I’ve been having an occasional issue when I’m playing FFXIV, it has nothing to do with the game, just when it becomes really hectic and I’m going through buttons, I occasionally get stuck in some sort of keyboard mode, I’m not sure the term to search for is, it would have some sort of activation based on ctrl, alt, or shift since those are the buttons I have mapped for special buttons in game. After it gets hectic I’ll suddenly be stuck unable to use a variety of buttons in game as something else is capturing them, and my mouse loses the ability to interact with windows.
After I get stuck in this mode, T opens a terminal, E opens Thunar (my file explorer), and I think D or F opened Firefox, neither key was usable in game after, and the only way I’ve found to regain control of my system how I’m used to it is to swap to a tty, then swap back.
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=82153711-c850-462a-8202-79a8e6aa7878 rw rootflags=subvol=@
quiet resume=UUID=c59bd541-dcd2-44e8-8756-e8027a122cf6 loglevel=3 ibt=off
Desktop: Cinnamon v: 6.0.1 tk: GTK v: 3.24.39 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Gigabyte product: B550 UD AC-Y1 v: -CF
Mobo: Gigabyte model: B550 UD AC-Y1 v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: FD date: 06/08/2023
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 4191 high: 4197 min/max: 2200/5164 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4190 2: 4194
3: 4193 4: 4192 5: 4192 6: 4192 7: 4187 8: 4192 9: 4192 10: 4197 11: 4192
12: 4192 13: 4192 14: 4190 15: 4191 16: 4177 17: 4191 18: 4191 19: 4195
20: 4192 21: 4191 22: 4193 23: 4191 24: 4192 bogomips: 201208
Device-1: Avermedia driver: GC573 v: N/A alternate: gc573 pcie: gen: 2
speed: 5 GT/s lanes: 1 link-max: lanes: 4 bus-ID: 03:00.0 chip-ID: 1461:0054
class-ID: 0400
Device-2: AMD Navi 21 [Radeon RX 6950 XT] vendor: XFX driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2,DP-3,HDMI-A-1
empty: DP-1 bus-ID: 0a:00.0 chip-ID: 1002:73a5 class-ID: 0300
Device-3: MacroSilicon USB3.0 HD VIDEO
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 534d:2109
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3 driver: X:
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 6665x3600 s-dpi: 96 s-size: 1763x953mm (69.41x37.52")
s-diag: 2004mm (78.9")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: top-left
model: LG (GoldStar) Ultra HD serial: <filter> built: 2017 res: 3840x2160
hz: 60 dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39")
diag: 690mm (27.2") ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: DP-3 mapped: DisplayPort-2 pos: primary,bottom-c
model: Sceptre O34 built: 2022 res: 3440x1440 dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: middle-r model: Denon DENON-AVR
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 90 gamma: 1.2
size: 544x303mm (21.42x11.93") diag: 623mm (24.5") ratio: 16:9 modes:
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 16.0.6 DRM 3.54 6.6.7-zen1-1-zen) device-ID: 1002:73a5
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.274 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 23.3.1-arch1.1
device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.1-arch1.1 (LLVM
Device-1: Avermedia driver: GC573 alternate: gc573 pcie: gen: 2
class-ID: 0400
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab28
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
Device-4: MacroSilicon USB3.0 HD VIDEO
Device-5: Yamaha MG-XU driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3.2.1:6 chip-ID: 0499:1703
class-ID: 0102
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
lanes: 1 port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-3.1:5
IF: enp12s0f3u3u1 state: down mac: <filter>
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 13d3:3533
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
Local Storage: total: 55.48 TiB used: 6.98 TiB (12.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P3SSD8
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A temp: 42.9 C
model: WDS100T2B0B-00YS70 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 90WD
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DX001-1CE168
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 5900
serial: <filter> fw-rev: 0103 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST18000NM013J
size: 16.37 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 7200
ID-5: /dev/sdd maj-min: 8:48 vendor: HGST (Hitachi) model: HUS724040ALA640
ID-6: /dev/sde maj-min: 8:64 vendor: Seagate model: ST18000NM003D-3DL103
ID-7: /dev/sdf maj-min: 8:80 vendor: Western Digital
model: WUH721414ALE604 size: 12.73 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0103 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 345.59 GiB (18.9%)
used: 345.59 GiB (18.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.26 GiB used: 247.5 MiB (0.8%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 59.5 C mobo: 37.0 C gpu: amdgpu temp: 78.0 C
mem: 72.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 957
Processes: 540 Uptime: 18h 10m wakeups: 0 Memory: total: 32 GiB
available: 31.26 GiB used: 10.83 GiB (34.7%) Init: systemd v: 255
Packages: 1748 pm: dpkg pkgs: 0 pm: pacman pkgs: 1726 libs: 515 tools: paru
pm: flatpak pkgs: 22 Shell: fish v: 3.6.4 running-in: gnome-terminal
inxi: 3.3.31
Garuda (2.6.21-1):
System install date: 2023-11-11
Last full system update: 2023-12-26
