 Uptime: 1h 1m wakeups: 0 Memory: 3.8 GiB used: 2.46 GiB (64.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1308 lib: 334
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
BTW, what means cz?
short for for cause.
For those who need to use a translation tool cz is not appropriate in the forum, please write out everything here, thank you.
sure.
Do you have a solution for my problem?
- Make sure you press apply after selecting the color scheme.
- It could be that you are editing a new Konsole profile, but the Default (read only) one is being used. Go to Settings -> Manage Profiles and make sure the one you modified is set as default.
- I have pressed that.
- There's nothing named Manage Profiles.
Btw, the permissions as follows.
Is this why I can't changed it permanently?
I can't take screenshots properly on my system, but it's there. Global menu Settings -> Manage Profiles (or) Configure Konsole and go to Profiles tab. Or just click around and you'll find it.
Well I have a option switch profile in the Switch profile. And If I change it to garuda it changes to the color scheme sweetified. But If i open a new instance of the konsole its no more applied. Which means it changes into the Default profile. Therefore I need to change the profile permanently.
It works. Thank you @zoeruda. You made my day.
