Unknown controller access device getting compromised; manipulating ps5 controller input after popping up before every game that is run or crashing games outright; in Steam and making the Steam interface unusable.
Kernel: 6.13.6-hardened1-1-hardened arch: x86_64 bits: 64 compiler: gcc
v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm parameters: pti=on
root=UUID=90bad688-87c2-4fa2-a41d-19c0de4179f2 rw rootflags=subvol=@
quiet rd.luks.uuid=55e381a9-1da2-4774-9917-9126737d9ffd loglevel=3
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
Mobo: ASUSTeK model: ROG STRIX B850-I GAMING WIFI v: Rev 1.xx
UEFI: American Megatrends v: 0825 date: 11/29/2024
Device-1: ps-controller-battery-7c:66:ef:30:b2:4d model: N/A serial: N/A
charge: N/A status: full
Info: model: AMD Ryzen 7 8700G w/ Radeon 780M Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705206
Speed (MHz): avg: 5108 min/max: 400/5176 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 5108 2: 5108 3: 5108
4: 5108 5: 5108 6: 5108 7: 5108 8: 5108 9: 5108 10: 5108 11: 5108 12: 5108
13: 5108 14: 5108 15: 5108 16: 5108 bogomips: 134141
Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
7800 XT] vendor: XFX driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2,Writeback-1 bus-ID: 03:00.0
chip-ID: 1002:747e class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: ASUSTeK
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-4, DP-5, DP-6, DP-7, DP-8, HDMI-A-2, Writeback-2 bus-ID: 0d:00.0
chip-ID: 1002:15bf class-ID: 0300 temp: 52.0 C
gpu: amdgpu d-rect: 5360x1440 display-ID: 0
Monitor-1: DP-3 pos: primary,left model: Samsung S34CG50 serial: <filter>
built: 2024 res: mode: 3440x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 3440x1440
min: 720x400
Monitor-2: HDMI-A-1 pos: right model: Sharp HDMI built: 2008 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 59 gamma: 1.2
size: 820x460mm (32.28x18.11") diag: 940mm (37") ratio: 16:9 modes:
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
navi32 LLVM 19.1.7 DRM 3.61 6.13.6-hardened1-1-hardened)
device-ID: 1002:747e memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.304 layers: 8 device: 0 type: discrete-gpu name: AMD
Radeon RX 7800 XT (RADV NAVI32) driver: N/A device-ID: 1002:747e
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV GFX1103_R1) driver: N/A device-ID: 1002:15bf
Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:1640
Device-3: Sony DualSense wireless controller (PS5)
driver: playstation,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-1:5 chip-ID: 054c:0ce6 class-ID: 0300
Device-4: ASUSTek USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2
chip-ID: 0b05:1be1 class-ID: 0300
API: ALSA v: k6.13.6-hardened1-1-hardened status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.0 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I226-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0 chip-ID: 8086:125c
Device-2: Sony DualSense wireless controller (PS5)
Local Storage: total: 1.82 TiB used: 474.56 GiB (25.4%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 53.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Transcend model: N/A size: 1.87 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: TS37
scheme: MBR
ID-1: / raw-size: 71.28 GiB size: 71.28 GiB (100.00%)
used: 48.76 GiB (68.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-55e381a9-1da2-4774-9917-9126737d9ffd
used: 31.3 MiB (32.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 71.28 GiB size: 71.28 GiB (100.00%)
ID-4: /var/log raw-size: 71.28 GiB size: 71.28 GiB (100.00%)
ID-5: /var/tmp raw-size: 71.28 GiB size: 71.28 GiB (100.00%)
ID-1: swap-1 type: zram size: 60.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 70.0 C mobo: 46.5 C
GPU: device: amdgpu temp: 51.0 C watts: 32.14 device: amdgpu temp: 73.0 C
mem: 73.0 C fan: 496 watts: 60.00
Memory: total: 64 GiB note: est. available: 60.49 GiB
used: 21.83 GiB (36.1%)
Processes: 473 Power: uptime: 4h 22m states: freeze,mem suspend: deep
avail: s2idle wakeups: 1 services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1460 libs: 457 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.0 running-in: konsole
inxi: 3.3.37
System install date: 2025-02-05
Last full system update: 2025-03-12
