I am having a bit of trouble with my keyboard. I tried to create a udev rule to rename my network interface, following a few guides i found to create the rule. after rebooting i found that my keyboard no longer worked. I booted into rescue mode and deleted the rule. but now my keyboard only works after waiting about 30 seconds after boot. All my usb devices seem to work, and after 30 seconds they seem to reset. Then my keyboard will start working.
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=6a8a01fd-1dfe-48f8-8b4d-c2c38ad8ec88 rw rootflags=subvol=@
quiet resume=UUID=61fcd7d4-37c6-41ce-8991-c45faf6c34ec loglevel=3 ibt=off
Type: Desktop System: Gigabyte product: X570S AORUS PRO AX v: -CF
Mobo: Gigabyte model: X570S AORUS PRO AX serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F6c
date: 09/20/2023
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3783 high: 4581 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3632
3: 3605 4: 4458 5: 3639 6: 4581 7: 3598 8: 3599 9: 3700 10: 3602 11: 3584
12: 3605 13: 3648 14: 3622 15: 3676 16: 4472 17: 3685 18: 4075 19: 3700
20: 3700 21: 3916 22: 3600 23: 3700 24: 3700 bogomips: 177605
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M]
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,HDMI-A-1 empty: DP-2,DP-3,Writeback-1 bus-ID: 0d:00.0
chip-ID: 1002:744c class-ID: 0300
gpu: amdgpu d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-1 pos: bottom-l res: 3440x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: top-right res: 1920x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
navi31 LLVM 17.0.6 DRM 3.57 6.8.7-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.5-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab30
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS GameDAC driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-2.2:9
chip-ID: 1038:1282 class-ID: 0300 serial: <filter>
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api with: aoss
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0608
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
IF: enp7s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
wpa_supplicant
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-5:2 chip-ID: 0e8d:0608
Local Storage: total: 4.32 TiB used: 2.76 TiB (63.9%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Kingston model: SNV2S500G
lanes: 4 tech: SSD serial: <filter> fw-rev: EJFK3N.7 temp: 70.8 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 62.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 054 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 2TB
ID-1: / raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
used: 46.12 GiB (10.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
ID-4: /var/log raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
ID-5: /var/tmp raw-size: 431.11 GiB size: 431.11 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.23 GiB used: 247.8 MiB (0.8%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
ID-2: swap-2 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5
System Temperatures: cpu: 86.0 C mobo: 58.0 C gpu: amdgpu temp: 65.0 C
mem: 81.0 C
Memory: total: 32 GiB available: 31.23 GiB used: 11.91 GiB (38.1%)
Processes: 469 Power: uptime: 1h 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2085 libs: 566 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-04-19
Last full system update: 2024-04-26
Failed units: nmb.service systemd-vconsole-setup.service
