System: Kernel: 5.14.5-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9139214a-2dcf-485e-bc20-c6aafd3ac5fc
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP Laptop 15-dw0xxx v: Type1ProductConfigId serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 85EF v: 36.41 serial: <filter> UEFI: Insyde v: F.44 date: 05/13/2021
Battery: ID-1: BAT1 charge: 7.1 Wh (18.2%) condition: 39.1/41.0 Wh (95.2%) volts: 10.7 min: 11.4
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter> status: Discharging
CPU: Info: Dual Core model: Intel Core i3-8145U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: C (12) microcode: EA cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18399
Speed: 3654 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 3654 2: 3785 3: 3832 4: 3862
Graphics: Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: IMC Networks HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 13d3:56c9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.5-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.35 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8821ce v: N/A modules: rtw88_8821ce,8821ce port: 3000 bus-ID: 02:00.0
IF-ID-1: enp0s20f0u1 state: unknown speed: -1 duplex: half mac: <filter>
Bluetooth: Device-1: HMD Global SDM439-QRD _SN:E3D1D4D2 type: USB driver: rndis_host v: kernel
bus-ID: 1-1:4 chip-ID: 2e04:c022 class-ID: 0a00 serial: <filter>
Report: bt-service: disabled note: tool can't run
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060
bus-ID: 00:17.0 chip-ID: 8086.282a rev: 30 class-ID: 0104
Drives: Local Storage: total: 931.51 GiB used: 48.12 GiB (5.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1C
Partition: ID-1: / raw-size: 70 GiB size: 70 GiB (100.00%) used: 26.54 GiB (37.9%) fs: btrfs
dev: /dev/sda8 maj-min: 8:8
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 580 KiB (0.1%) fs: vfat
dev: /dev/sda7 maj-min: 8:7
ID-3: /home raw-size: 125.52 GiB size: 123.05 GiB (98.03%) used: 21.57 GiB (17.5%) fs: ext4
dev: /dev/sda10 maj-min: 8:10
ID-4: /var/log raw-size: 70 GiB size: 70 GiB (100.00%) used: 26.54 GiB (37.9%) fs: btrfs
ID-5: /var/tmp raw-size: 70 GiB size: 70 GiB (100.00%) used: 26.54 GiB (37.9%) fs: btrfs
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda9
maj-min: 8:9
Sensors: System Temperatures: cpu: 41.0 C mobo: 29.8 C
Info: Processes: 192 Uptime: 25m wakeups: 1 Memory: 7.65 GiB used: 2.12 GiB (27.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1840 lib: 347
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Hi there, welcome!
Check this thread, it seems the same issue and it was solved.
It could be that you will need two lines in the blacklist file due to
It solved the problem..
Thanks a lot
