please fix this bug
Can you plz post your garuda-inxi?
- When did this problem start?
- Have you tried with another SDDM login screen?
- Have you tried with only one monitor? (say the laptop's only)
- Have you tried searching the Web for SDDM graphical issues?
Just an example of a 30 seconds search:
https://wiki.archlinux.org/title/SDDM#Overlapping_greeters_on_multiscreen_setup
i think this problem is not only for me
maybe code has bug
thank you but there is no way to solve this with update?
It's not a bug, you have your configuration incorrectly set. Filo posted guidance for fixing your configuration if you are interested.
There is a possible solution right here
its worked
but how can i zoom in laptop screen
At login screen?
That's a different issue. I know there's plenty of solutions on the web cuz I had to search for this a while back.
I ended up using xrandr in a script for my use case, but it also zooms (scales) the user graphical environment, so you have to search more to avoid that if you don't want to scale user as well.
I edited the topic to reflect clearly the issue so others can easily find it when they search for the same issue as yours. ![]()
