I tried using chsh and the checkboxs in Garuda Settings Manager, it says the shell is zsh but it's still fish no matter what I do
If you set your login shell to zsh then your login shell is zsh . Check which shell is being launched by your terminal emulator.
If you looked at the forum before posting you’d find similar questions have been posted several times:
Discourse even points out similar threads!
