so, as I’ve mentioned before I recently reinstalled Garuda (as we all do, don’t we?) and decided to try Mokka. Lovely, except that… every now and again, KDE will freeze. Running programs aren’t affected, but taskbar and panels just lie there non-responsive.
Alt-tabbing works, system-wide shortcuts work (like I mapped KRunner to meta+r)… but that’s it. After a while it seems to refresh, and freeze again.
Ideas on troubleshooting this? (yeah yeah, I now I need to restart)
Kernel: 6.15.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=4ecc7201-c93d-43c1-8ebe-cab168420a64 rw rootflags=subvol=@
quiet resume=UUID=7b8745dc-f1a9-4f64-88ca-5c7aa55e0bbc loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.4.3 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Laptop System: Dell product: G5 5590 v: N/A
Mobo: Dell model: 0CNDTP v: A04 serial: <superuser required> part-nu: 08EA
uuid: <superuser required> UEFI: Dell v: 1.27.0 date: 09/13/2023
ID-1: BAT0 charge: 34.7 Wh (100.0%) condition: 34.7/60.0 Wh (57.9%)
volts: 15.6 min: 15.2 model: SMP DELL JJPFK87 type: Li-poly serial: <filter>
status: full
Speed (MHz): avg: 900 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
8: 900 9: 900 10: 900 11: 900 12: 900 bogomips: 62399
ports: active: none off: eDP-1 empty: DP-2, DP-3, HDMI-A-2, HDMI-A-3
bus-ID: 0000:00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Dell
driver: nvidia v: 575.64.05 alternate: nouveau,nvidia_drm
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 ports:
active: none off: DP-1,HDMI-A-1 empty: none bus-ID: 0000:01:00.0
chip-ID: 10de:1f11 class-ID: 0300
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0c45:671f
class-ID: 0e02
gpu: i915,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-1 model: LG (GoldStar) HDR WFHD serial: <filter> built: 2018
res: mode: 2560x1080 hz: 75 scale: 100% (1) dpi: 81 gamma: 1.2
size: 798x334mm (31.42x13.15") diag: 869mm (34.2") modes: max: 2560x1080
min: 640x480
Monitor-2: HDMI-A-1 model: LG (GoldStar) ULTRAWIDE serial: <filter>
built: 2013 res: mode: 2560x1080 hz: 60 scale: 100% (1) dpi: 112 gamma: 1.2
size: 677x290mm (26.65x11.42") diag: 628mm (24.7") modes: max: 2560x1080
min: 640x480
Monitor-3: eDP-1 model: BOE Display 0x084a built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.6-arch1.1
GT2) device-ID: 8086:3e9b memory: 15.06 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 14 device: 0 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel v: 25.1.6-arch1.1
device-ID: 8086:3e9b surfaces: N/A device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 575.64.05
device-ID: 10de:1f11 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.6-arch1.1 (LLVM
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 0000:00:1f.3
Device-2: NVIDIA TU106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:10f9
Device-3: Realtek USB Audio driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.5:9 chip-ID: 0bda:4014
API: ALSA v: k6.15.7-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 0000:3b:00.0 chip-ID: 10ec:2502 class-ID: 0200
IF: enp59s0 state: down mac: <filter>
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 0000:3c:00.0
chip-ID: 168c:003e class-ID: 0280
IF: wlp60s0 state: down mac: <filter>
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-1.2:3
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 0cf3:e007
driver: intel_nvme_remap v: kernel port: 5060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 2.73 TiB used: 952.61 GiB (34.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: MP600 CORE MINI
size: 1.82 TiB block-size: physical: 512 B logical: 512 B tech: SSD
serial: <filter> fw-rev: ELFMC1.0 temp: 45.9 C scheme: GPT
model: WD10SPZX-75Z10T3 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 4514 scheme: GPT
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 136.19 GiB (7.4%)
used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
used: 136.19 GiB (7.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.42 GiB used: 8.7 GiB (56.4%)
ID-2: swap-2 type: partition size: 16.97 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 95.0 C pch: 67.0 C mobo: N/A
Memory: total: 16 GiB available: 15.43 GiB used: 12.77 GiB (82.8%)
Processes: 412 Power: uptime: 2d 22h 39m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.09 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1608 libs: 467 tools: octopi,paru Compilers:
clang: 20.1.8 gcc: 15.1.1 Shell: garuda-inxi default: Zsh v: 5.9
running-in: tmux: inxi: 3.3.38
Garuda (2.7.3-2):
System install date: 2025-07-14
Last full system update: 2025-07-29 ↻
Failed units
