KDE Plasma, ethernet not working waking from sleep
Hey! I am back to spill the beans on my ethernet not working occasionally.
I have a problem with ethernet not working waking from sleep. Must be caused by some update. Since it used work fine. What’s up with that…?
I read an old post on similar topic last week but I wonder if this might be the same problem or not?
  Kernel: 6.10.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=83e6e33d-5f20-4d39-9ccf-b5fc2847233f rw rootflags=subvol=@
    quiet resume=UUID=2a353ec0-d5c1-4a6c-b8fa-35e185d234c6 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
  Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
    UEFI: American Megatrends v: 4604 date: 03/22/2024
  Info: model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
    L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 3044 high: 3704 min/max: 2200/4148 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3000 2: 3000
    3: 3000 4: 3000 5: 3000 6: 3000 7: 3704 8: 3000 9: 3000 10: 3000 11: 3000
    12: 3000 13: 3000 14: 3000 15: 3000 16: 3000 bogomips: 95819
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASUSTeK
    active: DP-1,DP-3 empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 0b:00.0
    chip-ID: 1002:73ff class-ID: 0300
  Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 046d:0825
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: Dell U2412M serial: <filter> built: 2011
    res: 1920x1200 dpi: 94 gamma: 1.2 size: 518x324mm (20.39x12.76")
    diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200 min: 720x400
  Monitor-2: DP-3 model: Dell U2412M serial: <filter> built: 2011
  API: Vulkan v: 1.3.285 layers: 7 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 24.1.4-arch1.3
    device-ID: 1002:73ff surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.1.4-arch1.3 (LLVM 18.1.8) device-ID: 10005:0000
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
    bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
  Device-4: C-Media CM6631A Audio Processor
    lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 0d8c:0004 class-ID: 0300
  API: ALSA v: k6.10.2-zen1-1-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
  Device-2: Dell Alienware AW620m Wireless Gaming mouse Dongle
    driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 3-3:2 chip-ID: 413c:302d class-ID: 0300
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4
  Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: not found
    rfk-block: hardware: no software: no address: see --recommends
  Local Storage: total: 3.44 TiB used: 44.5 GiB (1.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
    model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
    fw-rev: H211011a temp: 39.9 C scheme: GPT
    model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
    scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SUV400S37240G
    size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 96R9 scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: Wilk model: USB DISK 3.0
    size: 28.91 GiB block-size: physical: 512 B logical: 512 B type: USB
    fw-rev: PMAP scheme: MBR
  ID-1: / raw-size: 459.56 GiB size: 459.56 GiB (100.00%)
    used: 44.5 GiB (9.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 459.56 GiB size: 459.56 GiB (100.00%)
  ID-4: /var/log raw-size: 459.56 GiB size: 459.56 GiB (100.00%)
  ID-5: /var/tmp raw-size: 459.56 GiB size: 459.56 GiB (100.00%)
  ID-2: swap-2 type: partition size: 17.08 GiB used: 0 KiB (0.0%)
  System Temperatures: cpu: 39.8 C mobo: N/A gpu: amdgpu temp: 30.0 C
    mem: 24.0 C
  Memory: total: 16 GiB available: 15.53 GiB used: 3.12 GiB (20.1%)
  Processes: 393 Power: uptime: 4m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,upowerd
  Packages: 1223 pm: pacman pkgs: 1217 libs: 381 tools: paru pm: flatpak
    pkgs: 6 Compilers: N/A Shell: garuda-inxi default: fish v: 3.7.1
    running-in: kitty inxi: 3.3.35
  System install date:     2024-07-22
  Last full system update: 2024-07-29
I would suggest testing the linux-lts kernel. If that is no better, I would suggest installing the proprietary r8168 driver.
