Kernel: 6.16.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=7c00ebe1-2afc-47d3-89ef-5d20ec101133 rw rootflags=subvol=@
quiet resume=UUID=e78c8cd0-674e-4997-ba57-cd0d1ffa26ab loglevel=3
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
wm: kwin_x11 tools: avail: lxlock vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: LENOVO product: 83DV v: LOQ 15IRX9
serial: <superuser required> Chassis: type: 10 v: LOQ 15IRX9
Mobo: LENOVO model: LNVNB161216 v: SDK0T76462 WIN
serial: <superuser required> part-nu: LENOVO_MT_83DV_BU_idea_FM_LOQ 15IRX9
uuid: <superuser required> UEFI: LENOVO v: NECN39WW date: 09/06/2024
ID-1: BAT1 charge: 23.3 Wh (39.7%) condition: 58.7/60.0 Wh (97.8%)
power: 30.4 W volts: 15.0 min: 15.4 model: SMP L23M4PK4 type: Li-poly
serial: <filter> status: discharging cycles: 134
Info: model: 13th Gen Intel Core i7-13650HX bits: 64 type: MST AMCP
microcode: 0x12F
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 800 min/max: 800/4700:4900:3600 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 112127
Device-1: Intel Raptor Lake-S UHD Graphics vendor: Lenovo driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: eDP-2 empty: DP-2, DP-3, HDMI-A-2, HDMI-A-3, HDMI-A-4, HDMI-A-5
bus-ID: 00:02.0 chip-ID: 8086:a78b class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile] vendor: Lenovo
driver: nvidia v: 580.76.05 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s ports:
active: none empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:28e0
Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 174f:246d
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
Monitor-1: eDP-2 model: AU Optronics 0x7ead serial: <filter> built: 2023
res: mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2
modes: 1920x1080
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.5
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-S)
device-ID: 8086:a78b memory: 14.96 GiB unified: yes
API: Vulkan v: 1.4.321 layers: 11 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-S) driver: mesa intel v: 25.2.1-arch1.5
device-ID: 8086:a78b surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 4060 Laptop GPU driver: nvidia v: 580.76.05
device-ID: 10de:28e0 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.1-arch1.5 (LLVM
Device-1: Intel Raptor Lake High Definition Audio vendor: Lenovo
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0401
Device-2: NVIDIA AD107 High Definition Audio vendor: Lenovo
API: ALSA v: k6.16.4-zen1-1-zen status: kernel-api tools: N/A
port: 4000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:b852 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 0bda:4853
Local Storage: total: 476.94 GiB used: 144.43 GiB (30.3%)
model: MTFDKCD512QFM-1BD1AABLA size: 476.94 GiB block-size: physical: 512 B
fw-rev: 1002V3LN temp: 39.9 C scheme: GPT
ID-1: / raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
used: 144.42 GiB (31.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 8.6 MiB (2.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
ID-4: /var/log raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.79 GiB size: 459.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.86 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 52.8 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 4.27 GiB (27.9%)
Processes: 396 Power: uptime: 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.04 GiB services: org_kde_powerdevil,
Packages: 1623 pm: pacman pkgs: 1598 libs: 402 tools: octopi,paru
pm: flatpak pkgs: 25 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash
v: 5.3.3 default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
Garuda (2.8.2-2):
System install date: 2025-07-04
Last full system update: 2025-09-03
22/23 checks run in 0.94 seconds ⌛
Powered by garuda-health 🦅
--- INFO ---
- Nvidia drivers are installed, but an incorrect or a suboptimal hardware profile is active (fix available)
Hi, I have been experiencing a similar issue for a while (1-2 months), though not on live USB. I have been connecting to the Internet and VPN using nmtui
, but it asks for password every time. Sometimes, I also need to wait a few minutes or open the WiFi section in system settings to enter the password. Is there a way to fix Wallet or saving passwords on nmtui?
