Keyboard layout changes do not work
Hello folks!
Having trouble setting up language-switching on garuda i3 edition, fresh install.
Following step 2.2.1 on Xorg/Keyboard configuration - ArchWiki I used localectl set-x11-keymap us,ru pc105 "" grp:lalt_lshift_toggle to configure 00-keyboard.conf. The configuration was successfull as localectl status returns
  System Locale: LANG=en_US.UTF-8
       VC Keymap: us-acentos
      X11 Layout: us
       X11 Model: pc105
     X11 Options: grp:lalt+lshift_toggle
which should work, yet pressing lalt+lshift does nothing, be it before or after reboot. However, setxkbmap -layout us,ru -option grp:lalt_lshift_toggle works properly, letting me change layouts back and forth all I want by pressing lalt+lshift. I know I can throw that into some autoexecute file and be done with it, but I want it to be done properly, so why does localectl way of making the change permanent doesnt work?
Garuda-inxi:
  Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=b290f53a-a9c0-43d4-92d1-c19e8c49542f rw rootflags=subvol=@
  Desktop: i3 v: 4.21 info: i3bar vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: Razer product: Blade v: 6.06
  Mobo: Razer model: Razer serial: <superuser required> UEFI: Razer v: 4.02
    date: 02/22/2018
  ID-1: BAT0 charge: 33.8 Wh (55.5%) condition: 60.9/70.2 Wh (86.7%)
    volts: 11.2 min: 11.4 model: Razer Blade type: Unknown serial: <filter>
  Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
    model-id: 0x9E (158) stepping: 9 microcode: 0xF0
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 2562 high: 2800 min/max: 800/3800 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2800 2: 2800 3: 2800
    4: 2800 5: 2800 6: 2800 7: 2800 8: 900 bogomips: 44798
    vulnerable
    PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 630 vendor: Razer USA driver: i915 v: kernel
    empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
  Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] vendor: Razer USA
    driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-10) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c20
  Device-3: Realtek USB Camera type: USB driver: uvcvideo bus-ID: 1-7:3
    chip-ID: 0bda:579f class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 driver: X:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Monitor-1: eDP-1 model: LG Display 0x0569 built: 2016 res: 1920x1080
    hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1920x1080
  Device-1: Intel CM238 HD Audio vendor: Razer USA driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
  Sound API: ALSA v: k5.19.13-zen1-1-zen running: yes
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Rivet Networks Killer Wireless-n/a/ac 1535 driver: ath10k_pci
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3b:00.0
    chip-ID: 168c:003e class-ID: 0280 temp: 32.0 C
  IF: wlp59s0 state: up mac: <filter>
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
    v: 0.8 bus-ID: 1-4:2 chip-ID: 0cf3:e300 class-ID: e001
  Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 0 state: down
    bt-service: disabled rfk-block: hardware: no software: yes address: N/A
  Local Storage: total: 476.94 GiB used: 9.87 GiB (2.1%)
    model: MZVLW512HMJP-00000 size: 476.94 GiB block-size: physical: 512 B
    rev: CXY7501Q temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 124 GiB size: 124 GiB (100.00%) used: 9.84 GiB (7.9%)
  ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 27.7 MiB
    (28.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 124 GiB size: 124 GiB (100.00%) used: 9.84 GiB
    (7.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-4: /var/log raw-size: 124 GiB size: 124 GiB (100.00%) used: 9.84 GiB
  ID-5: /var/tmp raw-size: 124 GiB size: 124 GiB (100.00%) used: 9.84 GiB
  ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 44.0 C pch: 39.0 C mobo: N/A
  Processes: 246 Uptime: 17m wakeups: 1 Memory: 15.52 GiB used: 1.93 GiB
  (12.4%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1332
  libs: 361 tools: pamac,paru Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.22
Garuda (2.6.8-1):
  System install date:     2022-10-10
  Last full system update: 2022-11-05
Have you installed Fcitx or IBus by any chance? Have you issue the localectl command with admin privileges? What is the contents of /etc/X11/xorg.conf.d/00-keyboard.conf?
