Hey there!
I’m currently experiencing an issue with the KDE panels on my Garuda Linux installation. Specifically, the right-click functionality anywhere on panels isn’t working. I am using HiDPI displays and wayland (with a zoomlevel of 200%).
Just nothing appears. So I also can not show any screenshot… since nothing is to see
That’s very annoying when managing shortcuts and tasks. (Basically not possible.) When logging out of Wayland and into X11 it is working. But then some other tools have issues (e.g. screensharing tools). And it (X11) also causes issues with the general scaling.
I found this: 1958130 – KDE Plasma Wayland right-clicking on panels does not work
But it wasn’t resolved. Just closed.
Do you have any idea what could cause that?
Kernel: 6.5.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=3a0c7d8b-509b-499f-9089-c01905828923 rw rootflags=subvol=@
quiet hush rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
systemd.unified_cgroup_hierarchy=1 sysrq_always_enabled=1
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASRock model: X670E PG Lightning
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.28
date: 05/22/2023
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
model-id: 0x61 (97) stepping: 2 microcode: 0xA689803
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 863 high: 4916 min/max: 400/5050 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 3292
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 4916 15: 400 16: 400 bogomips: 134146
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-2 empty: HDMI-A-1,HDMI-A-2 bus-ID: 03:00.0
chip-ID: 1002:744c class-ID: 0300
Device-2: AMD Raphael driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-3, DP-4, DP-5, HDMI-A-3 bus-ID: 19:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 45.0 C
gpu: amdgpu,amdgpu d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-1 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-2 pos: primary,left res: 1920x1080 size: N/A modes: N/A
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XTX (gfx1100
LLVM 16.0.6 DRM 3.54 6.5.7-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.264 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV GFX1100) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:744c surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 23.2.1-arch1.2 device-ID: 1002:164e
16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 19:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 19:00.6
Device-4: Logitech PRO X Wireless Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 3-10:2 chip-ID: 046d:0aba class-ID: 0300
API: ALSA v: k6.5.7-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0
IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
Local Storage: total: 7.28 TiB used: 195.55 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD BLACK
SN850X HS 2000GB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 620311WD
temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2U9104
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 931.44 GiB size: 931.44 GiB (100.00%)
used: 142.48 GiB (15.3%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 29.3 MiB (30.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 931.44 GiB size: 931.44 GiB (100.00%)
ID-4: /var/log raw-size: 931.44 GiB size: 931.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.44 GiB size: 931.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.47 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 58.2 C mobo: N/A
GPU: device: amdgpu temp: 53.0 C mem: 64.0 C fan: 0 watts: 77.00
device: amdgpu temp: 45.0 C
Processes: 441 Uptime: 0m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.47 GiB used: 4.81 GiB (15.8%) Init: systemd v: 254
Packages: 2150 pm: pacman pkgs: 2126 libs: 578 tools: octopi,paru,yay
pm: flatpak pkgs: 24 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-07-26
Last full system update: 2023-10-13
