how can i downgrade my kernel to older version 5.18.16 im currently using 5.19.6-zen1-1-zen. After an update im facing issues on battery like battery % stuck at point and showing plugged in but still discharging.
Kernel: 5.19.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=7e3c1e48-613d-4794-8cdb-674078355a0a rw rootflags=subvol=@
resume=UUID=20fcabd1-88b4-42a4-b85d-4d69e3ec8dc7 loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming F15 FX506LI_FX506LI
Mobo: ASUSTeK model: FX506LI v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX506LI.310 date: 11/26/2021
ID-1: BAT1 charge: 33.4 Wh (79.1%) condition: 42.2/48.1 Wh (87.7%)
volts: 11.0 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
Info: model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 2 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1437 high: 2500 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 2500
4: 2500 5: 800 6: 800 7: 2500 8: 800 bogomips: 39999
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-3: Sonix USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 322e:202c class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Monitor-1: eDP-1 model: Najing CEC Panda 0x004d built: 2019
res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Sound Server-1: ALSA v: k5.19.6-zen1-1-zen running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: IMC Networks Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-14:4 chip-ID: 13d3:3563 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 476.94 GiB used: 20.39 GiB (4.3%)
model: 2210 MTFDHBA512QFD size: 476.94 GiB block-size: physical: 512 B
rev: P6MA001 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 69.73 GiB size: 69.73 GiB (100.00%) used: 20.39 GiB
(29.2%) fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 580 KiB
(0.2%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
ID-3: /home raw-size: 69.73 GiB size: 69.73 GiB (100.00%) used: 20.39 GiB
ID-4: /var/log raw-size: 69.73 GiB size: 69.73 GiB (100.00%) used: 20.39
GiB (29.2%) fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9
ID-5: /var/tmp raw-size: 69.73 GiB size: 69.73 GiB (100.00%) used: 20.39
ID-1: swap-1 type: zram size: 7.6 GiB used: 1.2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p8 maj-min: 259:8
System Temperatures: cpu: 43.0 C pch: 53.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 258 Uptime: 1h 9m wakeups: 4 Memory: 7.6 GiB used: 3.07 GiB
(40.4%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pacman: 1271 lib: 323
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.6-1):
System install date:     2022-09-04
Last full system update: 2022-09-04
