Kernel crash (6.14.7-zen2-1-zen)
Hi, I had a kernel panic shortly after booting. The only thing I was doing was texting on Telegram desktop, so I doubt it was something I did, and seems to be a kernel bug. I attach the content of the QR code the blue screen gave me below:
[QR code content]
In addition to that, here is my fastfetch in case it helps:
OS: Garuda Linux x86_64
Host: B650 PG Lightning
Kernel: 6.14.7-zen2-1-zen
Packages: 1695 (pacman) [stable), 10 (flatpak)
Shell: fish 4.0.2
Resolution: 1920x1080
DE: GNOME 48.1
WM: Mutter (Wayland)
WM Theme: Adwaita-dark
Theme: Adwaita-dark [GTK2/3/4]
Icons: Adwaita [GTK2/3/4]
Terminal: GNOME Terminal 3.56.2
Terminal Font: FiraCode Nerd Font Mono 12
CPU: AMD Ryzen 7 9800X3D (8) @ 5.27 GHz
GPU: AMD RX 9070/9070 XT [Discrete]
GPU: AMD Radeon Graphics [Integrated]
Use TTY if possible or live ISO, chroot and update the system. Another way is, use last working snapshot and update. If problem persists, restore the last snapshot and wait a few days and then try a new update.
Just post garuda-inxi, maybe use also the live ISO for that. Fastfetch did not help :slight_smile:
Hey Isma,
I had a similar issue a while back after a kernel update, using a previous snapshot worked as a quick fix. If you can get into TTY or a live ISO, try updating everything (sudo pacman -S-Syu) and maybe consider temporarily switching to the LTS kernel if the panic keeps happening. Curious to see your garuda-inxi` too, that should give more clues.
if, use sudo pacman -Syu but best is to use garuda-update or just upd in terminal
