Keyboard layout problem
Hello i have install garuda linux today it was great experience to me! but i have an issue i am programmer when used shift to unlock number 2 it return me this " and when i press ’ it returns @ when i press 3 with shift it return £ this need help!
it is hard to pratice programming
╭─batman@vitcus in ~ took 4s
╰─λ sudo garuda-inxi
[sudo] password for batman:
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=744736bd-ab80-41dd-ade6-eb0f243d02ce rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Laptop System: HP product: Victus by HP Gaming Laptop 15-fb1xxx v: N/A
Mobo: HP model: 8C30 v: 88.14 serial: <filter> part-nu: 8L083PA#ACJ
uuid: 33444335-3532-3144-5632-6c8ea7c40b29 UEFI: AMI v: F.03
date: 08/10/2023
ID-1: BAT0 charge: 49.4 Wh (100.0%) condition: 49.4/49.4 Wh (100.0%)
volts: 13.1 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 99
Info: model: AMD Ryzen 5 7535HS with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2065 high: 4541 min/max: 400/4603 base/boost: 3300/4600
scaling: driver: amd-pstate-epp governor: powersave volts: 1.2 V
ext-clock: 100 MHz cores: 1: 2742 2: 4541 3: 2243 4: 400 5: 2395 6: 2330
7: 2396 8: 400 9: 2395 10: 2291 11: 2255 12: 400 bogomips: 79049
Device-1: NVIDIA GA107 [GeForce RTX 2050] vendor: Hewlett-Packard
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 4 speed: 16 GT/s
lanes: 8 link-max: lanes: 16 ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:25ad class-ID: 0300
Device-2: AMD Rembrandt [Radeon 680M] vendor: Hewlett-Packard
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1
bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 52.0 C
Device-3: Chicony HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b766
Display: server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x094d built: 2020
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
rembrandt LLVM 17.0.6 DRM 3.57 6.8.7-zen1-2-zen) device-ID: 1002:1681
memory: 500 MiB unified: no
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:1681 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2050 driver: nvidia v: 550.76
device-ID: 10de:25ad surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 13d3:3567
Local Storage: total: 476.94 GiB used: 12.17 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN810 SDCPNRY-512G-1006 size: 476.94 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 42.9 C scheme: GPT
SMART: yes health: PASSED on: 20d 6h cycles: 11,314
read-units: 32,643,380 [16.7 TB] written-units: 14,257,689 [7.29 TB]
used: 12.17 GiB (2.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 6.97 GiB used: 2.68 GiB (38.4%)
System Temperatures: cpu: 60.1 C mobo: 44.0 C gpu: amdgpu temp: 53.0 C
Fan Speeds (rpm): fan-1: 2708 fan-2: 0
Memory: total: 8 GiB note: est. available: 6.97 GiB used: 4.95 GiB (71.1%)
Processes: 402 Power: uptime: 4h 13m states: freeze,mem,disk
suspend: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 2.75 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1839 libs: 542 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
System install date:     2024-08-25
Last full system update: 2024-08-25 ↻
Is partially upgraded:   Yes
It’s probably a keyboard layout problem (you have the wrong layout active).
Open Settings - Keyboard - Layouts click on Configure layouts and either move “yours” up or add it if not listed and move it up.
an reboot required after that ?? and what layout i need to choose
No, reboot is not required and you can even use the available (or other) shortcuts to switch.
which layout i need to select bro
I don’t know! This depends on your keyboard.
I have an Italian keyboard and use the relevant layout (it).
International keyboards often have “English (US)”.
