Hi @all,
I'm using an hp probook 845 G9 with Ryzen 5 pro 6650u CPU (Radeon iGpu).
When I want to shutdown the PC by using GUI, the notebook reboots.
Same problem with the shutdown now command in the terminal.
The only way to shutdown the PC is to select it from Grub.
After searching on forums, it seems to be a kernel problem, so I tried downloading and applying the Zen3 fixed kernel (linux-amd-znver3-6.4.v.8-1 + headers) thanks to Garuda Setup assistant, but I've got NO Wifi AND it doesn't shutdown as well, only reboot...
I'm new to arch, so be forgiving please ![]()
Can you help me please to get my system working well (shutdown working, and no missing drivers) ?
Have a nice day
Kernel: 6.4.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=a69746de-3731-4dcb-93b6-53988d380f12 rw rootflags=subvol=@
Type: Laptop System: HP product: HP EliteBook 845 14 inch G9 Notebook PC
v: N/A serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8990 v: KBC Version 09.4A.00 serial: <superuser required>
UEFI: HP v: U82 Ver. 01.05.01 date: 03/22/2023
ID-1: BAT0 charge: 29.3 Wh (57.1%) condition: 51.3/51.3 Wh (100.0%)
power: 10.0 W volts: 11.5 min: 11.6 model: Hewlett-Packard Primary
type: Li-ion serial: <filter> status: discharging cycles: 6
Info: model: AMD Ryzen 5 PRO 6650U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1583 high: 1600 min/max: 1600/4582 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 1600
3: 1600 4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 9: 1600 10: 1406 11: 1600
12: 1600 bogomips: 69473
Device-1: AMD Rembrandt [Radeon 680M] vendor: Hewlett-Packard driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, HDMI-A-1 bus-ID: 63:00.0
chip-ID: 1002:1681 class-ID: 0300 temp: 49.0 C
Device-2: Chicony HP 5MP Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 04f2:b738
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1435 built: 2021
res: 1920x1200 hz: 60 dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4")
diag: 355mm (14") ratio: 16:10 modes: max: 1920x1200 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon Graphics (rembrandt
LLVM 15.0.7 DRM 3.52 6.4.8-zen1-1-zen) direct-render: Yes
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 63:00.1
snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 63:00.5 chip-ID: 1022:15e2 class-ID: 0480
bus-ID: 63:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.4.8-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
Device-1: Realtek vendor: Hewlett-Packard driver: rtw89_8852be v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 6000 bus-ID: 01:00.0
chip-ID: 10ec:b852 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0bda:b85c
address: <filter>
Local Storage: total: 931.51 GiB used: 11.66 GiB (1.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK1N.1 temp: 40.9 C
ID-1: / raw-size: 224.61 GiB size: 224.61 GiB (100.00%)
used: 11.59 GiB (5.2%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 71.9 MiB (74.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 224.61 GiB size: 224.61 GiB (100.00%)
ID-4: /var/log raw-size: 224.61 GiB size: 224.61 GiB (100.00%)
ID-5: /var/tmp raw-size: 224.61 GiB size: 224.61 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.1 C mobo: N/A gpu: amdgpu temp: 49.0 C
Processes: 312 Uptime: 15m wakeups: 41039 Memory: total: 32 GiB note: est.
available: 30.67 GiB used: 3.09 GiB (10.1%) Init: systemd v: 254
pm: pacman pkgs: 1171 libs: 324 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date: 2023-06-26
Last full system update: 2023-08-06
