I’m using Kodi from time to time, and it used to work perfectly fine. (As far as Kodi goes at least…) But recently, I think between November 2023 and January 2024 all of sudden keyboard input stopped working at all alongside with the audio, only mouse input works. I’ve tried removing all configs related to Kodi and I tried running it as a new user, but that hasn’t helped. The only way I can get Kodi to accept keyboard input and have working audio is to run it via terminal with sudo, but I don’t think that’'s how its supposed to work… I’ve tried on a separate Pc that also runs Garuda, but never had Kodi installed and yet the result was the same. I don’t think it’s a Linux version of Kodi issue as when I tried it on bootable USB with Manjaro (KDE Plasma edition, to be as close to Garuda as possible.) it worked fine without the need for sudo. (I tried with bootable USB Garuda, but after updating everything it would just crash on launch, and rebooting removes all the updates, so yeah…) I also tried the flatpak version as opposed to the offical repo, but the result was still the same. Does anyone have any clue about what might be going on and how to fix it?
garuda-inxi output:
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0522a2df-3a77-4919-981f-38dd84af70be rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Convertible System: LENOVO product: 80X8 v: Lenovo YOGA 520-14IKB
serial: <superuser required> Chassis: type: 31 v: Lenovo YOGA 520-14IKB
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN
serial: <superuser required> UEFI-[Legacy]: LENOVO v: 4QCN51WW(V2.15)
date: 11/19/2019
ID-1: BAT1 charge: 39.1 Wh (89.3%) condition: 43.8/52.5 Wh (83.4%)
power: 12.8 W volts: 12.0 min: 11.2 model: SIMPLO PABAS0241231 type: Li-ion
Info: model: Intel Core i3-7130U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF4
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 525 high: 900 min/max: 400/2700 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 400 3: 400 4: 400
bogomips: 21599
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Syntek EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 174f:241a
class-ID: 0e02
Monitor-1: eDP-1 model: InfoVision Optronics/Kunshan 0x057d built: 2016
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1920x1080
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 7.45 GiB unified: yes
API: Vulkan v: 1.3.276 layers: 11 device: 0 type: integrated-gpu
name: Intel HD Graphics 620 (KBL GT2) driver: mesa intel v: 23.3.5-arch1.1
device-ID: 8086:5916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 0cf3:e500
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c0000
Local Storage: total: 1.03 TiB used: 832.32 GiB (79.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Patriot model: P300 128GB
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S1111A0L temp: 47.9 C
scheme: MBR
model: WD10SPZX-24Z10T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: MBR
ID-1: / raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
used: 52.72 GiB (44.2%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
ID-3: /var/log raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
ID-4: /var/tmp raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.62 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C pch: 44.0 C mobo: N/A
Processes: 240 Uptime: 0m wakeups: 0 Memory: total: 8 GiB
available: 7.63 GiB used: 2.5 GiB (32.8%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1691
pm: pacman pkgs: 1681 libs: 508 tools: octopi,pamac,paru pm: flatpak
pkgs: 10 Shell: fish v: 3.7.0 default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.31
Garuda (2.6.23-1):
System install date: 2023-08-18
Last full system update: 2024-02-06
