╭─erickpardus@Carlayka in ~ took 13ms
╰─λ garuda-inxi
Kernel: 6.4.11-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=df25e11d-5ac5-404d-829f-ed5d08c21133 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 7 dm:
1: LightDM v: 1.32.0 2: SDDM note: stopped Distro: Garuda Linux
Type: Laptop System: Notebook product: NJx0PU v: N/A
serial: <superuser required> Chassis: No Enclosure type: 10
Mobo: Notebook model: NJx0PU serial: <superuser required> UEFI: INSYDE
v: 1.07.04 date: 03/03/2023
ID-1: BAT0 charge: 44.1 Wh (100.0%) condition: 44.1/44.4 Wh (99.2%)
volts: 16.4 min: 14.8 model: Notebook BAT type: Li-ion serial: <filter>
status: full
Info: model: 12th Gen Intel Core i7-1255U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x42C
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1837 high: 2600 min/max: 400/4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 763 2: 2600 3: 911 4: 849
5: 2600 6: 587 7: 2600 8: 2600 9: 2600 10: 742 11: 2600 12: 2600
bogomips: 62668
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:46a8 class-ID: 0300
Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 5986:214c
compositor: kwin_x11 driver: X: loaded: modesetting unloaded: vesa
alternate: fbdev,intel dri: iris gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1775 built: 2021 res: 1920x1080
hz: 60 dpi: 128 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: C-Media USB Advanced Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 0d8c:0287 class-ID: 0300
API: ALSA v: k6.4.11-zen2-1-zen status: kernel-api tools: N/A
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
IF-ID-1: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 698.65 GiB used: 33.78 GiB (4.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 31.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
tech: SSD serial: <filter> fw-rev: 2B6Q
ID-1: / raw-size: 112.54 GiB size: 112.54 GiB (100.00%)
used: 33.78 GiB (30.0%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 576 KiB (0.0%)
fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 112.54 GiB size: 112.54 GiB (100.00%)
ID-4: /var/log raw-size: 112.54 GiB size: 112.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 112.54 GiB size: 112.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.51 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 68.0 C mobo: N/A
Processes: 335 Uptime: 1h 52m wakeups: 1405 Memory: total: 64 GiB
available: 62.51 GiB used: 6.57 GiB (10.5%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: 1913 pm: pacman pkgs: 1828 libs: 416 tools: pamac,paru pm: rpm
pkgs: 0 pm: flatpak pkgs: 78 pm: snap pkgs: 7 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.29
waarschuwing:database file for 'custom' does not exist (use '-Sy' to download)
System install date: 2023-08-21
Last full system update: 2023-08-24
garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Hi,
I edit your text, please use three ~ in first and last line, like
Terminal text
then others can easily expand or copy the text.
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
This might be a problem. I would presume an update is in order. After such a long time, please backup your data first.
Then run garuda-update
Or wait for a guru tip, I am new here ![]()
╰─λ garuda-update
[sudo] wachtwoord voor erickpardus:
:: Pakket-databases synchroniseren...
garuda 83,7 KiB 89,5 KiB/s 00:01 [--------------------------------------------------------] 100%
core 132,2 KiB 405 KiB/s 00:00 [--------------------------------------------------------] 100%
extra 8,4 MiB 3,89 MiB/s 00:02 [--------------------------------------------------------] 100%
multilib is bijgewerkt
chaotic-aur 2,5 MiB 2,41 MiB/s 00:01 [--------------------------------------------------------] 100%
downloaden van custom.db mislukt
fout:kan het bestand 'custom.db' niet ophalen van schijf : Couldn't open file /home/custompkgs/custom.db
fout:alle databases synchroniseren mislukt (onverwachte fout)
chaotic-aur 2,5 MiB 2,02 MiB/s 00:01 [########################################################] 100%
garuda aan het downloaden...
core aan het downloaden...
extra aan het downloaden...
multilib aan het downloaden...
chaotic-aur aan het downloaden...
custom aan het downloaden...
--> Applying keyring updates before starting full system update..
waarschuwing:archlinux-keyring-20240208-1 is up to date -- overslaan
waarschuwing:chaotic-keyring-20230616-1 is up to date -- overslaan
waarschuwing:garuda-hotfixes-1.1.2-1 is up to date -- overslaan
er valt niets te doen
garuda 83.7 KiB 117 KiB/s 00:01 [--------------------------------------------------------] 100%
core 132.2 KiB 308 KiB/s 00:00 [--------------------------------------------------------] 100%
extra 8.4 MiB 4.43 MiB/s 00:02 [--------------------------------------------------------] 100%
multilib 142.5 KiB 352 KiB/s 00:00 [--------------------------------------------------------] 100%
chaotic-aur 2.5 MiB 2.97 MiB/s 00:01 [--------------------------------------------------------] 100%
custom.db failed to download
error: failed retrieving file 'custom.db' from disk : Couldn't open file /home/custompkgs/custom.db
error: failed to synchronize all databases (unexpected error
Don’t know if one of these 85 packages is the trouble maker
But this one for shure
Check your
/etc/pacman.conf
and garudafy it again, look for a line with custom.db and comment it out and run garuda-update again.
But be aware of the big KDE upgrade, prepare yourself by reading this KDE Upgrade Guide first
╭─erickpardus@Carlayka in ~ took 10ms
╰─λ /etc/pacman.conf
bash: /etc/pacman.conf: Toegang geweigerd
╭─erickpardus@Carlayka in ~ took 8ms
You have to open it in an editor, one you are familiar with,
you’ll be looking for a section that looks similar to this:
[custom]
Server = file:///Home/builds
just comment all those lines with a # (Pound sign)
like
#[custom]
#Server = file:///Home/builds
Danke sch"on fur deine antwort…aber ich verstehe nicht was ich sollte machen…
╭─erickpardus@Carlayka in ~ took 14ms
╰─λ [custom]
find-the-command: “[custom]” is not found locally, searching in repositories…
find-the-command: command not found: “[custom]”
find-the-command: “Server” is not found locally, searching in repositories…
find-the-command: command not found: "Serv
- Oeffne Konsole,
- type “micro /etc/pacman.conf” and hit enter
- editor oeffnet die Datei,
scrolle zum Ende der Text Datei bis zur section [CUSTOM],
dann fuege zum beginn jeder Reihe ein # , das ist shift+3, ein, angefangen mit [CUSTOM}
Es sollte dann so aussehen.
#[CUSTOM]
#Server = file://home/custompkgs
Dann hit ctrl+S und dann ctrl+Q
Maybe on your keybord, here it is §, # is left from enter. ![]()
IDK, but maybe it differ on nederland keyboards
ok, was going by my keyboard, use what ever prints the pound character
Thank you/danke sehr SGS…!!
