Key bindings in console for delete key differ Dragonized vs Mokka
The ‘delete’ key on a Mokka laptop deletes the character above the cursor and continues towards the right (expected) in Konsole. The ‘delete’ key on Dragonized desktop (Logi MX Keys S keyboard) deletes the character to the left of the cursor and continues to the left (unexpected) in Konsole. In both pc’s all applications i.e. Kate, LibreOffice Writer, etc, the delete key deletes to the right (expected). Both pc’s have the same applications installed. Both are built with the respective …250308 iso’s (running KDE, wayland).
I ran on both pc’s:
╰─λ bind -a | grep -i delete
bind --preset shift-delete history-pager-delete or backward-delete-char
bind --preset -k sdc history-pager-delete or backward-delete-char
bind --preset ctrl-d delete-or-exit
bind --preset delete delete-char
bind --preset backspace backward-delete-char
bind --preset shift-backspace backward-delete-char
bind --preset ctrl-h backward-delete-char
bind --preset ctrl-delete kill-word
bind delete _autopair_backspace
The last line (autopair_backspace) is what’s different, it appears on the desktop not on the laptop.
I tried to search in my .config and .local folders for something that might be setting the delete key, but couldn’t find anything. I originally saw this (unexpected) on the laptop running test Dragonized iso’s but thought it was due to KDE development, so forgot about it.
Currently I’m avoiding xmodmap and other key binding applications, in the hope I just need to unset something.
Kernel: 6.14.0-arch1-1-znver5 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver5
root=UUID=1e687301-70d2-4461-b24f-ad53850a97e4 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop Mobo: Micro-Star model: MPG X870E CARBON WIFI (MS-7E49) v: 1.0
Megatrends LLC. v: 1.A30 date: 03/12/2025
Info: model: AMD Ryzen 9 9950X bits: 64 type: MT MCP arch: N/A level: v4
note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
microcode: 0xB404023
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1.2 MiB desc: d-16x48 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3632 min/max: 600/5756 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3632 2: 3632 3: 3632
4: 3632 5: 3632 6: 3632 7: 3632 8: 3632 9: 3632 10: 3632 11: 3632 12: 3632
13: 3632 14: 3632 15: 3632 16: 3632 17: 3632 18: 3632 19: 3632 20: 3632
21: 3632 22: 3632 23: 3632 24: 3632 25: 3632 26: 3632 27: 3632 28: 3632
29: 3632 30: 3632 31: 3632 32: 3632 bogomips: 275199
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: Sapphire NITRO+ driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-3, DP-4, DP-5, HDMI-A-3,
Writeback-2 bus-ID: 7a:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 41.0 C
gpu: amdgpu display-ID: 0
Monitor-1: DP-2 model: MSI MPG271QX OLED built: 2024 res: mode: 2560x1440
hz: 120 scale: 110% (1.1) to: 2327x1309 dpi: 107 gamma: 1.2
size: 606x344mm (23.86x13.54") diag: 697mm (27.4") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.2-arch1.2
navi31 LLVM 19.1.7 DRM 3.61 6.14.0-arch1-1-znver5) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:13c0
Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 7a:00.1 chip-ID: 1002:1640
speed: 16 GT/s lanes: 16 bus-ID: 7a:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:6
chip-ID: 0db0:0b58 class-ID: 0300
API: ALSA v: k6.14.0-arch1-1-znver5 status: kernel-api tools: N/A
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1 port: c000 bus-ID: 09:00.0
chip-ID: 10ec:8126 class-ID: 0200
Device-3: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn Band Simultaneous Wireless driver: ath12k_pci v: N/A
modules: ath12k pcie: gen: 3 speed: 8 GT/s lanes: 2 bus-ID: 10:00.0
chip-ID: 17cb:1107 class-ID: 0280
IF: wlp16s0 state: down mac: <filter>
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-9:5 chip-ID: 0489:e10a
Local Storage: total: 1.82 TiB used: 18.31 GiB (1.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T705SSD3
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: PACR5111 temp: 39.9 C
ID-1: / raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
used: 18.3 GiB (1.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 608 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-4: /var/log raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-5: /var/tmp raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-1: swap-1 type: zram size: 60.37 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
System Temperatures: cpu: 46.0 C mobo: 33.2 C
Fan Speeds (rpm): fan-1: 0 fan-2: 2941 fan-3: 0 fan-4: 0 fan-12: 979
fan-13: 0 fan-14: 0 fan-15: 0 fan-16: 0
GPU: device: amdgpu temp: 46.5 C device: amdgpu temp: 51.0 C mem: 60.0 C
fan: 0 watts: 37.00
Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.14
Memory: total: 60 GiB note: est. available: 60.37 GiB used: 5.18 GiB (8.6%)
Processes: 613 Power: uptime: 2h 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1470 libs: 407 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date:     2025-03-27
Last full system update: 2025-04-01
Did you accidentally use the insert button?
And
Rebooted. Same behavior, delete key moves to the left
loglevel=3 ibt=off
Speed (MHz): avg: 2982 min/max: 600/5756 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2982 2: 2982 3: 2982
4: 2982 5: 2982 6: 2982 7: 2982 8: 2982 9: 2982 10: 2982 11: 2982 12: 2982
13: 2982 14: 2982 15: 2982 16: 2982 17: 2982 18: 2982 19: 2982 20: 2982
21: 2982 22: 2982 23: 2982 24: 2982 25: 2982 26: 2982 27: 2982 28: 2982
29: 2982 30: 2982 31: 2982 32: 2982 bogomips: 275199
Writeback-2 bus-ID: 7a:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 43.0 C
Local Storage: total: 1.82 TiB used: 18.29 GiB (1.0%)
used: 18.28 GiB (1.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 49.8 C mobo: 43.5 C
Fan Speeds (rpm): fan-1: 0 fan-2: 2926 fan-3: 0 fan-4: 0 fan-12: 975
GPU: device: amdgpu temp: 42.0 C device: amdgpu temp: 50.0 C mem: 60.0 C
fan: 0 watts: 36.00
Memory: total: 60 GiB note: est. available: 60.37 GiB used: 4.07 GiB (6.7%)
Processes: 645 Power: uptime: 1m states: freeze,mem,disk suspend: deep
maybe you overread this?
No, on the insert button (tested immediately after a reboot) . Did some more digging, booted on the iso and the terminal is just fine (delete to the right). Tried a new config.fish file from /etc/skel/.config/fish (no luck). Typing bash and the delete key goes to the right, type konsole and delete is back to the left. Now I know the keyboard selection in System Settings → Keyboard is ok. Something is certainly self-inflicted here.
This is in plain Konsole CLI app, not in an app inside Konsole (Vim, Micro, Nano…)?
In true CLI in konsole it deletes to the right for me.
Backscape deletes to the left.
I’m not helping, just adding to the comparison.
After looking on how to set key bindings in X11, Wayland, KDE…, via several types of applications, I never did find where this was being set:
I did find the fix. It’s in Konsole, goto Settings → Edit Current Profile → Keyboard: Solaris console was the culprit. Changing the selection to Linux console or Default (XFree 4). Both of those made the Delete key move right. I settled on Linux console. On Mokka, selecting Solaris console made the Delete key move left. It’s default was set to Default (XFree 4). Note the System Settings → Keyboard had no impact on the situation.
Not sure where the Solaris console file is located, to compare with older versions, or how it was selected in the first place (I don’t recall making any changes). But happy days now.
