My desktop environment, dragonized, broke after garuda-update, Latte is not working either:
Latte icon shows the following error when I press on it:
file:///usr/share/plasma/plasmoids/org.kde.latte.plasmoid/contents/ui/main.qml:17:1: plugin cannot be loaded for module "org.kde.plasma.private.taskmanager": Cannot load library /usr/lib/qt/qml/org/kde/plasma/private/taskmanager/libtaskmanagerplugin.so: (/usr/lib/libprocesscore.so.9: file too short)
I had to launch my applications through the start-menu, which luckily still works.
inxi:
╰─λ garuda-inxi
Kernel: 6.0.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=cd218c4a-cd87-436a-a31d-1f94c11b73ca rw rootflags=subvol=@
resume=UUID=9a65ace2-c064-49fe-a16d-7da701bbdb7d loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.26.0 tk: Qt v: 5.15.6 info: latte-dock vt: 1
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B350-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 6042
date: 04/28/2022
Info: model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2831 high: 3197 min/max: 1550/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2558 2: 3109
3: 2739 4: 2557 5: 2573 6: 3000 7: 3197 8: 3000 9: 3000 10: 3000 11: 2578
12: 3000 13: 2561 14: 2687 15: 2553 16: 3184 bogomips: 95816
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: eVga.com.
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 07:00.0 chip-ID: 10de:1b06 class-ID: 0300
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-5:3 chip-ID: 046d:0843 class-ID: 0102
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.57x13.11")
s-diag: 868mm (34.19")
Monitor-1: DP-2 res: 3440x1440 dpi: 109 size: 800x330mm (31.5x12.99")
diag: 865mm (34.07") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: NVIDIA GP102 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
bus-ID: 1-5:3 v: kernel pcie: chip-ID: 046d:0843 gen: 3 class-ID: 0102
speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 10de:10ef class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.3
Device-3: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Device-4: SAVITECH JDS Labs Element DAC type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:2 chip-ID: 262a:1048
class-ID: 0102
Sound API: ALSA v: k6.0.1-zen2-1-zen running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
IF-ID-1: br-e102d34c0b28 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-3: veth1812dc9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: veth2895b67 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-5: veth82c9c50 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: vethaec8be2 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: vethba6cb55 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: vethbee0af9 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: vetheda49e7 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: virbr0 state: down mac: <filter>
IF-ID-11: virbr1 state: down mac: <filter>
Supported mdraid levels: raid0
Device-1: md0 maj-min: 9:0 type: mdraid level: raid-0 status: active
Info: report: N/A blocks: 891025408 chunk-size: 512k super-blocks: 1.2
Components: Online:
0: sdb1 maj-min: 8:17 size: 425 GiB
1: sdc1 maj-min: 8:33 size: 425 GiB
Local Storage: total: 2.54 TiB used: 1017.14 GiB (39.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 950 PRO
512GB size: 476.94 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B0QBXX7
temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:9 vendor: Samsung model: SSD 960 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7
temp: 27.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT525MX300SSD1
size: 489.05 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R060 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
ID-1: / raw-size: 121.64 GiB size: 121.64 GiB (100.00%) used: 114.96 GiB
(94.5%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 596 KiB
(0.2%) fs: vfat dev: /dev/nvme0n1p8 maj-min: 259:8
ID-3: /home raw-size: 250.86 GiB size: 250.86 GiB (100.00%) used: 75.74
GiB (30.2%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /var/log raw-size: 121.64 GiB size: 121.64 GiB (100.00%) used: 114.96
GiB (94.5%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-5: /var/tmp raw-size: 121.64 GiB size: 121.64 GiB (100.00%) used: 114.96
ID-1: swap-1 type: zram size: 15.53 GiB used: 770.5 MiB (4.8%)
ID-2: swap-2 type: partition size: 7.91 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 38.4 C mobo: 32.0 C gpu: nvidia temp: 40 C
Fan Speeds (RPM): cpu: 291 fan-2: 260 fan-3: 254 fan-4: 272 fan-6: 0
gpu: nvidia fan: 17%
Power: 12v: N/A 5v: N/A 3.3v: 3.31 vbat: 3.27
Processes: 513 Uptime: 4m wakeups: 0 Memory: 15.53 GiB used: 6.19 GiB
(39.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2078
libs: 549 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
Garuda (2.6.8-1):
System install date: 2022-04-08
Last full system update: 2022-10-14
Failed units: shadow.service
