Keeping it Simple with Garuda Linux
I apologize in advance if I posted this in the wrong section. I spent a week trying to figure out why my external monitor’s brightness could not be adjusted. today is Friday and sunny and I happened to notice the brightness icon in the sys tray .
I clicked on it and like magic, there is was! :rofl: :exploding_head:
So moral of the story, always troubleshoot with the simplest steps first. :nerd_face:
I had issues with the old AX200 WIFi and a couple of minor issues. However, this Forum is so vast with solutions from other posts that I barly have to google. ChatGPT is starting to miss me I think.
So that means that I don’t post often but am in here every day reading up on more knowledge.
I’m a Developer so my Linux Laptop is a workhorse like you wouldn’t believe!
i’m running Garuda KDE Dr460nized latest and greatest with 11th gen intel core i7-1165G7 clocking at 2.8 Ghz with Mesa intel Xe Graphics on a clevo Laptop with the led multicolor keyboard (yup I got that working too. Thanks Forum!). Have a great weekend!
and have fun :slight_smile:
BTW :wink:
Just post the garuda-inxi from terminal :smiley:
I should have yes! Here you go :sunglasses:
  Kernel: 6.11.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=326ffc0f-ad3f-4fd9-bc45-af9249ab2048 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.2.1 tk: Qt v: N/A info: frameworks v: 6.7.0
  Type: Laptop System: Notebook product: NLx0MU v: N/A
  Mobo: Notebook model: NLx0MU serial: <superuser required>
    uuid: <superuser required> UEFI: INSYDE v: 1.07.08N date: 03/08/2022
  ID-1: BAT0 charge: 20.9 Wh (69.0%) condition: 30.3/36.2 Wh (83.7%)
    volts: 12.0 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
    status: not charging
  Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
    microcode: 0xB8
    smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
    desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1176 min/max: 400/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 1176 2: 1176 3: 1176 4: 1176 5: 1176 6: 1176
    7: 1176 8: 1176 bogomips: 44851
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: CLEVO/KAPOK
    driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
    built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
    HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
  Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 5986:9102
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.3
  Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
    drv: iris x11: drv: iris
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
    device-ID: 8086:9a49 memory: 7.52 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.295 layers: 9 device: 0 type: integrated-gpu name: Intel
    Xe Graphics (TGL GT2) driver: mesa intel v: 24.2.5-arch1.1
    device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.2.5-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: CLEVO/KAPOK
    bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
  Device-2: C-Media USB Advanced Audio Device
    lanes: 1 mode: 1.1 bus-ID: 3-6:3 chip-ID: 0d8c:0266 class-ID: 0300
  API: ALSA v: k6.11.4-zen1-1-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
    bus-ID: 0000:00:1f.6 chip-ID: 8086:15fc class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel
    bus-ID: 0000:02:00.0 chip-ID: 8086:2723 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0029
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 476.94 GiB used: 43.33 GiB (9.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
    lanes: 4 tech: SSD serial: <filter> fw-rev: 004C temp: 34.9 C scheme: GPT
    used: 43.33 GiB (9.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 15.4 GiB used: 28.2 MiB (0.2%) priority: 100
  System Temperatures: cpu: 47.0 C mobo: N/A
  Memory: total: 16 GiB available: 15.4 GiB used: 4.66 GiB (30.2%)
  Processes: 278 Power: uptime: 3h 39m states: freeze,mem,disk
    suspend: s2idle avail: deep wakeups: 4 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 2038 libs: 586 tools: octopi,paru Compilers:
    clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.37
  System install date:     2024-10-18
  Last full system update: 2024-10-31
