With the latest zen-kernel (6.16.zen2-1) the keyboard isn’t reacting any longer when trying to unlock the screen on my Hyprland-installation. Sometimes the keyboard isn’t even reacting direct after startup.
With the LTS (6.12.42-1-lts) no such problem is occurring.
All worked until the last 6.15-version I had on my laptop. Strangely enough this never appeared with the 6.16 versions of the mainline kernel. So, it must bis something with the zen branch that’s going wrong here.
> System:
> Kernel: 6.12.42-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
> clocksource: tsc avail: hpet,acpi_pm
> parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts
> root=UUID=8fc0538c-e6e3-47d8-a84e-7a636831918f rw rootflags=subvol=@
> resume=UUID=df24f3c3-6afd-4568-9051-cb3f3f460ba2 loglevel=3 ibt=off
> Desktop: Hyprland v: 0.50.1 with: waybar tools: hypridle avail: gtklock,
> hyprlock, swayidle, swaylock vt: 1 dm: N/A Distro: Garuda base: Arch Linux
> Machine:
> Type: Laptop System: LENOVO product: 242970G v: ThinkPad T530
> serial: Chassis: type: 10 serial:
> Mobo: LENOVO model: 242970G serial:
> part-nu: LENOVO_MT_2429 uuid: UEFI: LENOVO
> v: G4ETB6WW (2.76 ) date: 06/04/2019
> Battery:
> ID-1: BAT0 charge: 10.4 Wh (83.9%) condition: 12.4/73.3 Wh (17.0%)
> volts: 12.1 min: 11.1 model: SANYO 45N1023 type: Li-ion serial:
> status: not charging
> CPU:
> Info: model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
> gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
> model-id: 0x3A (58) stepping: 9 microcode: 0x21
> Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
> smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
> desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
> Speed (MHz): avg: 1198 min/max: 1200/3300 scaling: driver: intel_cpufreq
> governor: schedutil cores: 1: 1198 2: 1198 3: 1198 4: 1198 bogomips: 20756
> Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
> Vulnerabilities:
> Graphics:
> Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
> v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
> active: HDMI-A-2,LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-3, VGA-1
> bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
> Device-2: Bison ThinkPad Integrated Camera driver: uvcvideo type: USB
> rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-1.6:6
> chip-ID: 5986:02d2 class-ID: 0e02
> Display: wayland server: Xwayland v: 24.1.8 compositor: Hyprland v: 0.50.1
> driver: gpu: i915 display-ID: 1
> Monitor-1: HDMI-A-2 model: BenQ G2412HD serial: built: 2009
> res: 1920x1080 dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54")
> diag: 598mm (23.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
> Monitor-2: LVDS-1 model: Lenovo 0x40b0 built: 2010 res: 1366x768 dpi: 101
> gamma: 1.2 size: 345x194mm (13.58x7.64") diag: 396mm (15.6") ratio: 16:9
> modes: 1366x768
> API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
> device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
> drv: crocus x11: drv: crocus
> API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 25.1.7-arch1.1
> glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
> GT2) device-ID: 8086:0166 memory: 1.46 GiB unified: yes
> API: Vulkan v: 1.4.321 layers: 9 device: 0 type: integrated-gpu name: Intel
> HD Graphics 4000 (IVB GT2) driver: mesa intel v: 25.1.7-arch1.1
> device-ID: 8086:0166 surfaces: N/A device: 1 type: cpu name: llvmpipe
> (LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM
> 20.1.8) device-ID: 10005:0000 surfaces: N/A
> Info: Tools: api: eglinfo, glxinfo, vulkaninfo de: xfce4-display-settings
> wl: kanshi, nwg-displays, swaymsg, wdisplays, wlr-randr x11: xprop,xrandr
> Audio:
> Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
> driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
> class-ID: 0403
> API: ALSA v: k6.12.42-1-lts status: kernel-api
> tools: alsactl,alsamixer,amixer
> Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
> Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
> status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin
> 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
> Network:
> Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
> v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
> IF: enp0s25 state: down mac:
> Device-2: Intel Centrino Advanced-N 6205 \[Taylor Peak\] driver: iwlwifi
> v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
> chip-ID: 8086:0085 class-ID: 0280
> IF: wlp3s0 state: up mac:
> Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
> Bluetooth:
> Device-1: Broadcom BCM20702 Bluetooth 4.0 \[ThinkPad\] driver: btusb v: 0.8
> type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1.4:5
> chip-ID: 0a5c:21e6 class-ID: fe01 serial:
> Report: btmgmt ID: hci0 rfk-id: 3 state: up address: N/A
> Drives:
> Local Storage: total: 894.25 GiB used: 469.96 GiB (52.6%)
> SMART Message: Required tool smartctl not installed. Check --recommends
> ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37960G
> size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
> tech: SSD serial: fw-rev: 2101 scheme: GPT
> Partition:
> ID-1: / raw-size: 885.16 GiB size: 885.16 GiB (100.00%)
> used: 469.96 GiB (53.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
> ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
> used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
> ID-3: /home raw-size: 885.16 GiB size: 885.16 GiB (100.00%)
> ID-4: /var/log raw-size: 885.16 GiB size: 885.16 GiB (100.00%)
> ID-5: /var/tmp raw-size: 885.16 GiB size: 885.16 GiB (100.00%)
> Swap:
> Kernel: swappiness: 133 (default 60) cache-pressure: 100 (default) zswap: no
> ID-1: swap-1 type: zram size: 7.58 GiB used: 0 KiB (0.0%) priority: 100
> comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 4
> dev: /dev/zram0
> ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
> dev: /dev/sda3 maj-min: 8:3
> Sensors:
> System Temperatures: cpu: 56.0 C mobo: N/A
> Fan Speeds (rpm): fan-1: 2657
> Info:
> Memory: total: 8 GiB available: 7.58 GiB used: 2.61 GiB (34.5%)
> Processes: 243 Power: uptime: 1h 36m states: freeze,mem,disk suspend: deep
> avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
> suspend, test_resume image: 3 GiB Init: systemd v: 257 default: graphical
> tool: systemctl
> Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 2321 libs: 499
> tools: pacseek,paru,trizen,yay Compilers: clang: 20.1.8 gcc: 15.2.1
> Shell: Bash v: 5.3.3 default: Zsh v: 5.9 running-in: foot inxi: 3.3.38
> Garuda (2.7.5-1):
> System install date: 2025-03-17
> Last full system update: 2025-08-16
> Is partially upgraded: No
> Relevant software: snapper NetworkManager dracut
> Windows dual boot: No/Undetected
> Failed units:
> — System Health Check Report —
> 20/21 checks run in 1.09 seconds ⌛
> Powered by garuda-health 🦅
> ✅ System health check passed. No issues found.
And here is the garuda-inxi while on linux-zen
Kernel: 6.16.0-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
Mobo: LENOVO model: 242970G serial: <superuser required>
part-nu: LENOVO_MT_2429 uuid: <superuser required> UEFI: LENOVO
ID-1: BAT0 charge: 10.5 Wh (84.7%) condition: 12.4/73.3 Wh (17.0%)
volts: 12.1 min: 11.1 model: SANYO 45N1023 type: Li-ion serial: <filter>
Speed (MHz): avg: 1852 min/max: 1200/3300 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1852 2: 1852 3: 1852 4: 1852 bogomips: 20753
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.6:6
Monitor-1: HDMI-A-2 model: BenQ G2412HD serial: <filter> built: 2009
modes: 1366x768
API: ALSA v: k6.16.0-zen2-1-zen status: kernel-api
status: off 2: wireplumber status: active 3: pipewire-alsa type: plugin
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
Device-1: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad] driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4:5
chip-ID: 0a5c:21e6 class-ID: fe01 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
Local Storage: total: 894.25 GiB used: 469.95 GiB (52.6%)
tech: SSD serial: <filter> fw-rev: 2101 scheme: GPT
used: 469.95 GiB (53.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 61.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 2629
Memory: total: 8 GiB available: 7.57 GiB used: 2.15 GiB (28.5%)
Processes: 235 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.99 GiB Init: systemd v: 257
Garuda (2.7.5-1):
20/21 checks run in 1.34 seconds ⌛
