It appears my system freezes when it tries to go to sleep and wake up, Kernel complains here is the output.
Is there a tracker to put this stuff in?
5.11.16-zen1-1-zen kernel
B450 Board
5600XT GPU
Apr 30 17:58:19 linuzo-amd64 kernel: [drm] PCIE GART of 512M enabled (table at 0x0000008000000000).
Apr 30 17:58:19 linuzo-amd64 kernel: [drm] PSP is resuming...
Apr 30 17:58:19 linuzo-amd64 kernel: [drm] reserve 0x900000 from 0x800f400000 for PSP TMR
Apr 30 17:58:19 linuzo-amd64 kernel: amdgpu 0000:0b:00.0: amdgpu: RAS: optional ras ta ucode is not available
Apr 30 17:58:19 linuzo-amd64 kernel: amdgpu 0000:0b:00.0: amdgpu: RAP: optional rap ta ucode is not available
Apr 30 17:58:19 linuzo-amd64 kernel: amdgpu 0000:0b:00.0: amdgpu: SMU is resuming...
Apr 30 17:58:19 linuzo-amd64 kernel: amdgpu 0000:0b:00.0: amdgpu: smu driver if version = 0x00000036, smu fw if version = 0x00000037, smu fw version = 0x002a3d00 (42.61.0)
Apr 30 17:58:19 linuzo-amd64 kernel: amdgpu 0000:0b:00.0: amdgpu: SMU driver if version not matched
Apr 30 17:58:21 linuzo-amd64 kernel: amdgpu 0000:0b:00.0: amdgpu: failed send message: EnableAllSmuFeatures (6) param: 0x00000000 response 0xffffffc2
Apr 30 17:58:21 linuzo-amd64 kernel: amdgpu 0000:0b:00.0: amdgpu: Failed to enable requested dpm features!
Apr 30 17:58:21 linuzo-amd64 kernel: amdgpu 0000:0b:00.0: amdgpu: Failed to setup smc hw!
Apr 30 17:58:21 linuzo-amd64 kernel: [drm:amdgpu_device_ip_resume_phase2 [amdgpu]] *ERROR* resume of IP block <smu> failed -62
Apr 30 17:58:21 linuzo-amd64 kernel: amdgpu 0000:0b:00.0: amdgpu: amdgpu_device_ip_resume failed (-62).
Apr 30 17:58:21 linuzo-amd64 kernel: snd_hda_intel 0000:0b:00.1: refused to change power state from D3hot to D0
Apr 30 17:58:21 linuzo-amd64 kernel: snd_hda_intel 0000:0b:00.1: CORB reset timeout#2, CORBRP = 65535
Apr 30 17:59:00 linuzo-amd64 kernel: amdgpu: Move buffer fallback to memcpy unavailable
Apr 30 17:59:00 linuzo-amd64 kernel: [drm:amdgpu_cs_ioctl [amdgpu]] *ERROR* Failed to process the buffer list -19!
Apr 30 17:59:10 linuzo-amd64 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* ring sdma0 timeout, signaled seq=147168, emitted seq=147170
Apr 30 17:59:10 linuzo-amd64 kernel: [drm:amdgpu_job_timedout [amdgpu]] *ERROR* Process information: process pid 0 thread pid 0
Apr 30 17:59:10 linuzo-amd64 kernel: amdgpu 0000:0b:00.0: amdgpu: GPU reset begin!
Apr 30 17:59:10 linuzo-amd64 kernel: ------------[ cut here ]------------
Apr 30 17:59:10 linuzo-amd64 kernel: kernel BUG at mm/slub.c:305!
Apr 30 17:59:10 linuzo-amd64 kernel: invalid opcode: 0000 [#1] PREEMPT SMP NOPTI
Apr 30 17:59:10 linuzo-amd64 kernel: CPU: 18 PID: 49414 Comm: kworker/18:0 Not tainted 5.11.16-zen1-1-zen #1
Apr 30 17:59:10 linuzo-amd64 kernel: Hardware name: System manufacturer System Product Name/ROG STRIX B450-F GAMING, BIOS 3103 06/17/2020
Apr 30 17:59:10 linuzo-amd64 kernel: Workqueue: events drm_sched_job_timedout [gpu_sched]
Apr 30 17:59:10 linuzo-amd64 kernel: RIP: 0010:__slab_free+0x1f9/0x500
Apr 30 17:59:10 linuzo-amd64 kernel: Code: 0f 84 d2 01 00 00 57 9d 0f 1f 44 00 00 4d 85 ff 75 73 45 84 c9 0f 84 92 00 00 00 48 8d 65 d8 5b 41 5c 41 5d 41 5e 41 5f 5d c3 <0f> 0b f7 47 08 00 0d 21 00 0f 84 25 fe ff ff 44 89 44 24 1c 48 89
Apr 30 17:59:10 linuzo-amd64 kernel: RSP: 0018:ffffb7590db87ca0 EFLAGS: 00010246
Apr 30 17:59:10 linuzo-amd64 kernel: RAX: ffff9e0e90ffa300 RBX: 000000008020001c RCX: ffff9e0e90ffa200
Apr 30 17:59:10 linuzo-amd64 kernel: RDX: ffff9e0e90ffa200 RSI: ffffe8fd4443fe00 RDI: ffff9e0e80043600
Apr 30 17:59:10 linuzo-amd64 kernel: RBP: ffffb7590db87d40 R08: 0000000000000001 R09: ffffffffc06895b4
Apr 30 17:59:10 linuzo-amd64 kernel: R10: ffff9e0e90ffa200 R11: ffffb7590db87a00 R12: ffffe8fd4443fe00
Apr 30 17:59:10 linuzo-amd64 kernel: R13: ffff9e0e90ffa200 R14: ffff9e0e80043600 R15: ffff9e0e818be0c8
Apr 30 17:59:10 linuzo-amd64 kernel: FS: 0000000000000000(0000) GS:ffff9e118ee80000(0000) knlGS:0000000000000000
Apr 30 17:59:10 linuzo-amd64 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Apr 30 17:59:10 linuzo-amd64 kernel: CR2: 0000560ab0229f98 CR3: 0000000118c10000 CR4: 0000000000350ee0
Apr 30 17:59:10 linuzo-amd64 kernel: Call Trace:
Apr 30 17:59:10 linuzo-amd64 kernel: ? kfd_gtt_sa_free+0x56/0x80 [amdgpu]
Apr 30 17:59:10 linuzo-amd64 kernel: ? kernel_queue_uninit+0x84/0xf0 [amdgpu]
Apr 30 17:59:10 linuzo-amd64 kernel: kernel_queue_uninit+0x84/0xf0 [amdgpu]
Apr 30 17:59:10 linuzo-amd64 kernel: stop_cpsch+0xa0/0xc0 [amdgpu]
Apr 30 17:59:10 linuzo-amd64 kernel: kgd2kfd_pre_reset+0x56/0x80 [amdgpu]
Apr 30 17:59:10 linuzo-amd64 kernel: amdgpu_device_gpu_recover.cold+0x36e/0x98a [amdgpu]
Apr 30 17:59:10 linuzo-amd64 kernel: amdgpu_job_timedout+0x121/0x140 [amdgpu]
Apr 30 17:59:10 linuzo-amd64 kernel: drm_sched_job_timedout+0x64/0xe0 [gpu_sched]
Apr 30 17:59:10 linuzo-amd64 kernel: process_one_work+0x214/0x3e0
Apr 30 17:59:10 linuzo-amd64 kernel: worker_thread+0x4d/0x470
Apr 30 17:59:10 linuzo-amd64 kernel: ? flush_delayed_work+0x40/0x40
Apr 30 17:59:10 linuzo-amd64 kernel: kthread+0x181/0x1b0
Apr 30 17:59:10 linuzo-amd64 kernel: ? __kthread_init_worker+0x50/0x50
Apr 30 17:59:10 linuzo-amd64 kernel: ret_from_fork+0x22/0x30
Apr 30 17:59:10 linuzo-amd64 kernel: Modules linked in: ufs hfsplus hfs cdrom minix msdos jfs xfs ext4 crc16 mbcache jbd2 dm_mod hid_logitech_hidpp zram snd_usb_audio snd_usbmidi_lib snd_rawmidi snd_seq_device hid_logitech_dj mc snd_hda_>
Apr 30 17:59:10 linuzo-amd64 kernel: xhci_pci_renesas nouveau mxm_wmi wmi radeon i915 video intel_agp intel_gtt amdgpu gpu_sched i2c_algo_bit drm_ttm_helper ttm drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops cec drm agpgart
Apr 30 17:59:10 linuzo-amd64 kernel: ---[ end trace 78437c3316e0c71d ]--- ~~~
Some more info for you DEVS!
System: Kernel: 5.11.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f0e58ef5-65bf-462f-8f31-865d2f723b45 rw
systemd.unified_cgroup_hierarchy=1 resume=UUID=8e479d1e-603f-4e5e-b380-332e9e780384 loglevel=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx serial: <filter> UEFI: American Megatrends
v: 3103 date: 06/17/2020
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus serial: <filter>
CPU: Info: 12-Core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 family: 17 (23) model-id: 71 (113)
stepping: 0 microcode: 8701021 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 182402
Speed: 3604 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 3604 2: 3372 3: 3599 4: 3600 5: 3598
6: 3594 7: 3815 8: 3598 9: 3599 10: 3602 11: 3600 12: 3599 13: 3600 14: 3601 15: 3980 16: 3497 17: 3551 18: 3591
19: 3597 20: 3594 21: 3591 22: 3599 23: 3600 24: 3599
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 0b:00.0 chip-ID: 1002:731f class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Monitor-1: DisplayPort-0 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.40.0 5.11.16-zen1-1-zen LLVM 11.1.0) v: 4.6 Mesa 21.0.3
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus-ID: 0b:00.1
chip-ID: 1002:ab38 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media USB Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2
chip-ID: 0d8c:0012 class-ID: 0300
Sound Server-1: ALSA v: k5.11.16-zen1-1-zen running: yes
Sound Server-3: JACK v: 0.125.0 running: no
Sound Server-4: PulseAudio v: 14.2 running: yes
Sound Server-5: PipeWire v: 0.3.26 running: no
Network: Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel port: e000 bus-ID: 04:00.0
Drives: Local Storage: total: 2.5 TiB used: 77.61 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: 111110WD temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SA2000M8250G size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: S5Z42105 temp: 34.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD20EARS-19MVWB0 size: 1.82 TiB block-size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: AB51 scheme: GPT
Partition: ID-1: / raw-size: 448.33 GiB size: 448.33 GiB (100.00%) used: 77.61 GiB (17.3%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:4
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:3
ID-3: /home raw-size: 448.33 GiB size: 448.33 GiB (100.00%) used: 77.61 GiB (17.3%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:4
ID-4: /var/log raw-size: 448.33 GiB size: 448.33 GiB (100.00%) used: 77.61 GiB (17.3%) fs: btrfs
dev: /dev/nvme0n1p2 maj-min: 259:4
ID-5: /var/tmp raw-size: 448.33 GiB size: 448.33 GiB (100.00%) used: 77.61 GiB (17.3%) fs: btrfs
ID-1: swap-1 type: partition size: 17.18 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5
ID-2: swap-2 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-10: swap-10 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-11: swap-11 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-12: swap-12 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-13: swap-13 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
ID-14: swap-14 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram12
ID-15: swap-15 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram13
ID-16: swap-16 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram14
ID-17: swap-17 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram15
ID-18: swap-18 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram16
ID-19: swap-19 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram17
ID-20: swap-20 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram18
ID-21: swap-21 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram19
ID-22: swap-22 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram20
ID-23: swap-23 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram21
ID-24: swap-24 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram22
ID-25: swap-25 type: zram size: 666.3 MiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram23
Sensors: System Temperatures: cpu: 49.9 C mobo: 0 C gpu: amdgpu temp: 35.0 C mem: 38.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 820
Info: Processes: 436 Uptime: 23m wakeups: 5 Memory: 15.62 GiB used: 3.23 GiB (20.7%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1597 lib: 489 Shell: Bash v: 5.1.4
running-in: xfce4-terminal inxi: 3.3.04 ~~~
Please read Garuda wiki "Reporting bugs"
format your posts with three ~ before and after the terminal output, please
Thanks I read the wiki about reporting bugs and since its with the linux-zen kernel which to my knowledge is a garuda feature, it says to report on the forum giving as much info needs to fix the issue.
Just trying to help make the best distro for this community
Have you tried setting different cstates in your bios.
Sometimes different grub kernel boot parameters can help with sleep issues as well.
If it truly is a kernel bug that’s really out of Garuda’s hands, as Garuda has nothing to do with Linux kernel development.
From the Garuda Wiki article you linked:
Any software experiencing bugs that can not be resolved should be reported to its upstream project.
linuzo:
5.11.16-zen1-1-zen
5.12.x is almost upon us (5.12.1 is currently in Arch testing). It will be worth checking whether there’s a fix already present.
linuzo:
5600XT GPU
There was a recent bug report to do with linux-firmware. Is your system fully up-to-date?
