Yesterday i installed garuda-dragonized but i keyboard lights are not working , i m able to change screen brightness & volume with Fn keys but not keypad lights.
root=UUID=1658ad10-6357-4dcb-9065-03d9a45957b9 rw rootflags=subvol=@
quiet resume=UUID=ccb7adc2-8afa-437b-8fef-07bf847f5bed loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LHB_FX506LHB
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FX506LHB v: 1.0 serial: <filter>
UEFI: American Megatrends v: FX506LHB.311 date: 02/09/2022
ID-1: BAT1 charge: 35.1 Wh (87.1%) condition: 40.3/48.1 Wh (83.8%)
volts: 12.7 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: charging
Info: model: Intel Core i5-10200H socket: U3E1 bits: 64 type: MT MCP
arch: Comet Lake gen: core 10 level: v3 note: check built: 2020
process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 2
microcode: 0xF8
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4100 base/boost: 2277/8300 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
bogomips: 38400
Device-1: Intel Comet Lake-H GT1 [UHD Graphics 610] vendor: ASUSTeK
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9ba4
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 545.xx+ status: current (as of 2023-10;
EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0300
temp: 46.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 322e:202c
class-ID: 0e02
Display: server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
device: 0 drv: nouveau device: 1 drv: iris device: 2 drv: swrast gbm:
drv: nouveau surfaceless: drv: nouveau x11: drv: iris inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT1)
device-ID: 8086:9ba4 memory: 7.42 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT1) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:9ba4 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.84 status: n/a (root, process) with:
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: enp0s20f0u2 state: unknown speed: -1 duplex: half mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-14:12
chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 24.66 GiB (5.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZ
lanes: 4 tech: SSD serial: <filter> fw-rev: 002C temp: 33.9 C scheme: GPT
SMART: yes health: PASSED on: 38d 15h cycles: 1,151
read-units: 18,703,557 [9.57 TB] written-units: 13,837,751 [7.08 TB]
used: 24.65 GiB (5.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 7.6 GiB used: 1.65 GiB (21.8%) priority: 100
System Temperatures: cpu: 51.0 C pch: 59.0 C mobo: N/A gpu: nouveau
temp: 46.0 C
Fan Speeds (rpm): cpu: 0
Processes: 279 Uptime: 1h 41m wakeups: 1 Memory: total: 8 GiB
available: 7.6 GiB used: 2.99 GiB (39.3%) igpu: 64 MiB Init: systemd v: 254
pm: pacman pkgs: 1816 libs: 551 tools: gnome-software,octopi,pamac,paru
Shell: garuda-inxi (sudo) default: Bash v: 5.2.15 running-in: konsole
inxi: 3.3.31
Garuda (2.6.18-1):
System install date: 2023-11-11
Last full system update: 2023-11-11 ↻
Yesterday i installed Garuda-Hyprland and i installed atk package due to which i can control brightness with keypad but i cant turn on my keypad lights.
Kernel: 6.5.10-x64v2-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=7f2d46a6-4eeb-45bb-971d-9889d4aab304 rw rootflags=subvol=@
quiet resume=UUID=02eb8e91-7d22-4247-b3fa-b2fae4031cdb loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: GL553VE v: 1.0
Mobo: ASUSTeK model: GL553VE v: 1.0 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: GL553VE.308 date: 04/29/2019
ID-1: BAT0 charge: 25.0 Wh (93.6%) condition: 26.7/48.2 Wh (55.4%)
volts: 15.4 min: 14.4 model: Simplo SDI ICR18650 type: Li-ion
serial: <filter> status: discharging cycles: 33
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1969 high: 3581 min/max: 800/3800 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 1904 3: 3517
4: 800 5: 800 6: 3581 7: 3553 8: 800 bogomips: 44798
Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: ASUSTeK
driver: nouveau v: kernel alternate: nvidiafb non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0302 temp: 41.0 C
Device-3: Realtek USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0bda:57f5
compositor: Hyprland driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: iris,nouveau gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: BOE Display 0x069c built: 2015 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 scale: 1 size: 344x193mm (13.54x7.6")
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 630 (KBL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:591b surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel CM238 HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171
API: ALSA v: k6.5.10-x64v2-xanmod1-1 status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4 chip-ID: 8087:0a2a
Local Storage: total: 931.51 GiB used: 11.42 GiB (1.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3V0 scheme: MBR
ID-1: / raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
used: 11.42 GiB (1.2%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-3: /var/log raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-4: /var/tmp raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
zswap: no
ID-1: swap-1 type: zram size: 7.64 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 51.0 C pch: 50.0 C mobo: N/A gpu: nouveau
temp: 41.0 C
Fan Speeds (rpm): cpu: 2600
Processes: 218 Uptime: 46m wakeups: 0 Memory: total: 8 GiB
available: 7.64 GiB used: 2.5 GiB (32.7%) Init: systemd v: 254
pm: pacman pkgs: 1409 libs: 392 tools: gnome-software,paru Shell: Bash
v: 5.2.15 running-in: kitty inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-11-04
Last full system update: 2023-11-04 ↻
NaN
4 November 2023 14:11
4
I thought this was a hardware(keyboard) handled feature? I too have a backlit keyboard and it works with Fn +Spacebar keycombo. This behaviour has remained consistent with shift from Windows to garuda.
I would assume you too have such a button/shortcut that does that on your keyboard backlight but I am not too experienced with RGB stuff so I might be wrong.
Nope in my laptop the RGB turns on with Fn + F4 & F3 because there are 3 levels of brightness and Screen brightness can be controlled with Fn + F5 & F6 which is working but i am still not able to figure out why my keypad lights are not working.
BlasterX24:
this forum may help your hardware issue:
Greetings all, I bought ASUS GL553VE laptop few days ago, mostly for specs to code using Ubuntu. Linux is working almost fine there, however, there is no way to control the Aura keyboard backlight. Is there any sort of tool to do that in...
here’s a package for your machine that was linked in that forum thread:
SGS
11 November 2023 10:15
7
@BlasterX24
It will not help, and it is rude to open new topics for the same problem.
Post why the hints does not help, what you try by yourself, please.
sorry but it was my diff laptop!
SGS
11 November 2023 10:33
9
Ok, what say asustek about linux compatibility?
Did you check the arch wiki about your models?
Did you use BIOS Fn settings?
system
Closed
25 November 2023 10:34
10
