KDE Wayland Session will not use NVIDIA GPU
Hello, all!
Given Wayland is now the default KDE session, I decided to give it a shot getting set up. I have never been able to get it to recognize the resolution of my Samsung Odyssey G9. I write this now from 1280x720 resolution. No matter what I do, my displays are not detected under Wayland (detected fine under X11, both of them).
After much searching, I found this thread: [SOLVED] External monitor not detected under Wayland (KDE Plasma) / Newbie Corner / Arch Linux Forums
which aligns most to my issue.
Attempt to solve:
 glxinfo | grep "OpenGL renderer"
OpenGL renderer string: llvmpipe (LLVM 16.0.6, 256 bits)
in /etc/default/grub-btrfs/config I added
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nvidia-drm-modset=1"
which is just below
GRUB_BTRFS_VERSION=4.12-master-2023-04-28T16:26:00+00:00
after
sudo grub-mkconfig -o /boot/grub/grub.cfg
and/or
sudo update grub
and restarts, no dice. I still get OpenGL renderer string: llvmpipe (LLVM 16.0.6, 256 bits)
Weirdly,
prime-run glxinfo -B | grep "OpenGL vendor string"
X Error of failed request:  BadAlloc (insufficient resources for operation)
Major opcode of failed request:  149 (GLX)
Minor opcode of failed request:  5 (X_GLXMakeCurrent)
Serial number of failed request:  0
Current serial number in output stream:  29
and of course, the kicker. My 3080ti sitting at room temperature running itself a lil xorg.
╰─λ nvidia-smi
Thu Nov 23 02:45:20 2023
| NVIDIA-SMI 545.29.02              Driver Version: 545.29.02    CUDA Version: 12.3     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  NVIDIA GeForce RTX 3080 Ti     Off | 00000000:0B:00.0  On |                  N/A |
|  0%   38C    P8              29W / 350W |     64MiB / 12288MiB |      0%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|    0   N/A  N/A      2034      G   /usr/lib/Xorg                                58MiB |
My garuda-inxi:
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e7f8b539-4888-4d96-a7fb-dc22ce7aba7f rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Mobo: ASUSTeK model: TUF GAMING B550M-E WIFI v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2403
date: 06/16/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4200 min/max: 2200/5361 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 4200 2: 4200 3: 4200
4: 4200 5: 4200 6: 4200 7: 4200 8: 4200 9: 4200 10: 4200 11: 4200 12: 4200
13: 4200 14: 4200 15: 4200 16: 4200 bogomips: 134407
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: Shenzhen Colorful
Yugong and Development driver: nvidia v: 545.29.02
2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 0b:00.0 chip-ID: 10de:2208 class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-3.2:3
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
compositor: kwin_wayland driver: X: loaded: modesetting,nouveau,nvidia
alternate: fbdev,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: Unknown-1 res: 1280x720 size: N/A modes: N/A
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia wayland:
drv: swrast x11: drv: swrast inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 30.52 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3080 Ti driver: nvidia v: 545.29.02 device-ID: 10de:2208
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: NVIDIA GA102 High Definition Audio vendor: Shenzhen Colorful
Yugong and Development driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:1aef class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3
chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
Device-4: Logitech BRIO Ultra HD Webcam
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api with: aoss
speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 0a:00.0 chip-ID: 10ec:8168
IF: enp10s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:7 chip-ID: 8087:0029
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 3.64 TiB used: 22.26 GiB (0.6%)
model: WD BLACK SN850X 4000GB size: 3.64 TiB block-size: physical: 512 B
fw-rev: 624331WD temp: 48.9 C scheme: GPT
ID-1: / raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 22.26 GiB (0.6%)
ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 22.26 GiB (0.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
ID-5: /var/tmp raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
System Temperatures: cpu: 39.4 C mobo: N/A
Processes: 343 Uptime: 9m wakeups: 0 Memory: total: 32 GiB
available: 31.26 GiB used: 4.02 GiB (12.9%) Init: systemd v: 254
pm: pacman pkgs: 1799 libs: 529 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date:     2023-11-23
Last full system update: 2023-11-23
Other feedback:
sudo dmesg | grep nvidia
[sudo] password for wayward:
[    2.783306] nvidia: loading out-of-tree module taints kernel.
[    2.783312] nvidia: module license 'NVIDIA' taints kernel.
[    2.783315] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[    2.783316] nvidia: module license taints kernel.
[    3.146651] nvidia-nvlink: Nvlink Core is being initialized, major device number 235
[    3.147695] nvidia 0000:0b:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=none
[    3.206999] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia,inheriting taint.
[    3.210082] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  545.29.02  Thu Oct 26 20:52:21 UTC 2023
[    3.212210] [drm] [nvidia-drm] [GPU ID 0x00000b00] Loading driver
[    3.212212] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:0b:00.0 on minor 1
[    3.296236] nvidia-uvm: Loaded the UVM driver, major device number 511.
Thanks in advance for any help, and sorry in advance if I missed something obvious… but im really struggling here.
You can use the kernel boot parameter nvidia-drm.modeset=1 with
sudo cp /etc/default/grub /etc/default/grub.bak && sudo sed '/^GRUB_CMDLINE_LINUX_DEFAULT=/s/"$/ nvidia-drm.modeset=1 "/g' -i /etc/default/grub && sudo update-grub
PS:
I’ve reformatted your post to be more readable.
terminal text like this
Appears like this
If you get used to it it’s quite easy (you can give a look editing with the pencil button), an much easier than correct it after :wink:
Hello! I tried the command you gave me, and it returned the following output:
wayward@wayward in ~ as 🧙 took 98ms
╰─λ sudo cp /etc/default/grub /etc/default/grub.bak && sudo sed '/^GRUB_CMDLINE_LINUX_DEFAULT=/s/"$/ nvidia-drm.modeset=1 "/g' -i /etc/default/grub && sudo update-grub```
'sudo cp /etc/default/grub /etc/default/grub.bak && sudo sed '/^GRUB_CMDLINE_LINUX_DEFAULT=/s/"$/ nvidia-drm.modeset=1 "/g' -i /etc/default/grub && sudo update-grub
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-zen-fallback.img
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-11-23 02:25:21 | @/.snapshots/12/snapshot | post | garuda-nvidia-prime-config garuda-video-linux-config intel-gmmlib intel- |
Found snapshot: 2023-11-23 02:25:20 | @/.snapshots/11/snapshot | pre  | pacman -S garuda-nvidia-prime-config  |
Found snapshot: 2023-11-23 02:14:07 | @/.snapshots/10/snapshot | post | nvidia-prime                          |
Found snapshot: 2023-11-23 02:14:07 | @/.snapshots/9/snapshot  | pre  | pacman -S extra/nvidia-prime          |
Found snapshot: 2023-11-23 02:12:06 | @/.snapshots/8/snapshot  | post | plymouth                              |
Found snapshot: 2023-11-23 02:12:05 | @/.snapshots/7/snapshot  | pre  | pacman -S --noconfirm plymouth        |
Found snapshot: 2023-11-23 02:07:00 | @/.snapshots/6/snapshot  | post | nvidia-dkms                           |
Found snapshot: 2023-11-23 02:05:58 | @/.snapshots/5/snapshot  | pre  | pacman -Syyu nvidia-dkms              |
Found snapshot: 2023-11-23 01:46:45 | @/.snapshots/4/snapshot  | post | alsa-card-profiles amd-ucode android-tools android-udev aom appstream ap |
Found snapshot: 2023-11-23 01:44:03 | @/.snapshots/3/snapshot  | pre  | pacman -Su --ignore jre-openjdk-headless grub                            |
Found 10 snapshot(s)
Unmount /tmp/grub-btrfs.tFV5nnk7S9 .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
When I restart the computer and try nvidia-smi or glxinfo | grep “OpenGL renderer”
I am still seeing the GPU at idle and: OpenGL renderer string: llvmpipe (LLVM 16.0.6, 256 bits)
Thank you for the helpful reply! I tried to modify it the second time by changing the path to grub with the path to grub-btrfs to see if that would help, but it simply caused an error.
PS thank you also for teaching me the formatting
I’m afraid you’ll need an Nvidia user here… :slight_smile:
My post was only aimed to set the kernel boot parameter correctly in /etc/default/grub instead of /etc/default/grub-btrfs/config as in the first post.
There must be clearly something else to be adjusted…
Well thank you for setting me on the right course with grub; I will hold my breath for someone else with some knowledge of this, and update my post if I find an answer in the meantime
The driver needs that to function, even if you don’t use any Xwayland apps, the driver revolves around messing with x11 to work.
it’s a shame you can’t try wayland on kde, the proprietary driver has been playing nicely on my machine, i think your problem sits between wayland and the driver, your best choice is to wait.
