Can I try to jump on that post since I have exactly same problem with garuda wayfire.
Here are my setups :
╭─bt@grincheux in ~
╰─λ cat /etc/vconsole.conf
File: /etc/vconsole.conf
FONT=ter-220n
KEYMAP=cf
╭─bt@grincheux in ~ took 163ms
╰─λ cat /etc/X11/xorg.conf.d/00-keyboard.conf
File: /etc/X11/xorg.conf.d/00-keyboard.conf
# Written by systemd-localed(8), read by systemd-localed and Xorg. It's
# probably wise not to edit this file manually. Use localectl(1) to
# instruct systemd-localed to update it.
Section InputClass
Identifier system-keyboard
MatchIsKeyboard on
Option XkbLayout ca
Option XkbModel pc105
Option XkbVariant multix
EndSection
╭─bt@grincheux in ~ took 166ms
╰─λ localectl status
System Locale: LANG=fr_CA.UTF-8
VC Keymap: cf
X11 Layout: ca
X11 Model: pc105
X11 Variant: multix
╭─bt@grincheux in ~ took 195ms
╰─λ
I have read info on Arch wiki on how to setup correct keyboard, locale etc.
but no success. This is very naggy and I would like a solution .
This is wayland session.
I have no experience with wayland and wayfire settings.
Have you read any instructions/manuals/wiki on how wayland configures keyboard?
Explain where did you try to type and was not the correct layout.
Nothing seems to work to change keyboard layout.
The keyboard is stuck with the US layout even if I don't use it.
I have tried with the Wayfire Config Manager (input) as suggested and nothing happened.
I have tried with the "Garuda Parameter Manager" (sorry if translation is not exact, I'm using a french language garuda). I accessed the Parameter Manager with the Garuda Welcome. From the "keyboard parameters", i can set the canadian french keyboard with the multix variant. It ask for sudo password and apply the selection. But the keyboard stays in US english always ... And if I come back to the "keyboard Parameters", they are back to US english like if I had never changed it.
This is a major problem for all people that use other keyboard than the US.
Still searching on my side for a solution. Could it be something related to security ???
The console have the cf keyboard, but many characters don't show correctly.
Some accented vowel will show a small blank square.
And the rest under wayland and X11 will only use US keyboard even if the configuration files telling to use canadian french keyboard.
I have setup the 'Keyboard Parameters' to french canadian; I have set the Garuda config manager -> input to french canadian. I have checked in the wayfire.ini config and the canadian french keyboard is set too.
What exactly was not helpful?
French specialities are not familiar to me. Have you checked this?
You may need to add an auto-executed command (using setxkbmap) in your shell’s rc or other conf file.
Well, the keyboard layout may be the issue here (not sure, you have to find out yourself, changing things).
I have no experience with sway, wayfire, or wayland. They are the factors that I don’t know about. I have a pretty good understanding of Xorg, KDE and other DEs on locale, since I need it (Greek).
An obvious catch is
I suggest you do as suggested
to test if the preferred settings are applied (runtime and after reboot).
Also I don’t know the real difference between French Canadian and French layouts. Might you need to find out what is the proper one?
Get available settings (you would know if/since you read Archwiki).
For example
localectl list-x11-keymap-layouts | grep -i "ca\|cf\|fr" # available Xorg keyb layouts
localectl list-keymaps | grep -i "ca\|cf\|fr" # available console keyb layouts
sudo grep -i "ca\|cf\|fr" /etc/locale.gen # available LANG options
localectl list-locales # current active generated
For your info, I can't use the french (fr) keyboard because it is an azerty keyboard and the canadian french keyboard is a qwerty keyboard. The french keyboard is not usable for me.
I have added the "xkbmodel=pc105" in garuda.ini config file to be sure. It has no effect that I can see.
here is my X config for the keyboard (generated by localectl) :
╭─bt@grincheux in ~ took 5ms
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "ca"
Option "XkbModel" "pc105"
Option "XkbVariant" "multix"
EndSection
All configs seems to be setup correctly to canadian french an everything stays US. The setxkbmap does absolutly nothing, you can try to setup keyboard to fr and it will stay "us" in a alacritty shell under wayland... I guess that a tool for X isn't effective for wayland.
I will goback to my linux Arch or OpenSUSE on my other disk and check the differences with Garuda for anything related to language/keyboard/locale and see if I can come out with anything.
It makes the distro semi-usable for me and very frustrating. I have files with accented caracters and I want to type text in french with accent for communication with others. So it shall be a "nogo" if I can't find a solution.
But I'm still searching,
Thanks for all who tried to help me up to now :+1:
BT
This is the system setting.
You should look for your user/local session setting, at running level (not only a config file.
Using Wayfire/Wayland is not for inexperienced users, so I guess you either become an expert (if not already ), or move to an easier DE
The problem is solved. I have modified the ~/.config/wayfire.ini file to add the xkb_model. At first it didn't seems to have changed anything. But I went in the Garuda Setting Manager => Keyboard and reselected my canadian french keyboard as default keyboard. And then it started to work. My keyboard had switched to the french canadian keyboard suddenly.
I'm still puzzled as why it wouldn't work before. On Arch the only thing specified is in the wayfire.ini file; and it's the keyboard layout, the variant, the rules. The model and option, are empty.
I still need to find a good documentation with good explications on how to handle those international stuff configuration.
Thank you all for the kind help.
I would like to help by giving feedback on the help received (with all due respect).
I would suggest not to tell others to find an easier desktop when solution is not easily found. Wayfire is a rather new desktop and documentation/tools need to improve. And all users are not english natives. The language barrier is there. It's making the person asking for help feels inferior. Linux configuration is complex and nobody know everything about it. And helping someone at distance is also complex. Misunderstanding are lurking ... I'm glad we succeeded to find a solution.
You have to agree that this motivated you to do a better job on searching for a solution . I apologize for working on your psychology .
Thanks for your feedback. You are a very welcome Garuda community member!
