Hello.
Since the latest updates, Garuda Linux with KDE Plasma was impossible to use in my quite new LG Gram laptop. The GUI self-destructed all the time: the animations stalled, all the Plasma DE stalled for seconds at a time, the wallpaper disappeared, the windows tittle bars disappeared... Continually. It was impossible to use, so I rolled back to a previous Snapper snapshot and kept going like that.
Today I finally had some time to investigate further and this is what I found: I installed the LTS kernel and choosing it in the grub menu, everything works perfectly. Otherwise, with the 5.15.2.zen1-1 kernel, the chaos ensues. And so does with the 5.15.2.arch1-1 and the 5.16rc1-1 kernels, which I tried just to have more info.
So this post is mainly to report this.
Also, is there any way not to have to choose the LTS kernel every time I boot? I have btrfs.
Cheers.
╰─λ inxi -Faz
System: Kernel: 5.10.79-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=899964ab-8512-415a-bad5-d5f6571a0f0f rw
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LG product: 17Z90P-G.AA79B v: 0.1 serial: <filter> Chassis: type: 10 v: 0.1
Mobo: LG model: 17Z90P v: FAB1 serial: <filter> UEFI: Phoenix v: T2ZF0320 X64 date: 04/23/2021
Battery: ID-1: CMB0 charge: 50.9 Wh (65.1%) condition: 78.2/80.0 Wh (97.7%) volts: 8.0 min: 7.7 model: LG LGC-LGC
type: Li-ion serial: <filter> status: Discharging cycles: 10
CPU: Info: Quad Core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP arch: Tiger Lake family: 6
model-id: 8C (140) stepping: 1 microcode: 8A cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44851
Speed: 941 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 941 2: 1070 3: 1099 4: 909 5: 822 6: 1231
7: 776 8: 1141
Graphics: Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: LG driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Realtek LG Camera type: USB driver: uvcvideo bus-ID: 3-2:2 chip-ID: 0bda:5641 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.7x16.7") s-diag: 798mm (31.4")
Monitor-1: eDP1 res: 2560x1600 hz: 60 dpi: 176 size: 370x230mm (14.6x9.1") diag: 436mm (17.2")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: LG driver: sof-audio-pci
alternate: snd_hda_intel,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.10.79-1-lts running: yes
Network: Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:a0f0
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:4 chip-ID: 8087:0026
Drives: Local Storage: total: 953.87 GiB used: 23.96 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41000C20
temp: 32.9 C scheme: GPT
Partition: ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 23.91 GiB (23.9%) fs: btrfs dev: /dev/nvme0n1p8
maj-min: 259:8
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 57.5 MiB (22.4%) fs: vfat
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%) used: 23.91 GiB (23.9%) fs: btrfs
dev: /dev/nvme0n1p8 maj-min: 259:8
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%) used: 23.91 GiB (23.9%) fs: btrfs
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%) used: 23.91 GiB (23.9%) fs: btrfs
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p7
maj-min: 259:7
ID-2: swap-2 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 32.0 C mobo: N/A
Info: Processes: 241 Uptime: 6m wakeups: 303 Memory: 15.33 GiB used: 3.04 GiB (19.8%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1298 lib: 327 Shell: fish
v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
