So, I was trying to customize some of my themes, I decided to just go and reset everything back to defaults and try again, but when I started doing that, it didn’t reset to default and now I can’t figure out how to get it back. I was wanting to know if I could get some help on getting my pin button back and resetting everything to normal. I did a search and found a forum post about someone wanting to change the pin button but the question was never answered. I also feel like I am missing more than just the pin button… Hmm…
When I press “Reset configs to default state”, I get 3 errors resetting the config files.
I am still playing around with it… I think I found a way to get the pin button back, but it’s not the beautiful green one that came with the OS. I just got everything like I like it… I am not sure if it’s worth reinstalling again over but it is kind of a minor inconvenience. I was told to link my garuda-inxi so here ya go! Any help would be much appreciated!
Kernel: 6.14.2-arch1-1-znver3 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver3
root=UUID=158341e7-23f5-4e07-adc5-5f30d9ae10b2 rw rootflags=subvol=@
quiet resume=UUID=77b0f943-5895-4a94-a89d-9830379dbce3 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA402RK_GA402RK
v: 1.0 serial:
Mobo: ASUSTeK model: GA402RK v: 1.0 serial:
uuid: UEFI: American Megatrends LLC. v: GA402RK.318
date: 03/09/2023
ID-1: BAT0 charge: 26.5 Wh (46.3%) condition: 57.2/76.0 Wh (75.2%)
power: 71.1 W volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion
serial: N/A status: charging
Info: model: AMD Ryzen 9 6900HS with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404107
Speed (MHz): avg: 3211 min/max: 400/4936 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3211 2: 3211 3: 3211
4: 3211 5: 3211 6: 3211 7: 3211 8: 3211 9: 3211 10: 3211 11: 3211 12: 3211
13: 3211 14: 3211 15: 3211 16: 3211 bogomips: 105405
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6650 XT /
6700S 6800S] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1, HDMI-A-1,
Writeback-1, eDP-1 bus-ID: 03:00.0 chip-ID: 1002:73ef class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: eDP-2 empty: DP-2, DP-3, DP-4, DP-5, DP-6, DP-7,
DP-8, DP-9, Writeback-2 bus-ID: 07:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 45.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:56eb
class-ID: fe01 serial:
gpu: amdgpu display-ID: 0
Monitor-1: eDP-2 model: BOE Display 0x0a1d built: 2021 res:
mode: 2560x1600 hz: 120 scale: 145% (1.45) to: 1766x1103 dpi: 215 gamma: 1.2
size: 302x189mm (11.89x7.44") diag: 356mm (14") ratio: 16:10 modes:
max: 2560x1600 min: 640x480
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 680M (radeonsi rembrandt
LLVM 19.1.7 DRM 3.61 6.14.2-arch1-1-znver3) device-ID: 1002:1681
API: Vulkan v: 1.4.309 layers: 13 device: 0 type: integrated-gpu name: AMD
Radeon 680M (RADV REMBRANDT) driver: N/A device-ID: 1002:1681
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: AMD Radeon
RX 6800S (RADV NAVI23) driver: N/A device-ID: 1002:73ef
lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: ASUSTeK driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
lanes: 16 bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.14.2-arch1-1-znver3 status: kernel-api with: aoss
vendor: AzureWave ASUS PCE-AXE59BT driver: mt7921e v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:7922 class-ID: 0280
IF: wlp5s0 state: up mac:
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 13d3:3568
class-ID: e001 serial:
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: bt-v: 5.2
Local Storage: total: 953.87 GiB used: 102.21 GiB (10.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2450 MTFDKBA1T0TFK
lanes: 4 tech: SSD serial: fw-rev: V5MA010 temp: 36.9 C
ID-1: / raw-size: 937.24 GiB size: 937.24 GiB (100.00%)
used: 102.21 GiB (10.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 937.24 GiB size: 937.24 GiB (100.00%)
ID-4: /var/log raw-size: 937.24 GiB size: 937.24 GiB (100.00%)
ID-5: /var/tmp raw-size: 937.24 GiB size: 937.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.85 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.33 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 54.5 C mobo: 40.0 C
Fan Speeds (rpm): cpu: 2500
GPU: device: amdgpu temp: 45.0 C mem: 40.0 C fan: 0 watts: 5.00
device: amdgpu temp: 46.0 C
Memory: total: 16 GiB note: est. available: 14.85 GiB used: 5.51 GiB (37.1%)
Processes: 427 Power: uptime: 37m states: freeze,mem,disk suspend: s2idle
image: 5.93 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 1848 libs: 541 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date: 2025-04-10
Last full system update: 2025-04-11
