Hello!
Yesterday I have updated my system, linux-zen kernel has changed from 5.18.16 to 5.19.1
After rebooting my bluetooth mouse didn't work, there were no bluetooth adapter in the system. Also, there were no sound devices at all. When I have restored my system from snapshot, everything worked properly. After re-updating the result was the same - no bluetooth and audio device. Linux kernel (not-zen) can't see bluetooth and sound devices either.
Linux-lts kernel works fine.
What's wrong with new kernel and my system? What can I do?
garuda-inxi output:
Kernel: 5.19.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=2617e99d-fdce-4db0-be58-080633575b74
Desktop: KDE Plasma v: 5.25.4 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HUAWEI product: KPL-W0X v: M1B serial: <superuser required>
Mobo: HUAWEI model: KPL-W0X-PCB v: M1B serial: <superuser required> UEFI: HUAWEI v: 1.24
date: 04/11/2022
ID-1: BAT1 charge: 53.3 Wh (100.0%) condition: 53.3/56.3 Wh (94.6%) volts: 8.1 min: 7.6
model: DYNAPACK HB4593R1ECW type: Li-ion serial: <filter> status: not charging cycles: 104
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 0x11 (17) stepping: 0
microcode: 0x8101007
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 384 KiB desc: d-4x32
KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2620 high: 3286 min/max: 1600/2000 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 2633 2: 2000 3: 2628 4: 2626 5: 2635
6: 2000 7: 3286 8: 3157 bogomips: 31940
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series] vendor: Huawei
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 02:00.0
chip-ID: 1002:15dd class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14d4 built: 2016 res: 1920x1080 hz: 60
dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.47 5.19.1-zen1-1-zen)
v: 4.6 Mesa 22.1.6 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei driver: N/A
alternate: snd_hda_intel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.1 chip-ID: 1002:15de
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Huawei driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_sof_amd_renoir pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Huawei driver: N/A alternate: snd_hda_intel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.19.1-zen1-1-zen running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
Local Storage: total: 238.47 GiB used: 125.93 GiB (52.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON model: CV8-8E256 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 402 scheme: GPT
ID-1: / raw-size: 188.36 GiB size: 188.36 GiB (100.00%) used: 125.89 GiB (66.8%) fs: btrfs
dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 34.8 MiB (36.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 188.36 GiB size: 188.36 GiB (100.00%) used: 125.89 GiB (66.8%) fs: btrfs
ID-4: /var/log raw-size: 188.36 GiB size: 188.36 GiB (100.00%) used: 125.89 GiB (66.8%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-5: /var/tmp raw-size: 188.36 GiB size: 188.36 GiB (100.00%) used: 125.89 GiB (66.8%)
ID-1: swap-1 type: zram size: 6.68 GiB used: 2 MiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 51.9 C mobo: N/A gpu: amdgpu temp: 51.0 C
Processes: 259 Uptime: 1m wakeups: 1 Memory: 6.68 GiB used: 2.34 GiB (35.1%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages:
pacman: 1649 lib: 470 Client: shell wrapper v: 5.1.16-release inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2021-04-01
Last full system update: 2022-08-15
Failed units: bluetooth-autoconnect.service systemd-guest-user.service
