[Kernel Issue] Problema wifi driver mt7921l
Good evening everyone I have a motherboard with integrated wifi ROG STRIX B550-F GAMING WIFI II
i have a problem that does not see the wifi only etherneth is working
as drivers are mt7921L
how can i install this driver?
inxi
Kernel: 5.16.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=f859bf01-c2f5-46c4-bad5-086e6cd013d6 rw rootflags=subvol=@
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING WIFI II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 0305
date: 08/13/2021
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3235 high: 4285 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3259 2: 2999
3: 3424 4: 3110 5: 3010 6: 2999 7: 2998 8: 4285 9: 2999 10: 3078 11: 2999
12: 3249 13: 3800 14: 3551 15: 3001 16: 3000 bogomips: 121596
IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 08:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-2: Sunplus Innovation HD 720P webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1.1:4 chip-ID: 1bcf:2701
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: AMD RENOIR (DRM 3.44.0 5.16.10-zen1-1-zen LLVM 13.0.1)
v: 4.6 Mesa 21.3.6 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 1002:1637
v: kernel bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Sunplus Innovation HD 720P webcam type: USB
Sound Server-1: ALSA v: k5.16.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-1: MEDIATEK driver: N/A port: N/A bus-ID: 05:00.0 chip-ID: 14c3:0608
port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3 class-ID: 0200
Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-5:2 chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
Local Storage: total: 1.86 TiB used: 15.6 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Sabrent model: N/A
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT343.4
temp: 26.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: N/A
temp: 27.9 C scheme: GPT
used: 15.6 GiB (1.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.71 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 28.0 C
Processes: 390 Uptime: 0m wakeups: 0 Memory: 30.71 GiB
used: 2.39 GiB (7.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1424 lib: 354 Shell: fish
Garuda (2.5.5-1):
System install date:     2022-02-22
Last full system update: 2022-02-22
A web search for this chip ID led here:
so, it’s supported, it just needs some tweaking as outlined in the link above.
Thank you so much could you help me how to do it I'm new on arch
The above link provides two file names and content to put in those files. Create the files and copy-paste the content. There's really not much more help I can provide.
Thank you I try
Do I practically have to execute these commands?
sudo apt install build-essential flex bison
wget https://gitlab.com/jeremy53561/backports-11-26/-/raw/main/backports-5.15-rc6-1.tar.gz
tar -xvf backports-5.15-rc6-1.tar.gz
cd backports-5.15-rc6-1
make clean
make defconfig-wifi
make
sudo make install
cd /lib/firmware/mediatek
sudo wget https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/mediatek/WIFI_MT7961_patch_mcu_1_2_hdr.bin
sudo wget https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/plain/mediatek/WIFI_RAM_CODE_MT7961_1.bin
No, that's not what I linked to! :confused:
Look at it again.
I can't figure out how to do it
not and that you could show me step by step how to do it
forgive me
  • In a terminal, type sudo micro and the filename at 1 (and to be clear, cat is a command, not the filename), then press enter.
  • Copy-paste the text at 2. Save the file and exit.
  • Use sudo micro with the filename at 3.
  • Copy-paste the text at 4. Save the file and exit.
  • Reboot.
I did as described but it still doesn't go :sleepy:
The answer @jonathon linked is a few months old, perhaps those files are no longer required on the newest mainline kernel. I would install and test the linux-mainline kernel as it's possible it may now have better support for your adapter.
To install the linux-mainline kernel and headers:
sudo pacman -Syu linux-mainline linux-mainline-headers
You can switch to the newly installed kernel after a reboot via the grub "Advanced" boot menu. After installing a new kernel it is best not to uninstall your old kernel. It is always best to have at least two kernels installed in case one kernel experiences a problem booting. The LTS kernel is the recommended choice to keep installed as a backup kernel.
If the kernel change doesn't help then I guess it's back to creating the udev/modprobe rules. This Archwiki contains an entry on your adapter with far simpler instructions to implement the workaround:
https://wiki.archlinux.org/title/AYA_NEO_2021
modprobe rule
echo alias pci:v000014C3d00000608sv*sd*bc*sc*i* mt7921e >> /etc/modprobe.d/rz608.conf
udev rule
echo SUBSYSTEM=="drivers", DEVPATH=="/bus/pci/drivers/mt7921e", ATTR{new_id}="14c3 0608" >> /etc/udev/rules.d/99-rz608.rules
Simply execute both of those commands as root (su to root) and the files will automagically be created for you, (then reboot).
Can confirm it’s in 5.17rc5: kernel/git/torvalds/linux.git - Linux kernel source tree
(It’s not in 5.16.10: pci.c « mt7921 « mt76 « mediatek « wireless « net « drivers - kernel/git/stable/linux.git - Linux kernel stable tree)
Also worth mentioning, this particular wifi card, the hardware and/or the driver, in both Windows and Linux, is notoriously buggy.
Why would Asus put a crappy Wifi card on a premium-ish laptop?? Supply shortage? Intel AX210/201 is better.
from the terminal I ran these commands but it gives me an error
roberto@roberto in ~
λ echo alias pci:v000014C3d00000608svsdbcsci* mt7921e >> /etc/modprobe.d/rz608.conf
fish: No matches for wildcard 'pci:v000014C3d00000608svsdbcsci*'. See help expand.
roberto @ roberto in ~
λ sudo roberto @ roberto in ~
[:red_circle:] × sudo echo SUBSYSTEM == "drivers", DEVPATH == "/ bus / pci / drivers / mt7921e", ATTR {new_id} = "14c3 0608" >> /etc/udev/rules.d/99-rz608 .rules
warning: An error occurred while redirecting file '/etc/udev/rules.d/99-rz608.rules'
open: Permission denied
First of all I don't have a laptop but a desktop with ASUSTeK motherboard model: ROG STRIX B550-F GAMING WIFI II
then on windows also the band 6 works perfectly
This means you did not execute the command as “root” as I instructed you to do.
Do not use sudo, use su. Enter su in terminal first, then the root password, then run the commands.
I'm sorry you're right
So I ran the two commands as indicated, but I still can't see the wifi, only ethernet works
Your MOBO's Ethernet also has big issues and is not functional in Linux from other posts I'd read while searching your wifi.
ethernet works perfectly, I feel like drivers are missing wifi
You cannot grasp what is going on here. Your wifi to too new to have proper kernel support yet. The "driver" is included in the kernel. The kernels in general usage do not support this wifi adapter yet. Support is coming and is just around the corner.
Wait for kernel support to be added.
We are going around in circles here. There is nothing more to be done ATM. Nothing more can be added to this thread to resolve a lack a lack of kernel support. Research your purchase more carefully regarding full Linux support if you intend to run Linux.
I am closing this thread now as there is nothing further that can be done for you.
