I have reinstalled Garuda after some issues I created in my first install, and now I cannot get the keyboard backlight to function the way I want.
I simply want the Scroll Lock
key to toggle on/off the keyboard backlight - my keyboard is a Cooler Master Devastator with only one backlight color and brightness - it's either on, or off. Pretty simple.
On the first Garuda install (that I screwed up, requiring the reinstall) I was able to get this to work, and be persistent after power cycling/log-in/out, by simply typing in a terminal the following:
sudo xmodmap -e 'add mod3 = Scroll_Lock'
I found that by searching, and it worked like a charm. So, fast-forward to after the reinstall, and of course I assume this will work....which it does for the current session only - there's no persistence. I have researched and read alot of posts, many of which are for other distros using different WMs, so I'm a little wary of executing anything that's not specifically for Arch or Garuda.
I'm not sure what Garuda uses upon session login to determine the keymaps, and therefore, what I should be doing to modify a file to make this permanent. I looked through the Settings in Garuda Settings Manager and System Settings, but see nothing that appears to address my issue. I'm just looking for some advice on the best way to accomplish this one task - I feel like I shouldn't need to create a script and have it autorun on login (some posts have suggested this for other distros). I also don't understand why this worked on the first install and not on the second. ???
Kernel: 6.0.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=33bab7e2-354b-4a41-90a0-a035436b4688 rw rootflags=subvol=@
resume=UUID=d50fe1fb-623e-4546-b2a6-59b370feff67 loglevel=3
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.6 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4901
date: 07/25/2022
Device-1: hidpp_battery_0 model: Logitech G700s serial: <filter> charge: 55%
(should be ignored) rechargeable: yes status: discharging
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3634 high: 4027 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3600 2: 3600
3: 4027 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3582 10: 3600 11: 3600
12: 3600 bogomips: 86407
protection
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: eVga.com.
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 07:00.0 chip-ID: 10de:2482 class-ID: 0300
Device-2: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-2:2 chip-ID: 046d:0892
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
Screen-1: 0 s-res: 5360x1440 s-dpi: 109 s-size: 1249x342mm (49.17x13.46")
s-diag: 1295mm (50.98")
Monitor-1: DP-4 pos: primary,top-left res: 3440x1440 hz: 60 dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.15") modes: N/A
Monitor-2: HDMI-0 pos: bottom-r res: 1920x1080 hz: 60 dpi: 96
size: 509x286mm (20.04x11.26") diag: 584mm (22.99") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 5-2:2 chip-ID: 046d:0892 pcie:
class-ID: 0102 gen: 3 speed: 8 GT/s serial: <filter> lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 07:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C920 HD Pro Webcam type: USB
Sound API: ALSA v: k6.0.6-zen1-1-zen running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Local Storage: total: 13.19 TiB used: 174.28 GiB (1.3%)
model: WDBRPG0010BNC-WRSN size: 931.51 GiB block-size: physical: 512 B
rev: 111130WD temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: SSD serial: <filter> rev: 1B6Q
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWE140
type: HDD rpm: 7200 serial: <filter> rev: FP1R scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MD04ACA500
size: 4.55 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: FP2A scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba model: External
USB 3.0 size: 3.64 TiB block-size: physical: 4096 B logical: 512 B
type: N/A serial: <filter> rev: 5438 scheme: GPT
ID-1: / raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 174.28 GiB
(19.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 174.28
GiB (19.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 174.28
ID-5: /var/tmp raw-size: 896.83 GiB size: 896.83 GiB (100.00%) used: 174.28
ID-1: swap-1 type: zram size: 31.26 GiB used: 1.2 MiB (0.0%)
System Temperatures: cpu: 35.0 C mobo: 29.0 C gpu: nvidia temp: 41 C
Fan Speeds (RPM): cpu: 778 case-1: 729 case-2: 0 case-3: 858 gpu: nvidia
fan: 0%
Power: 12v: 9.92 5v: N/A 3.3v: N/A vbat: 3.23
Processes: 305 Uptime: 20m wakeups: 2 Memory: 31.26 GiB used: 3.22 GiB
(10.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2031
libs: 553 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2022-10-29
Last full system update: 2022-10-30
I'll add that I looked here: Keyboard backlight - ArchWiki
and since there is nothing about KDE Plasma, I'm leery to use anything listed here.
